Goto page Previous  1, 2, 3 ... 35, 36, 37 ... 62, 63, 64  Next
mcpherv
Posted: Mon Jan 31, 2011 4:55 am    Post subject:
Hey, I ended up using one of the Vishay DG611/612/613 series to replace the sd401. Took some jerry-rigging into place, but it worked flawlessly. Not too sure how much difference it really made to be honest, but it DOES work - just need to replace it with the appropriate variant (can't remember if a normally open or normally closed configuration is required of the switch). High voltage video pathway section of the neckboards are really the limiting area in terms of bandwidth... and its hard to do much about that. The rest of the path can be improved though, and does make a nice improvement.
Glad to see people are still pursuing this.
Posted: Mon Jan 31, 2011 4:58 am    Post subject:
I have three of those chips in house, never got around to doing the mod.
1031
Posted: Mon Jan 31, 2011 7:04 am    Post subject:
I have also used dg612 in place of sd5401 for some time now.. I never got it working 100% perfect, so iīm about to test Mikes "mini board" that replaces video section of that sd5401..
But someone who likes to test dg612.. Here is how i did that mod
Most problems what i had with that dg612 board was related to onscreens.
 Filesize:  22.72 KB
 Viewed:  10139 Time(s)
 Filesize:  36.97 KB
DVDO VP-50
New hobby, Rally
Posted: Mon Jan 31, 2011 7:15 am    Post subject:
I found some more pictures about that mod.
Here is risetime compair between sd5401 and dg612.
At some point when i tested that mod, i was able to get really good sharpness out of it (picture is from my testbench ,M8000 with hd-8īs) But when i tested that vim with my main projector, picture was useless, sharp yes, but too noisy Neutral
 Filesize:  10.15 KB
 Viewed:  10131 Time(s)
 Filesize:  43.53 KB
 Filesize:  40.08 KB
DVDO VP-50
New hobby, Rally
dvh99
Posted: Mon Jan 31, 2011 8:13 am    Post subject:
i have some different inductor values now to play with and some varicaps so i can undo the limiting factor on the neckboards.
i will report later in another thread.
hope to get this done this week, will try the different inductors on green first.
mcpherv
Posted: Mon Jan 31, 2011 11:58 am    Post subject:
Can't wait to see the results on that one... My impression from a few years back was that the bandwidth of the large transistors, along with the capacitance of the circuit was the major limiting factor. However, the inductors do affect the shape of the waveform, and at the time, I thought you could maybe somewhat compensate for the rounding of the waveform as it passes through the neckboards by exaggerating the edge of the waveform perform it goes into the high voltage circuit (ie. ringing...).
mcpherv
Posted: Mon Jan 31, 2011 12:02 pm    Post subject:
Thats honestly a more elegant solution than I ever did - I ended up using wiring to hook up the chip upside down overtop of the sd5401. I think I only ever switched out the primary video path part of the switch and left the other parts in place if I remember right. I got something comparable in terms of sharpness outcome. Also, never had a scope to look at the waveform, but after all my mods, there wasn't a lot of obvious noise anymore that I could see by looking into the tube faces on a still screen or on the windows desktop, etc.
Posted: Mon Jan 31, 2011 12:51 pm    Post subject:
I probably would have done that mod as you say McPherve. Its possible the board itself is picking up noise , but since you have not scoped it its hard to say if your had the noise as well.
The peaking circuit on the vim that Scott at VDC is something you should see. it brings the pre amp up to about 240 mhz pixel clock.
mcpherv
Posted: Mon Jan 31, 2011 11:39 pm    Post subject:
Your point is well taken, and I agree regarding the no scope issue.
Hey - got a link for the peaking circuit? I found the following thread which shows the schematic for some new gen neck boards, which has a peaking circuit in the feedback loop for the video signal opamp:
http://www.avsforum.com/avs-vb/showthread.php?t=1127826
Peaking is important, I think, for exactly what TSE mentioned in that thread - to overdrive the transistors in the latter stages of the video path at high frequencies (ie. the third order harmonic of the video signal which makes up the sqaured edge of the square waveform). The signal attenuation should reduce a lot of the ringing of the waveform in the earlier stages down, but you end up with a closer-to-square wave at the tube itself, which is obviously desireable. Obviously, the tradeoff is that this is variable at different frequencies, and could add artifact at lower frequencies. Note, this attentuation would also be happening to high frequency noise introduced into the video path at the preamp stage... Just sayin (re: tradeoff/benefit of the switch replacement - faster rise time, some noise on scope).
Also, a couple years after I stopped doing all of this, I found this new analog multiplier:
http://www.analog.com/static/imported-files/data_sheets/ADL5391.pdf
Would be a PAIN to install into the circuit due to its form factor (although an adapter board would work - seems like some around here are into custom pcbs), which is a 3mm x 3mm size, but if you could get it to work, one of the main bandwidth limitations on the preamp section of the video path would be eliminated. Also as is mentioned in that thread, OPA695s rock. And multiple parallel caps for decoupling are good too...
Posted: Tue Feb 01, 2011 12:23 am    Post subject:
McPherve, here is the thread where we talk about the Peaking circuit. Scot posts some Spice models of the circuit.
