skyerjoe
| Posted: Wed Aug 19, 2009 11:34 pm Post subject: |
[quote]Its your 3 year old D2, get a new one or profile it to someone's probe that you know is working correctly.
@Nashou66
you think the trouble is the colorimeter
but ... is this really for sure?
i prone to buy an i eye one display lt ....
i dont have someone with an probe or an colorimeter that he can borrow me for a few days
Sorry i don't know anything aobut the the average lifetime for an clolorimeter...
greez fireskyer
| Posted: Wed Aug 19, 2009 11:44 pm Post subject: |
The guys at Spectracal told me that the lesser probes like the Spyder,s and the Display2.s are just consumer probes that should be replaced every year. its just how they are made, the sensors are not the types that can be calibrated, you can oly profile them in the software to an known existing probe once they fall out of spec, i had one go bad after 8 months.
skyerjoe
| Posted: Thu Aug 20, 2009 12:49 am Post subject: |
@nashou66
okay thanks for help but where i can get an profiles and how do i use them with color hcfr and my meter?
maybe i think about it to buy a new one later maybe an eye one pro... but for now it's to expensive for me
btw: how about the eye one pro? is the lifetime higher than the low price products which you've count.
and does it pay to buy an used eye one pro? or later i ve the same accuracy problems like the other ones
and how about the X-Rite ColorMunki?
thanks for help
greetz skyerjoe
thepowerofdonuts
| Posted: Wed Oct 14, 2009 4:32 pm Post subject: Is there something wrong with my i1 LT? |
I got my i1 LT in the mail yesterday, and I'm wondering if there's something wrong with it. The measurements it takes for luminance and gamma are darn close to what they should be, but the color is way off. It says something like 700% for red, 300% for blue, and -100% for green. When I look at the CIE diagram, all my points are in the black part near magenta. Also my footlamberts are really low, under ten even though I'm using a plasma.
Edit: By the way, I've turned blue and red all the way down and green all the way up, and it still reads red and blue really high and green really low, even when I'm looking at a green field.
LastButNotLeast
| Posted: Wed Oct 28, 2009 1:30 am Post subject: gamma |
Was reading an interesting review about a new set here:
http://hdguru.com/the-new-king-of-hdtv-displays-panasonics-tc-p54v10-reviewed/458/
and came across this:
"The Gamma user control, set to its numerically highest level (”Normal”), measured 2.25 average. There is no service level or user gamma tracking adjustment available, an omission we would like to see remedied in a display of this caliber. Blu-ray discs are mastered for a 2.5 gamma display" (emphasis mine).
Huh?
So I tried desperately to get mine (a different set) to 2.2 and now it's "supposed" to be 2.5?!
Any thoughts?
ev666il
| Posted: Fri Dec 11, 2009 11:59 am Post subject: |
I'm sorry if this has already been asked. Kal's guide states that the correct way to set the Color control is so that the Y value of a 100% red window is 21% of that of a 100% white window. I reckon this is only valid for HD, isn't it? What would the correct percentage be, when calibrating against the SD PAL standard?
Thanks in advance.
Bronco70
TV/Projector: BenQ W6000, PE-7700, Panny50" Plasma
| Posted: Wed Dec 16, 2009 1:49 am Post subject: |
Hello Everyone,
Just a quick post to say thanks to Curt for the best guide out there for consumer calibration done with the least expense.
I have been using an Eye One with the GetGray disc and HCFR for the past 5 years. Based on other guides and with effort I have achieved good results on numerous displays.
When I came here today to give the little donation and become a club member I found that I had signed up as a regular member some time back and forgotten about that (my AV bookmark list is way too long). Perhaps too much focus on AVS and all the distraction and time one can spend there.
Anyway, printed out the guide and find that although I have had good results, my methodology has been a bit lacking. As you all understand once familiar with the process, measures in the HCFR program are quite simple. It's the starting point of max luminance that can be hard to get right. Always thought just make sure you don't have the colorimiter in it's shadow, keep the sensors about 3-4" from the screen and go on.
Not so it would appear. Little changes in angle of reflectance, at least with the EyeOne had my range with a 100IRE window at a variance of at least 2 ftL.
Lesson learned.
Just upgraded from a BenQ PE-7700 to a W6000. The 6000 seems to have a very usable CMS with an ISF mode. Should be fun.
Forgive my first, and long winded, post. Promise to keep it pithy in the future.
Happy Holidays,
Joe
adariusbelly
| Posted: Thu May 13, 2010 9:10 am Post subject: |
This "greyscale calibration" guide into a comprehensive "colour calibration" guide including measuring primaries and secondaries, and complete colour decorder adjustments hue/tint/saturation/etc. It is recommended that HCFR is set with the color space definition that matches the calibration test pattern source. This sets the reference standard within HCFR for the color gamut only and has nothing to do with the greyscale calibration itself, since D65 is the same for all standards.
