Goto page Previous  1, 2, 3 ... 33, 34, 35 ... 62, 63, 64  Next
Posted: Mon Nov 15, 2010 4:18 pm    Post subject:
Right Drags, I was just looking at decoupling caps and I'll say it again, I really wish they Made SMD OsCons in smaller case sizes. I was thinking of stacking SMD Film chips as decouplers and then adding a larger size SMD oscon on top since now the other chips will raise the hight up off the board and possible clear any SMD IC's that might be too close together.
But with the EL5166 use a 4.7 uF decopiling cap and then try a 47uf OS CON radial cap across the pins of the amp.
Posted: Mon Nov 15, 2010 8:20 pm    Post subject:
don't mean to argumentative but i'm not a fan of stacking caps. My concern here is Oscillation by running so many different caps in parallel. My understand from the reading i've done is that by running them in parallel you get a generally flatter impedance curve over the time domain. However the problem I see from the research i've done is that the sharp response curve of MLCC's still leaves lump and bumps in the impedance curve. These deviations from constant impedance manifest themselves as Oscillations in the time domain.
OR, to put it in simpler terms your filtering is lumpy Laughing I don't need to to explain why Oscialltions are bad for the Op amp.
The other thing that bothers me about this it's so old school. I mean running all those caps in parallel is what they've been doing now since the invention of the micro-processor. It doesn't use any of the newer wideband cap technology out there now.
For instance, the plain-jane 470nf 50V MLCC used to de-couple the main chips in the VIM, C33,49,65. they now offer MLCC's with 3 node capacitive circuits with the 3rd node being a balanced reference to ground.
page 4
http://www.johansondielectrics.com/images/stories/surface-mount/x2y/JDI_X2Y_2010-06.pdf
not only that, but the design offers extremely low ESL which is important (if you want I have a Murata paper on the importance of low ESL in filtering).
This is just one example and doesn't even get int to the new low ESR / low ESL Tantalum Polymer caps. These are now offering very low ESL and low constant impedance up to about 10Mhz at which point it could hand off to the new MLCC. Maybe use 2 modern caps instead of 6 old ones?
So how about we try and come up with a new and unique filtering solution for the primary RGB opamps using technology from this Century, Wink Who's up for it. Thumbs Up
Posted: Mon Nov 15, 2010 8:55 pm    Post subject:
Drags, were you hacking my computer last night?
I was looking into EMI filters , here is an excellent paper on it.
http://www.syfer.com/category_docs/sm_filter_article.pdf
It explains what you were talking about and some other things.
I agree that with certain caps stacking can be detrimental. This is why I like Oscons, super low ESr and ESL as frequency increases.
The key is to do as MP does use caps and inductors to smooth out the filtering so you do not have the Lumps or Bumps.
But with the right combination of stacked caps you can avoid those bumps. This is why I think and others are doing this as well is to use
1nf,10nf,100nf, 1uf and a larger cap across the +/- pins for those times you need power overhear requirements.
The reason I like Oscons is, on the newest version of the CCM it has that really bad vertical band issue. I tried the stacking method and adding larger caps across the +/- pins of the associated chips and added inductors in line of the signal, it worked but also altered the wave form a bit. Only when I added a 100uf 20 volt Sanyo Oscon did all those bars go away. Also it improved even more when i removed the other smaller caps i added parallel to the 100nf caps there.
But i still think the EMI SMD chips might be the ticket here.
there are some other good papers on that site about filtering, especially one where they add those chips between the pins on connectors, like the ones on the Vim and CLm etc.
tse
Posted: Tue Nov 16, 2010 1:08 am    Post subject:
You can get an idea of what different caps do by looking at a simple Spice program from Kemet. It can show the combined impedance of paralled caps. Low ESR up to 1000MHz is important for the opamps with the very high bandwidth.
http://www.kemet.com/kemet/web/homepage/kechome.nsf/weben/kemsoft
Scott
Thomas Jefferson
Posted: Tue Nov 16, 2010 1:19 am    Post subject:
Scott I have a question for you. Why did electrohome choose not to use Voltage regulators on the boards them selves Like the NEC's do? have been looking at the Super regulators made by Belleson and others and they seem like much cleaner power sources.