Your right about the resolutions being specific. This circuit is now good for anyone who wants to use say 1080p and 720p. You have to tune it in for the res your going to mostly use.
I have a blend set up so i have all inputs scaled to the same res.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=15194.html
mcpherv
Posted: Thu Feb 03, 2011 4:13 pm    Post subject:
Impressive result there! Dramatic difference pre/post peaking circuit. Still could definitely be done with another amp with a higher slew rate, resulting in a shorter rise time, but that is a pretty good result!
mcpherv
Posted: Thu Feb 03, 2011 4:21 pm    Post subject:
Hey, are these the inductors at positions ~L1-L7 on the neckboards in the high voltage section? If remember right, there is a paper describing the mirror cascode amplifier that talks about inductor at these positions being used to introduce peaking into the signal to compensate for signal bandwidth limitations. Playing around with these values may allow you to improve the bandwidth of the end stages of the amp circuit for some frequencies (with the same previous caveats being that it'll introduce artifact into lower frequencies).
Revox
Posted: Thu Feb 03, 2011 4:30 pm    Post subject:
That is very interesting! Seems for me like for one resolution the mod can be a bigger improvement than a few other mods.
I learn for my control engineering exam in the moment, and that is realy a good transfair of this knowledge!
The problem of this big thread is, that you can only can guess what to mod if you read carfully throught the whole post.
So is it possible for you collect a few info?
To snapshot the part in the schematics of this VIM (might be possible for all VIMs or only one special?).
It would be very nice to, if you can add the mod parts via mspaint (but this is only if you have the time!).
Greetings from Berlin, Stefan
dvh99
Posted: Thu Feb 03, 2011 5:05 pm    Post subject:
mcpherv, scott explained a bit about this in another thread.
https://www.curtpalme.com/forum_archived/viewtopic.php@t=24037.html
i haven`t played with it sorry Sad.
the muratas have high q at 100mhz so i expect much of them.
mcpherv
Posted: Thu Feb 03, 2011 5:50 pm    Post subject:
Here's the patent for the mirror cascode amplifier used by the neckboards as the high voltage amp stage - describes the circuit in detail.
Mirror cascode amp patent.pdf
 Filename:  Mirror cascode amp patent.pdf
 Filesize:  202.37 KB
 Downloaded:  279 Time(s)
dvh99
Posted: Thu Feb 03, 2011 5:55 pm    Post subject:
hey thanks for that Thumbs Up
Posted: Thu Feb 03, 2011 6:02 pm    Post subject:
Here is the idea for adding a peaking circuit to the VNB's along with his notes on changing the Inductor values like McPherve just mentioned.
tse wrote:
The Mot parts are definately the best for this application (the parts on the neck card have the same characteristics as the ones attached other than increased power dissipation because of the package that allows attachment to heatsink).
Sanyo made a line of video output type transistors that could be used for higher bandwidth amps but at lower voltage than needed for the projector CRTs (ok for monitors).
There are a couple of Sanyo parts with the voltage needed but required more overdriving at the limits of bandwidth to match the Mot parts.
I believe that technique could be applied to the Mot type neck cards to get increased bandwidth over standard cards. Peaking network like C68 and R101 could be added to a better opamp. L1, L2, L3, and L7 should be lower value (to resonate at higher frequency). Probably, R84 and R85 should go away. R16 and R24 values would have to be optimized. L4, L5, and L6 might have to be slightly different value.
If attempting this I would recommend first replacing the inductors with 0 ohm jumpers and setting the peaking network for quickest rise and fall times at amplifier output. Then place the inductor values to get the shortest rise and fall times.
When I did this for the new VDC neck card I used 400MHz scope, 500MHz probes (that were close to the CRT capacitance), and pulse generator with rise/fall time less than 1ns.
Scott
I do have some of those New style Neck boards I plan to populate some day, if I ever get time... Sad
But the Bold text is very important, interesting idea of using jumpers to set the quickness of the rise time then later playing with inductors to find distance of the rise time. If I understand what Scott was trying to say here.
mcpherv
Posted: Thu Feb 03, 2011 6:55 pm    Post subject:
So another member of the original mods thread played around with this with a scope a number of years ago - the rise time adjustment can cause overshoot of the signal, which is what I meant by "ringing". At the time when I was talking with them about this, we were discussing the merits of exaggerating this overshoot to improve the shape of the waveform as it goes through the latter stages of the amp.
Oh, also - there may have been another document on the mirror cascode, but I can't seem to find it right now.
dvh99
Posted: Thu Feb 03, 2011 9:59 pm    Post subject:
that member is the designer of the neckboards, the godfather of the marquee on this forum. Mr. Green
scott i hope its ok with you i called you the godfather, if not please dont put concrete shoes on me and dump me in the ocean.
Posted: Thu Feb 03, 2011 10:04 pm    Post subject:
Actually the member he was talking about was Bill Blue I do believe. Bill was very outspoken in the original threads and got lots of heat for it from other marquee members. Also Chis Stevens was poking is head in and out of those old threads but he was bound to secrecy for much of what he came up with. He still has some ideas floating around form an e-mail i got form him a couple months ago. His Accurate Imaging machines were special. But those wet tantalums he used all over the place are expensive!!!!!!
Page 36 of 64
