What to get?
vorlon
Posted: Tue Apr 29, 2008 3:49 am    Post subject: What to get?
Hi
I have a G70 running a HD DVD Player @1080P signal via the HD Fury (powered) into the RGBHV input of my G70 over a 7 meter HDMI cable.
I am looking for something that i can use my existing cable and Fury set up and get the Gamma adjustment and hopefully another HD input so I can connect another HD device.
What magic box is out there that will do this?
I think I can use the RTC2200 but i will have to have it sitting at the CRT, Which I can do because it is hidden in a coffee table.
If i can use the RTC2200 what happens if I connect the RGB via the Fury straight from the HD DVD player @1080P and the Component input with 1080i and 560P via my HT Amp at the same time?
Person99
Posted: Tue Apr 29, 2008 1:48 pm    Post subject:
RTC2200 will do what you want.
RTC2200 auto switches and gives priority to the VGA input, so to see the source on component, the HD DVD player would need to be off.
You other option is a scaler.
