| Posted: Thu Dec 17, 2009 1:20 am Post subject: SAB noise |
Hi Guys, I thought this should be added to the thread since it might make a difference for some not all Astig amp boards
(SAB). I was having this nasty noise issue on my longbows where there were bands of vertical squiggly lines running across the screen. I ended up scoping the boards on the rear heat sink and found it was the SAB. I guess Scot knew this board was a problem. here is a repost of my findings and Scotts comments on the baord.
Here is a pic of the squiggly lines
| tse wrote: | The stig amp has been a problem child all along. If it was up to me (it isn't) I would have redesigned it years ago. It only has to output a few hundred milliamps and the bandwidth is max a megahertz or so. The idea of placing a ferrite suppresor over the cable is good. That absolutely had to happen with the two piece units where the stig amp is driving the stig coil through the 10' cable. The stig amp was not happy with the long cable and would oscillate like crazy. Those all had to have ferrite beads over the output wire right at the amplifier. The ferrites made for low freqs (look for ones specified at 10MHz) worked the best.
Scott |
If you hang a bit i am uploading a scope video and some pics so all can see, very very interesting to see how much Noise of instability is on that board.
No Ferrite, first pin from right(nearest convergence amp) Red (bottom ) and Green ( Top) channels
Now with ferrite, on any channel i have this on green.
And now with wire double wrapped around ferrite
And the Video
http://www.youtube.com/watch?v=P7Eu4RHnle8&feature=player_embedded
Now Cleaning up this noise on the board level, after i found this board to be a problem, was looked into By Mike. He made some board level changes that he said improved the picture and focus sharpness. I noticed this too with the ferrite beads. We'll have to wait to see some scope readings from Mike on the board level changes to see what the difference his changes made wave form wise compared to my scope readings. I just don't have the time to remove the SAB boards and do the work for now. So for me this seams to be a great and easy fix. And Scott also recommends t as well. I used some TDK Z cat ferrite cores i had lying around, i looked them up and mouser has them as well. get the ones that will fit around a normal audio cable so you can wind the astig cables through the core twice.
| Posted: Thu Dec 17, 2009 2:59 am Post subject: Re: SAB noise |
| Nashou66 wrote: |
Athanasios |
No, we're going after two different things. As I've said before, I'm not having a noise problem in my image.
The following images were taking from my test 8500LC. It's all stock with the exception of me changing out the CLM for this demo.
Notice what's on the frequency counter on the scope for each image...
First two shot were taking using stock (un-modified) CLM w/stock stig amp
Measured from BX-STIG pin on stig amp board connector
Measured from first pin on stig amp board right next to convergence amp
The last two were taking using a modified CLM w/stock stig amp - 538.2 Hz on display
Measured from BX-STIG pin on stig amp connector
On my 9500LC, it has changes also made to the stig amp, and that's what we're planning to look at in how we can further clean it up.
I'm having a few folk over tomorrow, and I'll show them the same demo to confirm what I'm showing here, and all I'm doing is changing the CLM..
| Posted: Thu Dec 17, 2009 3:15 am Post subject: |
Thanks for the scope pics Mike!
When i finally get time to add the parts you did i'll add it to this thread , i bet the combination of the beads and the board changes will be awesome . Can you PM the inductor values or post them here? I keep meaning to order a inductor kit with a bunch of values but always forget.
| Posted: Thu Dec 17, 2009 3:28 am Post subject: |
| Nashou66 wrote: | Thanks for the scope pics Mike!
Athanasios |
I'll send you the inductors and tants. You'll need to get the electrolytics. They're 220uf 25vdc - two also goes on the CLM.
1031
| Posted: Tue Dec 29, 2009 11:40 am Post subject: |
excellent paper on new, modern, low ESR low ESL capacitors and how they are being used in de-coupling. They talk about the old school approach of looping EL's, MLCC's, and Tants run in parallel within each loop and how this tends to produce oscillations. I think the MArquee VNB uses this philosohpy as you see a EL cans, followed by small 1uf tants and finally MLCC's.
It looks like the new approach is to use fewer of the new design style caps covering a much broader power filtering frequency and improved performance. By doing this you eliminate the oscillations between loops and also reduce board foot-print which is always good for noise reduction. They're even changing the packaging of the SMT tant's to reduce current loops, really cool stuff
http://www.kemet.com/kemet/web/homepage/kfbk3.nsf/vaFeedbackFAQ/E631B0BDEAB819C18525741700738042/$file/2008%20CARTS%20-%20Decoupling%20Solutions.pdf
Wouldn't it be cool to sit down with the MArquee VIM or VNB's and apply some of these newer techniques. I bet you could actually shrink the entiree size of the board and have a cleaner signal to boot.