It would have been nice to be able to just replace the on board regulators with these super regulators.
Bob Stephan is going that route with His Xg's and is having the owner of Belleson make special one to handle the highr frequencies a PJ uses.
http://www.belleson.com/
tse
Posted: Tue Nov 16, 2010 2:19 am    Post subject:
All the functions in a Marquee can be adjusted with the CLM, there are no pots on any board for calibration. I'm sure alot of work went into that. It did not matter too much if the +15V rail was a little different voltage from one projector to another so not important to design in regulators. One thing that happens when someone thinks something is not right with the projector is they get in there and start tweeking around on the pots. That was a major problem that Ampro had. Electrohome was smart and eliminated that. Plus it saved a few bucks to not have regulators on every board.
The circuits in a design depend on stable rails to some degree. Usually you depend on the decoupling caps to make up for any delay in response from a voltage regulator. Hopefully a millivolt or two doesn't upset your circuit too much.
Scott
Thomas Jefferson
Boilermaker
Posted: Tue Nov 16, 2010 2:03 pm    Post subject:
While I don't have a Marquee, I have followed this thread (and others that are similar) and really enjoyed watching the effort put forward by Drags, Nashou, Scott, MP and others to squeeze every last bit of performance that is possible from these projectors. It reminds me of doing the same thing to audio equipment many years ago and it was fun!
Scott, while I can see the great importance of decoupling caps, I still feel that even greater performance can be obtained with improvements to the voltage regulation at critical points.
Please correct me if this doesn't make any sense, but if the final regulation is quite a distance from the active circuitry it is supplying (wiring harnesses, circuit board traces, connectors, etc.), does this not add to the effective output impedance of the regulator and thereby lowering the overall performance? I realize the decoupling caps job is to make up for this, but what is your thoughts on this.
Also, while I have you, I have some concern over the widespread use of series inductors to filter noise. Especially given the high frequencies of video we are using, does this not also add further impedance that the load sees from the supply? Besides the resistive component, shouldn't the Ldi/dt portion be of concern? Or do you think that this is just "overkill"?
I recall back in the 1970's (yes, as Curt says - I am an old fart) when I was playing with audio, the difference in the conventional 3 - pin regulators and the "super-regulator" circuits that were being developed, was substantial. The noise rejection, stability, and output impedance were all vastly improved. My guess is that if it was noticable in relatively low frequency audio circuits, it should also be noticable at video frequencies. Do you agree?
Thanks, and keep up the interesting posts!
Bob
Posted: Tue Nov 16, 2010 9:08 pm    Post subject:
No, but I spent the night at a holiday Inn . Wink I'll check out that paper, got lots of them to read but get a headache after more than an hour of reading that stuff so i have to chew slowly. Laughing
I agree that with certain caps stacking can be detrimental. But with the right combination of stacked caps you can avoid those bumps. This is why I think and others are doing this as well is to use
According to some of what Ive read so far it's just not possible to stack caps and get a smooth impedance curve? I don't know, just started looking into this.
Scott
Scott as always much appreciated. i'll giver it a try and hopefully it's not a mind-bender to use. I have trouble with complex software.
Posted: Tue Nov 16, 2010 9:11 pm    Post subject:
I agree, i tried using TI's spice program and got lost Sad
tse
Posted: Wed Nov 17, 2010 1:21 am    Post subject:
Bob
I believe in local regulators. Look at the Ampro boards. Every one has regulators for the low current control sections. The Ampro LVPS wasn't designed to regulate every rail like the Marquee LVPS is. Standard regulators do a pretty good job when used in circuits that are drawing small currents like less than a few hundred milliamps. A little cap on the output and quick current changes cause very little change in voltage. Now, if the circuit has current changes of a couple of amps in usec time periods a high performance regulator is probably better than thousands of microfarads of decoupling caps.
Series inductors sometimes are required. They can do a great job of keeping high frequency garbage in one place instead of getting everywhere via the rail traces and wires. The DC resistance doesn't help with low frequency regulation, though. You can't ignore the self resonant frequency (SRF) of the inductor as past that frequency the inductor essentually becomes a capacitor and passes all the high frequency stuff right on through.
