mrbud
| Posted: Sat Mar 01, 2008 6:09 pm Post subject: spares |
lol.. well not a spare per se.. but That ( MP2E ) is what I'm using... However for the right price I do have a ST-CP, and a CNMSX-PRO available....
My setup includes.
1 MP2E
1 VT3500
1 1550c
1 CNX B12B ( 12 button keypad )
1 Mits. 73" DLP
1 UVERSE ( AT&T Cable Box )
1 LG DVD player
1 Yamaha RXV 2095
Master Bedroom TV and Cable Box
Kitchen speakers
Basement TV, Cable Box, speakers
Porch speakers
Rotel Preamp ( for zone usuage )
Rotel Amp ( A and B )
Audiosource Amp Two ( A and B )
Now get this.. Total cost: $ 550.00... I love this business I'm in...
_________________ Beer !!!!! Sometimes you can have it for breakfast and it's ok.....
| Posted: Sat Mar 01, 2008 6:11 pm Post subject: |
Leaves more money for beer...
| Posted: Sat Mar 01, 2008 7:44 pm Post subject: |
Here's my list (only stuff controlled by Crestron) CNMSX PRO and CT-3500
1. AmPro 4600 HD CRT projector RS232
2. TAW ROCK Plus scaler IR
3. Panasonic DVD w/sdi mod IR (why I have the ROCK)
4. Sony SAT HD-200 Directv receiver IR
5. Verizon Fios HD-DVR w/HD Fury IR
6. Yamaha RX-V992 IR (soon to be a Pioneer Elite)
7. NEC ISS 6010 rgb switcher IR
8. Lawn irrigation system contact closure
9. Driveway gate contact closure
10. driveway and exterior lights contact closure
11. theater lights (programmed but switches not installd yet) aka too cheap
12. Two zones of HVAC (programmed but thermostats not installed yet) same reason as above.
13. APC SU3000RMNET RS232 working on that as we speak.
Soon to be installed is a Sony BD player of some sort.
OK, back to work. I built a RS232 control cable and installed the APC PC software on my PC to test the operation of the UPS and the cable. All works as it should. Now to make it work with Crestron.
_________________ Chip
KES
| Posted: Sat Mar 01, 2008 9:34 pm Post subject: |
OK, back from Work. Nice setups guys. I'm envious. I would be happy today just to get ONE TP button to do anything!
_________________ What does not kill you, makes you stronger.
KES
| Posted: Sat Mar 01, 2008 9:36 pm Post subject: |
MR BUD, shouldn't I be getting the RF indicators to light up on the STRFGWX if signals are going between the TP and MP2?
jmayes
| Posted: Sat Mar 01, 2008 9:49 pm Post subject: |
| KES wrote: | | MR BUD, shouldn't I be getting the RF indicators to light up on the STRFGWX if signals are going between the TP and MP2? |
Yes, there should be some blinks of the front panel when you touch tp buttons. I just looked up the manual for the STRFGWX and there is an additional step to set the RF channel in the GWY. Be sure to confirm which channel is needed in the TP setup screens and look in the manual here at page 12
http://www.crestron.com/downloads/pdf/product_manuals/strfgwx.pdf
That should get you going
JM
KES
| Posted: Sat Mar 01, 2008 9:51 pm Post subject: |
Hi JM, OK will check it out
| Posted: Sat Mar 01, 2008 10:34 pm Post subject: |
If the processor and touch panel still have their original programming then yes you should get visual results but, if you've tried to download a new program that is faulty, the original would be erased and you would get nothing.
KES
| Posted: Sat Mar 01, 2008 11:09 pm Post subject: |
HORRAH! The SIG is lit..RXD & TXD will flash. TP buttons now show presses. Test Manager trace window shows data! Alittle afraid to touch anything that it might stop working!
| Posted: Sun Mar 02, 2008 1:40 am Post subject: |
Now I'm having trouble getting a simpl+ symbol copied over from the sample program to my program. There are about 8 simpl+ "text change detector" symbols in the APC sample program. If I could just get one over to my program's userdb I could just change the input/outputs as needed. I can't tell you how thrilled I am with this project.
fuzzybee
| Posted: Sun Mar 02, 2008 1:58 am Post subject: |
Did you open the simpl program, or import a zip file?
| Posted: Sun Mar 02, 2008 2:21 am Post subject: |
| fuzzybee wrote: | | Did you open the simpl program, or import a zip file? |
The APC sample program was downloaded as a zip file
jmayes
| Posted: Sun Mar 02, 2008 2:30 am Post subject: |
| stefuel wrote: | Now I'm having trouble getting a simpl+ symbol copied over from the sample program to my program. There are about 8 simpl+ "text change detector" symbols in the APC sample program. If I could just get one over to my program's userdb I could just change the input/outputs as needed. I can't tell you how thrilled I am with this project.  |
I tried to post this once and IE lost it- here goes again.
There are two files that need to go into c:\crestron\simpl\usrsplus\ Text.usp and Text.ush, then close and re-open simpl or refreash the project database (in options).
The "Text Change module" should show up in the "Symbol Library" under "User Modules". You have to have a CNX controller to use this module, it is not compiled for the 2 series. I think you said you have a Pro and not a pro2 so you are ok.
I did not use the module, everything worked fine without it, I just see a little flicker when the update ocurs, I sorta like that as I know the system is working.
Good luck!
JM
fuzzybee
| Posted: Sun Mar 02, 2008 3:13 am Post subject: |
| stefuel wrote: | | fuzzybee wrote: | | Did you open the simpl program, or import a zip file? |
The APC sample program was downloaded as a zip file |
If you open Simpl Windows and choose "Import achive program" under the File menu, and then select the downloaded zip file, it should put the modules in the proper locations for you. Then, rebuild the user/project databases.
jmayes
| Posted: Sun Mar 02, 2008 3:17 am Post subject: |
| Quote: | | If you open Simpl Windows and choose "Import achive program" under the File menu, and then select the downloaded zip file, it should put the modules in the proper locations for you. Then, rebuild the user/project databases. |
Nice, I saw the archive/zip function but I did not know it would put the modules in their proper sub dirs. Good Tip Fuzzybee!
TX,
JM
| Posted: Sun Mar 02, 2008 4:13 am Post subject: |
I knew there had to be a easy way to do it. I'm just freaking brain dead tonight. I'm going to try it right now. I'll be back shortly and let you know the outcome. Thanks,
| Posted: Sun Mar 02, 2008 4:28 am Post subject: |
Well I'll be dipped_in_$hit. That was way to easy. I've been putzing around with this for hours. I could finish this up tonight but I told the wife I'd have the house cleaned by the time she got home from work. That gives me about 30 minutes
Thanks for the tip.
| Posted: Sun Mar 02, 2008 5:32 am Post subject: |
| stefuel wrote: | Well I'll be dipped_in_$hit. That was way to easy. I've been putzing around with this for hours. I could finish this up tonight but I told the wife I'd have the house cleaned by the time she got home from work. That gives me about 30 minutes
Thanks for the tip. |
LOL !
| Posted: Sun Mar 02, 2008 6:00 am Post subject: |
The house ain't clean yet but I'm almost done here. Oooops, sorry honey, I lost track of time.
fuzzybee
| Posted: Sun Mar 02, 2008 12:53 pm Post subject: |
No problem - it's what I do for a living.
