What level to you watch movies at?
What level do you watch movies at?
Greater than reference (>85 db)
16%
 16%  [ 4 ]
Reference (85 db)
8%
 8%  [ 2 ]
A bit under refernce (75 db to 84 db)
41%
 41%  [ 10 ]
Fairly quiet (<75 db)
4%
 4%  [ 1 ]
I have no clue what it really is.
29%
 29%  [ 7 ]
Total Votes : 24
Person99
Posted: Tue May 20, 2008 1:36 pm    Post subject: What level to you watch movies at?
I've noticed that in my acoustically treated room (fairly dead) 13.5' x 18' theater I still tend to watch movies at -8 or -9 db and that sounds about right to me, in fact pretty close to or a bit above what it sounds like in the theater. If I go to reference levels action scenes sound great, but voices and ambient sounds are unnaturally loud. With my daughter in the theater, we tend to do about -14 to -16 from reference. Curious what others tended to do. Assuming you have a calibrated system, and you know, where do you listen at?
Posted: Tue May 20, 2008 2:11 pm    Post subject:
I listen fairly quietly now. I live in a row home(town house to you suburbanites) So blasting away @ loud levels is bad form.
In my new spot im designing a sound treated room, so then i'll probably be close to reference levels.
JustGreg
Posted: Tue May 20, 2008 4:59 pm    Post subject:
I currently have a center channel issue so try to make up for low vol dialogue with wattage. You can guess how well that works out in an action movie. Either straining your ears... or crapping your pants...not good. Either that or I'm the old(er) dude from the commercial set in a theater who keeps asking his wife "What did they say? What did they say?"
I try to keep it around reference out of deference to my guests.
Greg
Posted: Tue May 20, 2008 5:24 pm    Post subject:
On the floor looking up with headphones mostly Laughing
JustGreg
Posted: Tue May 20, 2008 6:06 pm    Post subject:
Laughing Laughing Ya nut you. Wink
Greg
Posted: Tue May 20, 2008 6:08 pm    Post subject:
How do you measure reference level? Is there a standard test tone?
I tend to watch fairly loud, probably at or above reference. Partly because of the same kind of center-channel issue Greg mentioned, partly because of the old-dude issue Greg mentioned. Smile My hearing is definitely not what it was, and especially with my crap center I miss dialog if I turn it down.
papalek
Posted: Tue May 20, 2008 6:26 pm    Post subject:
I listen at or above reference level. When a door slams in the back ground I want my guests to turn and look behind them. Mr. Green Besides when something blows up on screen I want everyone to "feel" the explosion. Mr. Green Thumbs Up Thats why I have 3 of the 21" subs and around 7000 watts of power in a 6.5 set up(yes 5 subs 3-21's and 2-15's). Thumbs Up
I do love my AmPro's
Person99
Posted: Tue May 20, 2008 6:31 pm    Post subject:
Actually, at reference volumes, the peaks for explosions will be 105 db. In my theater, I feel that even at -10 db from my 2 modest subs.
papalek
Posted: Tue May 20, 2008 6:38 pm    Post subject:
Yes you can feel it but my guest have the opened eyed look Shocked and ususally say HOLY sh*t THIS SYSTEM ROCKS!!! Thumbs Up Mr. Green
Person99
Posted: Tue May 20, 2008 6:40 pm    Post subject:
Calibration discs have the standard test tones to be used with the radio shack analog meter. The DVE ones are low, but it is well documented.
Most AVRs now have auto set up features. Some are relatively close. For instance, on my Yammy, after letting it do its auto set up, 0 db on the dial is just a couple db under refrence. So, when I'm at -8 db on the dial, I'm at -10db from reference.
Person99
Posted: Tue May 20, 2008 6:42 pm    Post subject:
Also, the Rives Audio Test CD is very good.
Posted: Tue May 20, 2008 6:55 pm    Post subject:
OK, I'll have to dig out DVE when I get a chance. I usually run my Onkyo at 40-45 on the dial, but whoknoze how that translates to dB?
Person99
Posted: Tue May 20, 2008 6:58 pm    Post subject:
If the AVR does not have calibration features, then it is just their ballpark guess with "average" sensitivity speakers. 0 db on the dial SHOULD be 85 db, but without calibration, there is no way for that to be known.
Do you mean -40 on the dial? If +40, either your Onkyo is waaaaaaay off or you are using some very low sensitivity power hungry speakers!!!
Posted: Tue May 20, 2008 7:10 pm    Post subject:
No, the Onkyo doesn't have a dB-labeled dial. Its "Volume" control goes from 0 to 72.
dropzone7
Posted: Tue May 20, 2008 7:11 pm    Post subject:
If it's just me in the room and I'm trying to spare my wife the rumbles and rattles then I usually run at -20 to -25. If everyone is in the room and we want the full effect then I normally crank it up to -12 or so. This is on an Onkyo 705 and I have run Audyssey on it and it sounds great to me. If I could change anything it would be to add two more surrounds and upgrade my sub.
"Coffee is for Closers."
JustGreg
Posted: Tue May 20, 2008 7:33 pm    Post subject:
The Rives Audio Test CD 2 has compensated tones for the Radio Shack SPL meter
http://www.rivesaudio.com/software/TestCD.html
I'm thinking of running my center channel through an older Rat Shack receiver and then through an equalizer. It may be the location of my center channel that's causing me grief too. (In my photo album) It's above and about 3 ft in front of the screen but still in line with the fronts. It's angled down to hit in between the front and rear row of seating. I admit freely I winged things when setting up the audio.
Before adding the amp and equalizer I may take a look at the crossover in it. Well, have someone else look at it and make recommendations for modifications. I'd replace what is just a generic multi location speaker with a designed-for mid tier (never mind high end) center channel but the $$$ just isn't there.
Until one of the two happens, center dialogue is gonna have to remain Mob Don cotton-stuffed-cheeks sounding. Rolling Eyes
Greg
Posted: Tue May 20, 2008 8:34 pm    Post subject:
Well, crap. The battery in my Ratshack meter corroded and I don't have another 9V handy. Have to try measuring later.
I dug out DVE and I see all kinds of test tones and sweep tones, but I don't see a reference measurement tone. Where is it?
I must have something really screwed up with my audio. Last time I checked the sound setup with DVE, everything was OK. Now I'm not getting proper location (left-front coming only out left-front speaker, etc) and I don't seem to be getting ANYthing out on LFE. But the sub responds when you do a low-freq sweep in other channels. Urgh. Probably some bad setting in the AVR. I'll have to track that down, but that'll be another thread.
fireanimal
Posted: Tue May 20, 2008 11:14 pm    Post subject:
My room is soundproof and accoustically treated. I listen at or above reference levels, and it never sounds too loud or causes listener fatigue.
My Movie Collection
Posted: Wed May 21, 2008 3:27 am    Post subject:
I use a whole pile of random amplifiers. Levels depend on the movie... if I'm watching transformers, I turn the mother up so loud that jets are as loud as actual jets. Or as close as I can get without distorting all over the place. Very Happy At any rate, with my setup there are so many knobs that it's pointless to look at the numbers. Everything gets matched up with AC3filter anyway; I set the levels so the max is clean and go from there.
During one of my test setups, I actually started to get up to go get the door when someone knocked off-screen. My wife really thought it was funny.
Posted: Wed May 21, 2008 3:31 am    Post subject:
I've gotten up to answer the phone once just like that. I was running for my old work phone cause you only get 5 rings and it was in my jacket. I stoped running once I walked pass the speakers. lol