I realize they are talking about crazy high bandwidths for PC CPU's but I would expect some of this would apply to a CRT video chain? Especially the 2035-03P VIM
Let the raging argument begin
HK-Steve
| Posted: Wed Dec 30, 2009 6:25 pm Post subject: |
Just when I thought I could have a quiet night without thinking about the Marquee,
Now this,
Nice fine draganm , lots of good info.
Oh No, The Wife just saw what I printed to read, looks like I will be on the couch again reading.
Nothing new there.
Have a Great New Year to all
Cheers
Steve
David_Web
| Posted: Fri Mar 12, 2010 11:54 am Post subject: |
I finally have my projector apart to change tubes.
I though I would add some clamp on ferrites where applicable.
So where should I put them?
And where should I not put them?
I guess between LVPS and HVPS could not hurt.
The right lines for VIM and CLM, VDM and the other boards. And of course P14. (Ill settle for some simple noise suppression right now but will mod more later)
But what have priority and where?
I figured that to limit the EMI from noisy lines it should not matter where it is put as the only thing we care about it current.
Volt should not matter for power rails as it goes hand in hand with current (AC).
How about the long black cables that goes from HVPS to VNB? OK to put a ferrite on them?
And a last question. Is 6.30V ok for P14? At least till I fix it later. I would guess no more than 100-200h or so.
_________________ SNR of people are ridiculously low.
dvh99
| Posted: Tue Mar 16, 2010 5:10 pm Post subject: |
i read somewhere the astig cables are the worst and that you should look at ferriteclamps specced 10mhz or less for those cables.
if you want to be sure ask nashou he`s the mod expert.
if you havent got his bellows yet order them cause they will leak someday if they dont already.
David_Web
| Posted: Wed Mar 17, 2010 4:23 pm Post subject: |
I don't have astig amp installed yet. Ill see if I need it first. I have enough for it if I install it later.
I ended up doing +-85V lines and the three lines going to each VNB. Also one big between LVPS and HVPS. And one around the smaller connector to the mainboard.
And one on each leg of P14.
Not sure what spec they are but any is better than none, at least when it comes to PSU lines.
Marquee 7500 (8110) so no bellows =)
I hope to get it together today so I have two days to tweak it until movie night on Saturday.
Sparky015
| Posted: Wed Mar 17, 2010 4:51 pm Post subject: |
If you haven't done so, check out Mike Parker's thread section about adding the ground wire. You may not have the issue though, if you don't have ASTIG, however it wouldn't hurt for the convergence board.
_________________ ~Paul
David_Web
| Posted: Thu Mar 18, 2010 5:58 pm Post subject: |
I used to have snow in my picture but now there is no hint of it, so it must have done something right.
I also found out all three magnetic rings are active. At least on green where I could detect the middle ring (faint but present). Not sure about R and B as I could not see any change, although it might be easier when I have done mechanical setup properly.
I hate leveling deflection yokes, have to turn it off for a while between adjustment. Me and HV does not play nice together so I might as well be careful.
Could you post a link to that ground wire?
Sparky015
David_Web
| Posted: Thu Mar 18, 2010 7:42 pm Post subject: |
Thanks. Might just plug in a pin and put it to ground. No need to solder until I need astig.
dvh99
| Posted: Thu Mar 18, 2010 9:51 pm Post subject: |
can you just add an astig amp???
there is a stig waveform generator on the clm on models with astig.
need to change the focus coils too.
David_Web
| Posted: Fri Mar 19, 2010 12:01 pm Post subject: |
I do have coils with astig windings (installed them with the new tubes). I also have an astig amp that would be easy to clamp on even with the PJ in position.
Might add it later but now I need it running for tomorrow.
Proper source setup next =)
After I put on the casing that is, no need to fry it with bad cooling too much. Not that it gets that hot.
DGP
| Posted: Wed Mar 31, 2010 9:04 am Post subject: Re: SAB noise |
| Nashou66 wrote: | Hi Guys, I thought this should be added to the thread since it might make a difference for some not all Astig amp boards
Scott |
And the Video
Athanasios |
I have also a VDC Marquee from 2004. I don’t have this level of noise in the picture, but I can see something similar to the noise you have in your projectors.
I have 3 ferrites, where did you placed them exactly?
Diego
