Whats the Difference??
Posted: Mon May 19, 2008 9:31 am    Post subject: Whats the Difference??
Barco 1100 and 1600 are known for eating tubes yet these PJs are based on the 800 series which, as far as I can see, are not known for the same issue. So why do 9" tubes blow when 8" don't?
Posted: Mon May 19, 2008 10:25 am    Post subject:
I'm pretty sure the problem is in the tube design.
deronmoped
Posted: Mon May 19, 2008 3:55 pm    Post subject:
The tubes are good, it's the PJ overdriving them that is the problem. The tubes are used in other PJ's without shorting out, Barco was trying to get way too much brightness out of them.
Deron.
Posted: Mon May 19, 2008 9:44 pm    Post subject:
Ok. If they are driving them too hard then why don't the 800 series tubes fail the same way. As mentioned the PJ components are almost (if not) identical which would mean the 800 series tubes are driven just as hard even though they produce less light.
