kal Forum Administrator
| Posted: Tue Apr 22, 2008 1:46 am Post subject: |
I was just reading that Are you going to offer it in PDF form too?
| Posted: Tue Apr 22, 2008 1:54 am Post subject: |
a) right
b) 2 x in this case is not good
c) enuff to go fishing with
d) RIGHT
Is there an easy way to add a printable page switch on the support pages?
| Posted: Tue Apr 22, 2008 12:57 pm Post subject: |
| AnalogRocks wrote: | | Is there an easy way to add a printable page switch on the support pages? |
No, unfortunately not. It's not database driven content (no content management system). It's all hand written - my mistake. I didn't think it was worth it when I first started the site as it was going going to be a couple dozen pages. We're at 650 pages now.
The forum does have a printable version button however.
People can pretty easily cut & paste into a Word document if they really want to. Takes about 60 seconds.
I could have also put the entire thing on one HTML page but with 48 images that would amount to over 5mb of content which causes a pretty slow user experience and dial-up users would be screwed (we had 2340 dial-up visits in the last 30 days).
| Posted: Tue Apr 22, 2008 6:32 pm Post subject: |
Then I'd have to say you are doing a great job balancing the need's of the dialup user's and the high speed user's. My proverbial hat's off to you.
tommo2
| Posted: Sat Aug 02, 2008 3:42 am Post subject: |
You forgot to mention how to setup geometry for green tube. Bow/skew/keystone/linearity etc.
You brush over it on page 4, but that's it. You then go straight onto convergence.
A quote from page 4:
The edge and corner focus have much less range than the center focus, as with the astig adjustments. Usually I find that the left and right edge focus need to be high on the positive side, something between +50 and +90. The top and bottom focus controls are usually not set anywhere near that high, but whatever settings work to get the best focus is what they should be at:
Repeat the above for all sides and corners and for all colors, and you’re set to go!
OK, now that the geometry is hopefully aligned well, and you have a square looking grid pattern on the screen for the green tube, it’s time to align the red and blue tubes over the green.
_________________ pull up the handbrake and walk away
Barco Data 701s
iScan HD scaler with sdi mod
Oppo 981HD with sdi mod
Xbox 360
Playstation 2
Denon AVR 1507 7.1 AV receiver
Wharfedale Diamond 9.4 floorstanders (front)
Wharfedale EVO2 (center)
Pioneer 100W (sides)
Wharfedale Diamond 9.1 (rear)
Wharfedale SW150 active subwoofer
Photos on the way!
| Posted: Sat Aug 02, 2008 4:46 am Post subject: |
Errr.. I don't think I emailed Kal one part of the document... Doing that now..