_________________ interiors and fashion colours
Mr Incredible
| Posted: Sun Jul 04, 2010 10:27 pm Post subject: |
I have had a JVC RS20 for about 200 hours use and think it would probably benefit from a calibration. I was reading through the Guide for Dummies to see if perhaps I could give it a go.
One thing I don't quite grasp is why greyscale is adjusted before the primaries. In my mind if the three primary points were way off the REC709 standard "traingle" and I had already done a greysacle adjustment, wouldn't the greyscale be affected by a subsequent change in the one or more primaries?
fuzzyreets
| Posted: Wed Jul 28, 2010 7:52 pm Post subject: |
Let me first say thank you to Curt for this awesome walkthrough. I'm totally new to all this calibration stuff but I found this and have been reading it for days now. This brings me to my question. The thread is at https://www.curtpalme.com/forum_archived/viewtopic.php@t=22754.html
If anyone has any interest in helping me, I'd greatly appreciate it. Thanks very much.
stu31
| Posted: Sat Oct 30, 2010 10:56 am Post subject: |
Hi Kal
Brilliant guide thanks alot.
Im using a LG 50PK990 Plasma, Sony S370 Blu Ray and an EyeOne i want to adjust my colours as in part 8 of the guide but now i'm stuck much to my embarrassment.
I have burnt the AVS HD 709 disk but i cant find the specific window i need could you give me the disk pathway from the opening menu for this instruction please
"Cue up your AVS HD 709 test disc and skip to the 100% white window pattern by selecting "10% Grayscale" -> "100% Gray window". 100% means that the window is at 100 IRE. Write down the Y (Luminance or brightness) reading as seen by the sensor"
and what Y value should i expect to get for my display, is the 39.012 value in the guide for projectors or direct view ?
many thanks
_________________ LG 50PK990, Sony S370 MR, Onkyo 606, Sky+ HD, AE Aegis EVO 3B 7.1, Belkin PF40 mains conditioner, B-Tech Ultragrips, Harmony 555, QED HDMI-Ps, Reference & OT Opticals, Silver Anniversary XT, Netgear XEB1004 Homeplugs, Custom AV Rack
kal Forum Administrator
| Posted: Sat Oct 30, 2010 10:30 pm Post subject: |
| stu31 wrote: | Hi Kal
"Cue up your AVS HD 709 test disc and skip to the 100% white window pattern by selecting "10% Grayscale" -> "100% Gray window". 100% means that the window is at 100 IRE. Write down the Y (Luminance or brightness) reading as seen by the sensor" |
Sorry, they've changed up the disc a dozen or so times since I wrote the guide so I don't know the exact path. You want the 100% gray window. Hunt around. It's a 100% contrast white window in the middle of the screen.
[quote]and what Y value should i expect to get for my display, is the 39.012 value in the guide for projectors or direct view ?[quote]
You have a direct view. You do not have a projector. Follow my guide for whatever it tells you to do for direct view sets.
ash
| Posted: Fri Dec 24, 2010 7:54 pm Post subject: |
One important question for me.
I tried to set the brightness using the DVE and the result was 47, than itried using the AVS 709 HD disc ant the brightness is 51. Which one is correct????????
redfox001
| Posted: Mon Dec 27, 2010 4:57 pm Post subject: Newer led tv's and eyeone pro |
The newer led tv's seem to have sharp peaks in their color spectrum. I heard people say that therefore the color readings from the eye one pro are not accurate. Is there a correction for led tv's in the software or will this be done in future? Regards.
Patrik G
| Posted: Sun Jan 09, 2011 9:12 am Post subject: Re: Newer led tv's and eyeone pro |
HI!
you tested and compared a Spyder2 and a Display2 with RGB readings
the Display2 reads RED to low it seems?
do you know how the Chroma5 is when reading RGB?
is it more close to a reference meter?
i heard other people saying the same about the Display2
that it reads RED low about 5%
why isnt that compensated in the programs when you calibrate a display2?
i mean if its known that it reads red 5% lower than a reference meter?
if i calibrate my tv that have 10Point IRE adjustments to the same line that the picture shows for the Display2
do i get closer to a correct result ?
| Posted: Sun Jan 09, 2011 2:16 pm Post subject: Re: Newer led tv's and eyeone pro |
| Patrik G wrote: | HI!
the Display2 reads RED to low it seems? |
No, the Display2 actually read RED higher then the Spyder2 if you look at the graphs I provided.
