1031
| Posted: Tue Mar 11, 2008 6:21 am Post subject: |
Guys. I dont have ready solution for you to tell what is best way to bypass that sd5401.
Nashou that bandwith thing on that chip dependts surrounding components-> output impedance of driverstage before it, sd5401 input capacitanse and "on resistance" of switch itself and capacitance of output. Those parameters combine circuit that is similar to r-c filter. Rc-filter pass low frequencies and cuts high frequencies. But i think bigger problem with that sd5401 chip is crosstalk between different signals. One solution could be that signal that goes to pins 11&14 are routed throught single swicht ( small fet) i remember that sony uses that kind of fet, i must look closer what was that fet and is that any better than sd5401.
_________________ Marquee 9500LC (Frankenyokes / Thomas electric tubes / HD-10L / +many mod´s)
DVDO VP-50
New hobby, Rally
1031
1031
9kids
Joined: 25 Jun 2007 Posts: 138 Location: Manassas, VA
| Posted: Tue Mar 11, 2008 8:01 pm Post subject: |
With the first one we would need to feed it both video signals , internal and external signal and have it be able to:
1) switch on internal video and external video switched on to overlay the internal video
2) switch on external video and switch off internal video for normal viewing
3) switch off external video and switch on internal for internal video patterns only.
trying to figure out what signals to send as the trigers for each situation seems complicated to me.
And i have looked over the schematics and read the service manual and I can not find any chip that does the overlay of video. The SD5401 does not do that as far as i can tell, there are four seperat outputs one for each channel , no combining of signals is done in that chip. It looks fron the schematics that internal and external video is just sent simultaniously from this point on this section of the schematics labled red , to the AD834 on another page of the schematics where from there it goes to the rgb ouput op amp. I think Contrast is addded inside the AD834 but dont quote me on this. Two signals are then sent to CLC449 op am to the inverting and non inverting pins then from there to the rca jacks.
I think just seperating one section of the SD5401 with the SD213 is the simplist way to eliminate crosstalk which seems to be the only weak link with that original chip. it does state it is a high frequency chip so i think the bandwidth is not an issue since i dont even think MP bypasses that chip on his mods. And they do 1080p easily.
Athanasios[/img]
9kids
| Posted: Tue Mar 11, 2008 11:31 pm Post subject: |
| Nashou66 wrote: | With the first one we would need to feed it both video signals , internal and external signal and have it be able to:
Athanasios[/img] |
Athanasios,
This is really hard to explain, but I will try. External video and internal video are never on at the same time. The reason you can't find any chip that does the overlay of video is because the SD5401 does it. The word “overlay” is incorrect, it should be described as internal video “insert”. First remember the SD5401 is really really fast at switching. OK first picture a whole screen of external video (means the SD5401 is set to external vid), then lets push a remote button that causes a pop up menu to appear. Let’s say this menu box is located where the top of the menu box starts on scan line 100 about half way across the screen. For the first 99 scan lines the SD5401 says set to external video. As scan line 100 starts the SD5401 is still set to external video. About half way across the scan the SD5401 switches to internal video (for how ever long/wide the menu box is), when the scan line gets to the end of the menu box it switches back to external video. This happens again for scan line 101, 102 … until it gets to the bottom of the menu box. Then the SD5401 stays set for external video for the whole scan line until the bottom of the screen. I hope this makes since, it is really hard to describe. It took me days of staring at the schematic and rereading the service manual to figure out how those pop up menus worked.
| Posted: Wed Mar 12, 2008 12:02 am Post subject: |
I was just thinking this and was going to add to my post! I was going to say " I just realized that the SD5401 has really fast switching so it might be switching very fast between internal and external thus showing the menu on the screen" But I didnt understand the part you explained about knowing where in the video field to turn on and off, this is done by the CLM right? It sends pulses telling the ex-video to turn off and at that same precise moment tells the internal side of the switch to turn on. Thanks for also clarifying this for me, now I understand,and also why the relay wont work unless it is split and when we want to see the menu we switch to the way the projector works now, and if we want to watch video only we could bypass the sd5401.But that seems lik to much work. So looks like the SD213 or SST213 is our best choice to eliminate the cross talk .I also talked to a tech today from Linear and he told me that noise is negligable on the chip but he is not sure of the bandwidth but is sure it is more than enough for high resolutions.
Thanks 9Kids...whats your name anyhow if you dont mind me asking.
Athansios
9kids
| Posted: Wed Mar 12, 2008 1:36 am Post subject: |
| Quote: | | Thanks 9Kids...whats your name anyhow if you dont mind me asking. |
My name is John, sorry I used to sign all my post, then I just got lazy. I am glad you understood how the pop up menus work now. It is very hard to explain, I was going to offer to call you if you didn't get it. As my screen name says I have 9 kids and I can get very busy some times. I think the 213's might help but will post more later, got to get the little ones off to bed.
John (9kids)
| Posted: Wed Mar 12, 2008 2:37 am Post subject: |
John you explained it like a great professor i once had in college. Once i get the chips in i'll give it a shot ,one on the video path and then i'll also try one on the clamp path that goes to the dc restore. Not sure if the cross talk is that bad an issue but id be neet to see if something like this works, then maybe we can find some other chip where we know the specs are correct...but then again most specs are not really made with the conditions of real world use.
