Red Focus problem...
ruva
Posted: Tue Mar 25, 2008 2:21 pm    Post subject: Red Focus problem...
Hi guys,
first post here, but long time crt and digital user.
I got a little problem with my marquee 8500LC: it seems that optical focus on the red tube is impossible to get.
Green and Blue works well, but when its time to to the side focus all I get is:
- top left unfocused, bottom right focused (not perfectly, but acceptable)
- top left focused, bottom right unfocused (not perfectly, but acceptable)
A italian technician tells me that the lenses are not good for my machine, (HD10 GT17) but I have my doubts...
The screen has a base of 215cm (86 inches) with masking system; lens throw should be no problem, since the marquee is ceiling mounted on a sort or rails; so I can move it forward or back.
Anyone could give me a clue on how to operate ?
ciao,
ruva
Posted: Tue Mar 25, 2008 3:53 pm    Post subject:
Lets first make sure its not something wrong with the electronic focus for the red channel , When looking in the tube does the grid look nice and sharp on all sides, if no try to go into individual RGB focus from the service menu. try to get a nice sharp focus on the tube face when adjusting the red. if it wont focus on the tube face you might have a bad focus modual. if it does focus then go and retry the schlumfluge adjustments for the red tube. Just go through the entire help set up menu again.
Posted: Tue Mar 25, 2008 5:05 pm    Post subject:
The lenses are fine. Get another tech..Wink
I agree, check the tube focus by puttting on sunglasses, contrast at 95% and look at the image on the tube face. I'm sure it's fine, and that the problem is mechanical (Scheimpflug).
ruva
Posted: Tue Mar 25, 2008 6:18 pm    Post subject:
The lenses are fine. Get another tech.. :Wink:
and I am more than sure that you know him.... Laughing
but you'll never get his name from me ! Wink
ruva
Posted: Tue Mar 25, 2008 6:30 pm    Post subject:
it sounds like a mechanical focus issue to me. Is it possible one of the Pivot pins between the LC plates has fallen out? This would cause exactly the problem described. Read chapter 2
http://www.etechvideo.com/techtip7.htm#
JustGreg
Posted: Tue Mar 25, 2008 6:45 pm    Post subject:
Hi ruva,
First, welcome to the forum! Thumbs Up
I'm curious....did this problem just start for no reason or is it a result of 'tweeking'?...or did you just get the projector and are doing an initial install setup?
Greg
ruva
Posted: Tue Mar 25, 2008 7:41 pm    Post subject:
Hello Greg, thanks !
I believe we've "met" on AVSforum...
Well, this problem started after one and a half year of NON_USE; yes my firend, I went digital...I was attracted by the dark side of videoprojection...
I must say in my defense that the house where I lived, did not permit ANY possible crt installation...ceiling was at 5 meters and room was too small; but I admit my sin Embarassed
I also admit that this is my 5th crt's, after a couple of Sim2 and ECP. The dream is still the G90....like the one Curt is selling...
Curt, what do you think: a Sim2 420HD and a marquee 8500LC fully modded in exchange for the Sony ?!?! 8)
ruva
Posted: Tue Mar 25, 2008 10:40 pm    Post subject:
I was being a bit sarcastic about firing the tech, but I'm not sure why someone would have an issue with wel recognized top of the line lenses?
I forgot about the pin on the side of the tube, that's also possibly the problem.
Posted: Wed Mar 26, 2008 9:51 am    Post subject:
Oh man, I saw ruva and without my glasses it looked like cuva. Remember him?
Posted: Wed Mar 26, 2008 12:24 pm    Post subject:
Hahaha, me too. THat was my local nemesis..Wink I had to deal with him until he bounced a check on me, then I told him where to go. Last I heard, he'd sold a BArco 1208 for $6K to Toronto, but shipped a BArco 800 instead. THe customer called me, as his wife happened to work for the Toronto metro police..Wink.
I gave them his contact info, and I believe he 'solved' the problem by sending the guy a slightly used DLP..Sad
BTW, the above story is about 'Kuva' who used to hang at avs years ago, not ruva, just to be clear....
ruva
Posted: Tue Apr 08, 2008 2:40 pm    Post subject:
Update:
looking through the lens I see a perfect focused grid.
Tried to adjust Scheimpflug but I cannot get a balanced right/left focus. ...I made the situation even worse, let me explain:
my machine is a 8500LC, which should have the lens mounting of a 9000: so on the right of the attached picture I should have left/right focus, on the left top/bottom.
Now I turn CCW the side bolt, then turn CW the top bolt but no improvement. Then I try the opposite...but nothig happen.
Could someone please explain me how the two left-right focus bolts works ?
What could be the problem (apart the pivot pin that draganm told me ) ?
thanks,
ruva
 Filename:  RED.jpg
 Filesize:  477.25 KB
 Downloaded:  387 Time(s)
Posted: Wed Apr 09, 2008 10:39 am    Post subject:
Before you go any further, locate and download the owners/installation manual. It will explain the (lens) focus adjustments. Pointing and focussing the lenses is in my opinion the hardest thing for a first time crt'er to do. The theory behind variable lens flapping is the same whatever projector you have. Only the screws that do it differ. I seem to recall some meathead starting a thread entitled "Holy focus Guy Kuo" that explains lens focus in great detail. For the life of me I can't remember who that meathead was but the thread is a stickie here or at AVS. Wink
ruva
Posted: Wed Apr 09, 2008 10:46 am    Post subject:
Chip,
I know what you're talking about, and I've set up in the past ECP and Sim2 CRT...
