BARCO/SEOS 1208: possible to get scope without further mod?
Blinx123
Posted: Thu Feb 14, 2008 5:01 pm    Post subject:
With dreamsetup I meant a dreamsetup that is at least slightly under the 10.000$US range.
Like I said: I want a big scope screen so it's not a problem to mask it down for a smaller but sharper picture. I'm going to buy a digital (a next generation 2k Panasonic if the design and quality doesn't change) in the not so far future (not farther away than 2 years) so it's not a bad idea to buy a bigger screen I think.
Posted: Thu Feb 14, 2008 5:06 pm    Post subject:
By the way that was in 1:85 mode, this is 2.4:1 scope:
last image ia 1080p@48hz with my personal moded 2005-03p vim
Person99
Posted: Thu Feb 14, 2008 5:09 pm    Post subject:
I use a 12 foot screen with my 8" marquee its all about personal prefrence. this is a 12 foot da lite 1.3 gain screen from a marquee 8500 with hd color filterd lenses which reduce light out put and I think it looks great.
It is, but we can objectively measure things like brightness and other things. We can also subjectively see things like softness. It is true that one may be willing to sacrifice absolute picture quality for other preferences and that is why I noted it is preference. But, I think it should be pointed out that a huge set up is definitely less than optimal and requires some sacrifices.
Person99
Posted: Thu Feb 14, 2008 5:14 pm    Post subject:
Do you have a CIH set up as OP is planning? In other words, is that 1.85:1 image using only 75% of your phosphor width? If so, I'd like to see a vertical 1-on/1-off pattern.
Posted: Thu Feb 14, 2008 6:43 pm    Post subject:
No I use CIW. keep the image at 12 feet wide just lower the hight.
Athansios
PS I do have another Marquee i usually run a stack but I have been doing some practice on chip changing on my OLD VIM 2005-03p and wanted to see the changes on its own.
