Epoxy sealed pot on Marquee neck card...
tse
Posted: Tue Apr 15, 2008 12:48 pm    Post subject: Epoxy sealed pot on Marquee neck card...
The sealed pot on the neck card sets the level of the OVER-I signal. The OVER-I signal is proportional to CRT beam current. It goes to the VIM bd where if it exceeds the threshold it causes the projector to shut down. There is another current sample type signal called I-SENS that comes from the neck card. It lowers the contrast setting of the projector when the current is too high, like a full white field. The I-SENS signal should do it's thing at a lower level than the OVER-I so high currents are controlled without shutting off the projector. The OVER-I circuit is there if the projector looses control of the beam current, like if something breaks and the contrast no longer has control.
There is nothing to be gained by messing with the pot. What you have to lose is controlled shut down in case of over current in a CRT if something causes full conduction or shutdown of the projector on bright scenes for no good reason.
Scott
Thomas Jefferson
zGman
Posted: Tue Apr 15, 2008 1:51 pm    Post subject: Marquee VNB
Hi Scott,
That is some good info - Thanks.
I have wondered if the beam current settings are the
difference between the 9" and 8" neckboards? And if
using the 8" neckboards on a 9" tube set would have
an appreciable difference on the overall light output?
Cheers,
Galen
Posted: Tue Apr 15, 2008 1:52 pm    Post subject:
Thanks for the clarification Scott.
Robert A. Hill
Posted: Mon Apr 21, 2008 3:07 am    Post subject:
Scott,
What provides the equivalent controls for the Ampro x600 series? Luckily, I have not seen a high beam current error, but others have posted about this issue.
tse
Posted: Mon Apr 21, 2008 12:37 pm    Post subject:
With the Ampro projectors a HV current sample is sent from the HVPS to the CPU card. If it goes too high the CPU shuts things down and displays the HIGH BEAM CURRENT message.
Scott
Thomas Jefferson
Posted: Mon Apr 21, 2008 10:17 pm    Post subject:
Scott
I resemble that remark
