dave1234
| Posted: Mon Apr 28, 2008 9:41 pm Post subject: Electrohome ECP 4100 & HTPC |
I finally hooked one of my ECPs up to my HTPC. I'm running powerstrip, and have the resolution set to 1280x720 @60hz. Now I have 2 questions.
1st-I am getting a little bit of smearing, especially when I right click on a menu. Is there anything I can do to fix this? I tried changing from 60hz to 75hz, with no change.
2nd-I also have the projector hooked up to a scaler, for satellite. When I switch between the inputs, the image shifts. Is there anyway to save individual settings between inputs?
Thanx for the help.
| Posted: Mon Apr 28, 2008 10:36 pm Post subject: Re: Electrohome ECP 4100 & HTPC |
| dave1234 wrote: | I finally hooked one of my ECPs up to my HTPC. I'm running powerstrip, and have the resolution set to 1280x720 @60hz. Now I have 2 questions.
Thanx for the help. |
Hello
What are you using for a switch? If you are using two inputs in the projector you have the ability to set H Move for each input; otherwise you can set up a Recall Memory for each different signal.
dave1234
| Posted: Mon Apr 28, 2008 10:44 pm Post subject: |
I am using the bnc input card. I wasn't sure if you could setup recall memories for these pjs. I'll take another peak in the manual. Ok, figured it out, I can have seperate settings for each input.
Anyone have any ideas on the smearing?