It's important to realize that these are the Display 2 and Spyder 2 I tested. Every one will be slightly different. There is considerably more variance in the spyder units because they are not calibrated at the factory. Display 2/LT units tend to be more accurate from the factory as they're calibrated at the factory.
| Quote: | do you know how the Chroma5 is when reading RGB?
is it more close to a reference meter? |
The Chroma 5 is indeeed a much more accurate meter. The CHroma 5 PRO is even more accurate still.
Read this:
FAQ: Which meter is right for me?: https://www.curtpalme.com/forum_archived/viewtopic.php@t=11436.html
And this:
Colour Science: About Meter Accuracy: https://www.curtpalme.com/forum_archived/viewtopic.php@t=22015.html
| Quote: | | i heard other people saying the same about the Display2 that it reads RED low about 5% |
I have not hear that.
The lower end the meter, the more variance you're going to see. So it could read 5-10% too high or 5-10% too low. Display 2's are all initiatially (quickly) calibrated at the factory. To say that they all read 5% too low in RED means that the manufacturer is consistently doing the wrong thing. I really doubt that's the case.
| Quote: | why isnt that compensated in the programs when you calibrate a display2?
i mean if its known that it reads red 5% lower than a reference meter? |
The Display 2 is a low end colorimeter that can easily be off by 5, 10 or even 20%. Every unit will be different. You can't compensate for that.
As well, I don't see how the meters could all be off by exactly 5% in red in the same direction. Why would the manufacturer purposely make something that was consistently off by 5%?
The Display 2 being a colorimeter will also drift over time so the readings will change over time.
This is why we (and others) offer calibration services and recommend that the meter (all colorimeters) be recalibrated at least once a year.
See: http://www.curtpalme.com/ChromaPure_EyeOneDisplay2.shtm
| Quote: | if i calibrate my tv that have 10Point IRE adjustments to the same line that the picture shows for the Display2
do i get closer to a correct result ? |
No. If your meter is incorrect you're calibrating to incorrect settings.
Patrik G
| Posted: Sun Jan 09, 2011 2:36 pm Post subject: Re: Newer led tv's and eyeone pro |
ok thanks for the answer.
i also think its strange if all D2 meters have the same error reading.
i had the Display2 with HCFR
sold that meter yesterday
so the next step i would think off is to get the Chroma5 and Chroma Pure program
http://www.curtpalme.com/ChromaPure_Chroma5.shtm
i hope the shippment to sweden is fast
im going to order it pretty soon
as you are the expert here
what version du you think is best for me PRO or Standard?
i own the LG 47LX950N (LX9900 in the US) FULL LED TV
but as i can see that tv has no pre calibrated offsets in Chroma Pure?
can i go for the Standard Chroma5 instead?
or is the PRO still more accurate?
also a dummies guide for Chroma5 and ChromaPure would be great.
also thanks for the dummies guide!
without that it would be impossible for a newbie to do a calibration.
| Posted: Sun Jan 09, 2011 2:59 pm Post subject: Re: Newer led tv's and eyeone pro |
| Patrik G wrote: | so the next step i would think off is to get the Chroma5 and Chroma Pure program
or is the PRO still more accurate? |
Only you can decide this. There's no right or wrong answer here. It all depends on what sort of accuracy you deem appropriate.
It's hard to put numbers here as there are lots of variables involved, but if I was forced to give numbers it would probably go something like this:
Display 2: 80% accurate
Chroma 5: 90%
Chroma 5 PRO: 95%+
I suggest you read here how and why the Chroma 5 PRO is more accurate and decide for yourself if the extra money is worth it to you: http://www.curtpalme.com/ChromaPure_Chroma5.shtm
An i1Pro or a Chroma 5 will have lower errors than the Display 2. So the question is not so much one of accuracy, but rather "What you are willing to pay for?" Are you satisfied paying $200 for a meter that removes 80% of the errors or would your rather pay 2-3 times more to remove 90% of the errors? Of course, if you invest in a professional quality tool you can remove 95%-99% of the visible errors. Notice, however, that the price/performance curve is not particularly consumer friendly. You have to pay a significantly greater amount for what is really just an incremental improvement in accuracy. For casual amateurs, the Display 2 is fine. For prosumers and dedicated amateurs, or even the professional just starting out, the Chroma 5 PRO is probably the best choice.
| Quote: | | also a dummies guide for Chroma5 and ChromaPure would be great. |
It's not needed. THe free ColorHCFR software is completely unintuitive. There's no workflow, guide, or anything. (That's because it's free). So it made sense for me to write my guide.
ChromaPure however is much easier to use since it walks you through the calibration process from start to end. There's no need for a guide.
| Quote: | also thanks for the dummies guide!
without that it would be impossible for a newbie to do a calibration. |
You're welcome! However, even a newbie can do a calibration as long as they use ChromaPure since it's so easy to use. New users have problems with ColorHCFR since it's completely not intuitive. You need to understand the steps yourself and do them in the right order.