This time turnig clockwise or counter-clockwise the two bolts give me no improvement on the left right focus..that's it.
Gotta go through the entire setup from scratch again....
Chuchuf
Posted: Wed Apr 09, 2008 1:07 pm    Post subject:
HD10 GT17's on a 86" wide screen?? Seems like he should be running HD10L's for that width. The GT17's are for a wider screen.
Terry
nuttall_chris
Posted: Wed Apr 09, 2008 1:16 pm    Post subject:
Terry
Remember that this is an 8500LC not a 9500LC. I used GT17 lenses on my 8500LC on an 86" wide screen and the focuse was perfect corner to corner.
If you look in the Marquee manual it lists screen sizes of 78-90" with the GT17 lenses. With the HD10L it only lists a 54" screen size.
Chris.
Ile
Posted: Wed Apr 09, 2008 1:31 pm    Post subject:
Terry
Not so wide with 8" tubes, 86" is in the middle of given 75"-94" screen width for GT17.
10L are only for 45"-58" for width according to M8500LC manual.
http://www.curtpalme.com/docs/ElectrohomeMarqueeUltra8500_8500LC_9500LC_User.pdf
page 87
Edit. too slow.
Posted: Wed Apr 09, 2008 2:14 pm    Post subject:
Ile your wrong on the hd10 gt17's EDIT oops meant HD10L's here is the spec sheet:
And for the HD10l can go a bit wider than 58inches I believe they can go up to around 80inches look for the evrything about lens's thread.
found the thread:
https://www.curtpalme.com/forum_archived/viewtopic.php@t=2761.html
10L-GT-17-GT26 lenses.doc
 Filename:  10L-GT-17-GT26 lenses.doc
 Filesize:  34 KB
 Downloaded:  338 Time(s)
nuttall_chris
Posted: Wed Apr 09, 2008 2:27 pm    Post subject:
Ile your wrong on the hd10 gt17's here is the spec sheet:
Check your data before you say someone is wrong. The spec sheet you attached is for the Marquee 9000, not the 8500LC. As the 8500LC uses 8" tubes the screen sizes are reduced.
FWIW - I sold my 8500LC with a set of HD10L lenses to Barry (Joust) and it throws an acceptably sharp 96" wide image with the 10L lenses. Not as sharp as the GT17 lenses but acceptable.
Chris.
Posted: Wed Apr 09, 2008 2:38 pm    Post subject:
Chris does the tube size matter? The lens doesnt caer what size the tube face is does it?. A certain lens should have the same specs no matter what the tube face size is correct? If I am wrong i need to understand why. does that 1 inch make the difference?
Help me out!! Wink
Edit I ment to say he was wrong on the HD10L's my bad !!! Sorry
Posted: Wed Apr 09, 2008 2:44 pm    Post subject:
here is a document from 3M on the delta lenses it makes no mention of tube size to be used on therefor i think it shouldnt matter what the screen width would be... however throw distance will be different possibly
EDIT Just saw the tube size mentioned but its a 7''??? weird these are used on 8" and 9" whats up with that?
The HD10 family of lenses has been designed to maximize performance and
versatility for professional CRT projection video, data and graphics applications.
All HD10 family lenses are optically coupled and designed to cover a full 178mm
(7”) raster diagonal. They are all fully color corrected hybrid designs,
incorporating both plastic and glass elements and share the same C-element and
mounting geometry, making it possible to interchange the lenses on the same
projector. The following is a brief description of lenses in the HD10 family.
HD10E – The HD10E covers 167mm focal length (7”) CRT raster diagonal. It
was designed to provide good performance over the largest possible
magnification range (14-45X). For this reason, CPL recommends the HD10E
lens for applications where the intended screen size requirements may vary over
this wide range (90” – 300” diagonal).
HD10L – The HD10L is designed for optimized performance for smaller screen
sizes not covered by other HD10 family lenses. This lens provides excellent
performance for a specific magnification range (9-13X).CPL recommends the
HD10L lens for applications requiring screen sizes of 60-90” diagonal.
HD10GT17 – The HD10GT17 is designed for improved resolution over the HD10
lens over a specific magnification range. This lens provides excellent
performance for magnifications of 14-20X. CPL recommends the HD10GT17
lens for applications requiring screen sizes of 100-140” diagonal.
HD10GT26 – The HD10GT26 lens is designed for improved resolution over the
HD10E lens for magnifications of 21-30X. CPL recommends the HD10GT26 for
applications requiring screen sizes of 150-200” diagonal.
HD10GT30-67 – The HD10GT30-67 is designed for improved resolution over the
HD10E for magnifications of 30-45X and to extend the range of the family up to
67X. CPL recommends the HD10GT30-67 for high magnification applications
requiring screen diagonals of 210-460”.
