Gerbrand
| Posted: Tue May 13, 2008 1:17 pm Post subject: Upgrading a BG808 to a BG1208/2, is it worth it? |
Hello all,
Since about a year I am the owner of a BG808. After struggling with drift for a while due to bad mechanical setup , I am now quite satisfied with its performance. And I can't bear looking at staircases on plasmas and LCDs anymore...
I use 1440x864@50 Hz for SD and 1920x1080@72i for HD (both using a HDFury on port 3). The latter is pretty soft: I am just able to discern the lines at resolution.
I may have the opportunity to buy a 1208/2 with toasted tubes. Would it be worth the effort to transfer my own tubes to this chassis? Or should I just wait until the prices on those 9"-er really start to drop ?
Thanks for your suggestions,
Gerbrand
kal Forum Administrator
Person99
| Posted: Tue May 13, 2008 5:31 pm Post subject: |
It is a small but not significant upgrade. If it were a 1208s/2 with good tubes, then I'd do it. Otherwise, no. If 1080i/72 is soft, you may need to do a better mechanical set up or perhaps you are using the Fury to drive too long a cable?
_________________ Dave
Gerbrand
| Posted: Wed May 14, 2008 8:00 am Post subject: |
Ok, I will wait till those affordable 9" start coming...
| Person99 wrote: | | If 1080i/72 is soft, you may need to do a better mechanical set up or perhaps you are using the Fury to drive too long a cable? |
I still need to do mechanical beam focus and astigmatism, but I am currently waiting for the materials to mount it to the ceiling. I reckon this will change the mechanical set-up a bit.
The Fury is driving the VGA to port 3 cable that came with it, so that should not be a problem.
Gerbrand
Person99
| Posted: Wed May 14, 2008 2:29 pm Post subject: |
| Gerbrand wrote: |
Have you upgraded the caps on your port 3 board? If not, you might consider that.
Gerbrand
| Posted: Wed May 14, 2008 4:06 pm Post subject: |
| Person99 wrote: |
Have you upgraded the caps on your port 3 board? If not, you might consider that. |
No I haven't. All is still original in my set AFAIK. Do you have a pointer to a procedure that describes this upgrade?
Gerbrand
Person99
| Posted: Wed May 14, 2008 5:22 pm Post subject: |
| Gerbrand wrote: | | Person99 wrote: |
Gerbrand |
Search here, Pete posted a thread with what to upgreade and all complete with parts list and pictures. I don't have it handy.
Gerbrand
