NEC PG raster centering rings
Posted: Fri Apr 04, 2008 12:59 am    Post subject: NEC PG raster centering rings
I'm looking for a full set (three tubes) of centering rings from or like a PG for a experiment. Scott tried to magnetize some rings for me but it didn't take. I think I can do the same thing with a set of NEC rings. They must be the thin metal type and the tabs must be as straight as possible not bent at a 90 degree angle. Thanks,
Posted: Fri Apr 04, 2008 7:16 am    Post subject: Re: NEC PG raster centering rings
Does some e-home ecpīs has those kind of centering magnets? I remember that because that i had once some sd-187 tubes from ecp and those was with thin centering magnet rings. I dont know what model those was from.
Edit: http://www.curtpalme.com/ElectrohomeECP_Layout2.shtm
Seems that those are astig rings?
DVDO VP-50
New hobby, Rally
Posted: Fri Apr 04, 2008 7:40 am    Post subject:
Metal Chip?
PG rings are plastic. Flat plastic, but plastic.
Posted: Fri Apr 04, 2008 9:09 pm    Post subject:
Mark_A_W wrote:
Metal Chip?
You may be right. It has been years since I looked at the inside of my 9PG Plus but was sure they were metal. In any event, I still need a full set of the thin metal type if anyone has some.
kschmit2
Posted: Fri Apr 04, 2008 9:17 pm    Post subject:
PG plus uses metal tabs. Plain PG uses plastic.
I only have several sets of complete plain PG magnetics here Sad
Kai
jask
Posted: Sat Apr 05, 2008 3:01 am    Post subject:
both 6 plus that I have had used the grey plastic style.
now we all want to know what you are working on Question Question Smile