So, like everything, it depends on the circuit.
Scott
Thomas Jefferson
Boilermaker
Posted: Wed Nov 17, 2010 10:37 am    Post subject:
Scott, thanks for the reply.
I had forgotten about the series capacitance effect of coils.
I have had a couple of conversations with Nash about the possible use of super-regulators as a direct replacement and what possible gains (if any) might be achieved. As a test platform, we have decided to use the Moome input card. Evidently, the input card picks off its power from the +5 volt rail on the Marquee. Nash is looking at the possibility of temporarily feeding it from the +15 volt rail and using a Belleson +5 volt regulator to serve the DAC. It appears that there is already a place on the Moome board for a 3-terminal regulator that appears to be jumpered. Or perhaps he could just use a wall-wart.
He could then easily measure any difference in output from the DAC when feeding a 1080P@72 test signal and also "see" any difference in noise at the 5 volt input to the DAC. It should be interesting!
Bob
Posted: Tue Nov 30, 2010 4:29 am    Post subject:
Well I have not taken a look at the LVPS in the 2004 longbows yet. I was going to do some work on them with a few ides I had but may not now after looking at it.
Here are some pics, its a 2001 printed PCB. A few interesting things about these PS's.
1) The Filament add on PCB to fix the over voltage is now part of the main PCB.
2) Near one of the LM353N DC op Amps they added a 10uf cap and diode over a resistor. Not sure what its for.
3) They used much better caps all over. Nippon KME and a few Panasonic's in the 85 volt section, as well as Dragans fav Nichicons
in other places. and a few Jamicons.
The large red Wima cap is gone replaced by a smaller in size black film cap, not sure the brand.
Here are some pics, pay note to the Filament section and the added cap diode combo.
dvh99
Posted: Tue Nov 30, 2010 7:51 am    Post subject:
i will add a little something, i replaced the diodes on the conv and vdm board.
when adjusting convergence the line now goes smoothly without any "hiccups" that most have seen while adjusting the conv.
the end of the lines from the raster dont show those funny ends anymore.
had those diodes lying here a while but i finally put them in, the conv is off a bit so it needs to be converged after replacing the diodes.
Posted: Tue Nov 30, 2010 5:02 pm    Post subject:
I also noticed a much smoother movement of the grids.
What do you mean by "funny ends" ?
Posted: Thu Dec 02, 2010 5:07 am    Post subject: BLACK GATE"S TO HEAVEN !!
Well I wasn't going to change out the caps with some caps I had planed on using for the older Marquee's I had before I got the 2004 Ultra's.
I know many do not believe in boutique caps but I am one who has to try things out before I toss the thought out the window.
So i put in all the largest caps in the LVPS and upped the 85 volt rail from the 33uf to 100uf 160 volt and one 47uf 160 volt.
I wanted all 100uf but could not find anymore of these caps so the two in series
are the 100uf's.
Why could i not find them? Because they are no longer made..... Yes they are the famous Black Gate caps.
Man are some of these large compared to new caps. From researching these I guess they are larger due to materials
used and manufacturing to get the special characteristics.
There were some add's from the original Black Gate makers before Rubycon took over the production
where they used them in Televisions. So i figured I try them in the power supply.
Also Walter has done his Zenith 1200 years ago and kinda inspired me to try them.
Before and after. Notice how large some caps are compared to the replaced caps.
I still have the smaller caps to change out.
I only have done a small run in period on my test bed and no source but looking at the internal
Greyscale pattern looking for background noise I always see in the marquee.
There is a reduction compared to my other Ultra in the theater, not sure if its the
Black Gate's or just the increase in uf's on the 85 volt rail.
I guess I wont really know till I finish it up let the caps settle after about 50 hours or so and then compare
with video material.
I also have some Soft recover rectifiers I want to also replace. that will come at a later time after
i first try them in an older LVPS before I put them into the Black Gate Power supply.
Yeah I know I'm crazy or just bored. Wink
1031
Posted: Thu Dec 02, 2010 7:24 am    Post subject:
Hey.. thats quite expensive bunch of caps that you have Shocked Anyway, iīm interested to hear, if you notice differences whit those blackgates.
