Sony G70 no 1080P
vorlon
Posted: Sun Mar 16, 2008 1:34 am    Post subject: Sony G70 no 1080P
Hi
I have a Sony G70 and i connected a Toshiba 1080P HD DVD player to it but got no picture through HDMI or Component yet when I connected it to my 86cm CRT TV through Component i got a fantastic picture even though the TV is only 1080i capable.
Now that i could see the players menu i turned it down to 1080i connected it back to the G70 and got a picture, why only 1080i, I have had an Helios upscaling dvd player connected through hdmi @ 1080P before.
Thanks.
Posted: Sun Mar 16, 2008 2:55 am    Post subject:
How are you feeding the HDMI into the G70? Moome card?
vorlon
Posted: Sun Mar 16, 2008 4:38 am    Post subject:
HD Fury
Posted: Sun Mar 16, 2008 5:07 am    Post subject:
vorlon wrote:
HD Fury
Do you have the HD Fury power supply. Lot's of people have reported the need for the 5 volt power supply to reach 1080P.
vorlon
Posted: Sun Mar 16, 2008 5:42 am    Post subject:
Hi
I havent got the power supply.
I would like to try one to see if it does make a differance.
Do you know of a brand i could buy locally that meets the Fury requirements?
Posted: Sun Mar 16, 2008 7:07 am    Post subject:
The requirement's are listed in the FAQ's here: https://www.curtpalme.com/forum_archived/viewtopic.php@t=5282.html
HD FURY FAQ's wrote:
The DC jack on the side of the HDfury must follow all these requirements:
- Provide REGULATED (+/- 5%) 5VDC power with 0.5A max DC current
- Deliver the power through a small 0.65mm diameter center pin / 2.6mm outer diameter DC plug (like the one often used in cellular phone AC adaptor)
- Provide the correct polarity with 'plus' on the OUTER part of the plug and 'minus' (ground) on the small center pin of the DC jack.
Trying to use an AC/DC adaptor that doesn't follow all these three requirements may destroy the HDFury. This external HDFury powering option is only needed in one or both the following situations:
- The DVI or HDMI cable is using thin gauge copper wires and its length exceeds 5 meters (16 feet).
- The DVI or HDMI source is unable to deliver the 0.5A maximum current over its HDMI or DVI pin #14. This situation often occurs when HDFury is used with cheap DVD/HD players at 1080p60 mode.
vorlon
Posted: Sun Mar 16, 2008 9:09 am    Post subject:
Thanks, but has anyone downunder, (Australia) found a power supply with these specs.
Posted: Sun Mar 16, 2008 6:21 pm    Post subject:
Check out iPod power supplies, the ones that have the USB power jack on them. Then you'd have to make a power cable with the correct polarity. From what I remember the plug is the same power plug that Nokia uses on their cell phones, WRONG POLARITY and VOLTAGE though, but you may be able to use the cord and get a USB cable and make something up.
oliverg
Posted: Sun Mar 16, 2008 8:20 pm    Post subject:
Any bulk standard power supply that does 5v, has the correct polarity and can supply the m/amps is fine.
In Australia: Dick Smith
Or just use a USB cable 5v power adapter.
Posted: Sun Mar 16, 2008 8:41 pm    Post subject:
I wasn't aware that 1080P could run on a G70. Is this 1920x1080P?
vorlon
Posted: Mon Mar 17, 2008 12:48 pm    Post subject:
I have run 1080P before using an Upscaling DVD player connected through the HDMI and get a picture no problems, yet I get a black screen with a HD DVD player.
I do get a picture with 1080i.
I upgraded the Toshiba firmware to 2.8 and I now get the option of 1080P 24 as well as just 1080P, Still no picture.
What does the new option for 1080P 24 mean compared to just 1080P?
Posted: Mon Mar 17, 2008 2:26 pm    Post subject:
Yes
I've run 1080p 60 and 1080p 72 on my G70, right now I'm running 1920x800p 60
Person99
Posted: Mon Mar 17, 2008 5:07 pm    Post subject:
1080p/24 means it is output at 24 Hz (the frame rate movies are created at). A CRT will not sync to or display 24 Hz. If you want a multiple of 24, you need to feed the 1080p/24 to a scaler.
Posted: Tue Mar 18, 2008 9:17 am    Post subject:
Yes
I guess that's one-up on the XG1351LC.
vorlon
Posted: Tue Mar 18, 2008 10:06 am    Post subject:
OK I have fixed the problem.
As I said before I had no problems playing and Upscaled DVD @ 1080P 60 or 50 using the hdmi to fury with a cheap chinese player thats why i could not understand why i could not get an expensive Toshiba HD-DVD player to work @ 1080P.
I bought a power supply locally and connected it up to the HD Fury and all i got was a black screen but I took a chance and bought another power supply of a different make and now it works.
Thanks all
Posted: Tue Mar 18, 2008 1:43 pm    Post subject:
What was the difference between the two power supplies? Were they the same specs?
vorlon
Posted: Tue Mar 18, 2008 2:14 pm    Post subject:
They are both selectable volt power supplies the first one had a choice of 4.5v, 7.0 ect yet when i checked it with a multimeter the 4.5 gave out 5.5v, the other had a choice of 5v ect. and it checked out at 5v so this must have been the problem.
69shelby
Posted: Tue Mar 18, 2008 2:36 pm    Post subject:
how does 1080p compare to 1080i ?
MYoung
Posted: Tue Mar 18, 2008 8:23 pm    Post subject:
The same way 480p compares to 480i.
MYoung
Posted: Tue Mar 18, 2008 8:29 pm    Post subject:
Perhaps run != fully resolve?
My 1271Q runs 1080p. Thumbs Up
