front_range
Joined: 03 Mar 2008 Posts: 64 Location: North of Colorado Springs
| Posted: Wed Apr 16, 2008 8:22 pm Post subject: Image problem Cine7 |
On my Cine7, I have a problem with the green, the leading edge is an inch or two into the image projected by red and blue. In other words, the there is a thin line on the left of the screen without green. It's not shifted, the gun just appears blanked a little too long on only one gun. Any ideas?
TIA
| Posted: Wed Apr 16, 2008 8:34 pm Post subject: |
You could try adjusting the Green horizontal width coil then redo the convergence.
front_range
| Posted: Wed Apr 16, 2008 8:38 pm Post subject: |
Doesn't that adjustment just affect the maximum width? If so, I'm no where near that. I'm at maybe 70% ov my availible h-size. If I'm off base, be gentle, I'm new to this...
| Posted: Wed Apr 16, 2008 8:45 pm Post subject: |
Each tube has it's own horizontal width coil but they are used for small adjustments. Can you post some screen shots ?
front_range
| Posted: Wed Apr 16, 2008 9:06 pm Post subject: |
Hopefully this works...
By the way, this is coming off my new PS3 through my also new HDFury, So I may have something wrong in the source settings.
JustGreg
| Posted: Wed Apr 16, 2008 9:27 pm Post subject: |
Never mind. I thought the thread title meant something else.
_________________ Greg
front_range
| Posted: Wed Apr 16, 2008 9:54 pm Post subject: |
I did play with them a bit, but they do not seem affect this artifact.
| Posted: Wed Apr 16, 2008 10:05 pm Post subject: |
What do you have with a genlocked pattern?
front_range
| Posted: Wed Apr 16, 2008 10:42 pm Post subject: |
Genlocked pattern looks good, I have no problem converging. I tried the raster size adjustment in the manual using the coils, but I'm not sure I'm doing it right. I can't see the rasters reflected off my wall (I took the screen down because I have a sheet of WilsonArt coming in tomorrow) so I put a crosshatch up after doing the raster center & toein, and adjusted the pattern widths to match.
| Posted: Wed Apr 16, 2008 10:47 pm Post subject: |
Have you made sure you're not shooting too close to the edge of the tube face? 70 width might be a bit much. DOes that green line shift, and can you still see it at say a 40 width?
Try shifting the phase to the right, you could be seeing image wraparound due to a misadjusted H phase (in the geometry menu)
front_range
| Posted: Wed Apr 16, 2008 11:03 pm Post subject: |
Damn! I knew it was something simple I'd seen before, I just couldn't remember what. It was folding back on itself, and horizonal phase cleared it right up. Thanks all, and thanks again Curt!
I finally have this set ready for a mount & final alignment. Wahoo!