DVDO VP-50
New hobby, Rally
Posted: Thu Dec 02, 2010 9:15 am    Post subject: Re: BLACK GATE"S TO HEAVEN !!
Why not do a scoped before and after to show what/if there's a difference with the new caps?
And without doing the scoped for the 85 volt rail, I will agree with you that changing caps on that rail could make a substantial difference in the image. The caps on the 85 volt rail is THE most likely caps to get a little weak or need changing because they either still have 85 temp caps still in it. Or some of them have been upgraded from version changes, but the three right at the rail will still be 85 temp caps.
There are 6 electrolytics in the LVPS 85 volt rails secondary supply. Three of them should be 105 temp caps, which are C64, C55 and C56. The other three C60, C61 and C67 are most likely 85 temp caps.
An 85 temp cap on any of these secondary rails is most likely weak. Not from age or leaking, but from the the pulses and switching that goes on. An 85 temp cap should never be used on the secondary of a switching supply.
Concerning the other caps in there. If you find one weak or leaking let me know. I've been looking into these supplies for at least ten years. And have only found cap problems on the 85 volt rails.
On some of the other rails, increasing the capacitance a little or maybe going with a better cap could possibly make things better for the other boards operations, like vertical, horizontal, etc. But from my experience, they will have very little effect on lowering noise.
The three key noise areas in the Marquee where cap upgrades has shown an improvement in the image is those three 100uf cap in the LVPS 85 volt rail. The second is the 22uf caps on the 85 volt rail on the neck boards, they too are 85 temp caps. The only other cap or section of the projector is the tants on the control board. The RF on that board weakens them over time, and changing them out will clear up noise in the video chain.
So, if you could show some before and after scoped reading of the LVPS, that would be great. And it would also allow me to see what a difference scientifically those caps could make in those circuits.
Posted: Thu Dec 02, 2010 10:10 am    Post subject:
It's my experiance that most of the Marquee noise is coming from the people who work on them Laughing
Posted: Thu Dec 02, 2010 10:53 am    Post subject:
Hmm, i hear more noise coming from ampro owner who likes to visit all threads that are related to Marquee Mr. Green
BTW Stefuel i found cool Ampro for you ->
http://www.google.fi/imgres?imgurl=http://www.agassiztrading.com/photos/photos-camerasfilm/photos-projectors/16mm/ampro-imperial-1.jpg&imgrefurl=http://www.agassiztrading.com/cameras-film/projectors/16mm-projectors/ampro-imperial.htm&usg=__7RYrOf35AjtV3JoWEbo1jqAOxxs=&h=620&w=400&sz=50&hl=fi&start=11&zoom=1&um=1&itbs=1&tbnid=CgbFEnaLfefFeM:&tbnh=136&tbnw=88&prev=/images%3Fq%3Dampro%26um%3D1%26hl%3Dfi%26client%3Dfirefox-a%26sa%3DN%26rls%3Dorg.mozilla:fi:official%26tbs%3Disch:1
DVDO VP-50
New hobby, Rally
Posted: Thu Dec 02, 2010 11:02 am    Post subject:
well one thing about the Black Gates I do not like is they only come in 85c temp. But from what i have read about them is
if they are used in fairly low temp areas they are fine. also they handle SMPS better than other 85c caps. That is one reason
i did not use them on the VNB's as it gets really hot with high resolutions. On those I used panasonic 100uf caps i think the EU series.
The 33uf caps replaced were panasonic 105c. So we'll see.
I always have a hard time scoping the power rails. i never seem to find anything. looking for anomalies on other wave forms
like focus and astig etc is easier to see.
Bob Stephan gave me some pointers, to lower the volts div way down and then use the AC couple selection on that V/D control.
I'll measure it from the MB harness is, if/When i do it. Might be some time from now. I'm getting some test
Super regulators Bob wants me to test for the 5 volt rails on the VIM.
Lots of experiments and little time and ambition as of late. Geeze it took me close to a year to try the Black Gates Wink
And the Places i got them from are all sold out. A year ago when i was ordering them I bought the last of some of the Values from 3 different places.
Jarmo over all cost for two PS was just over 400 dollars. A couple bellow sales paid for them back then Wink
Athansios
Page 34 of 64
