should I swap parts on an XG
kevin_k
Posted: Sat Jan 19, 2008 1:56 pm    Post subject:
Yes, the two sub boards are the same.
I don't understand though, if the boards have the same numbers , pwc, 721, 3a5 wouldn't they be that same boards. Would NEC have different revisions to the board and not change the numbers? I doesn't make sense.
dbaisey
Posted: Sat Jan 19, 2008 1:59 pm    Post subject:
It does to me unless I need more coffee. Doug
kevin_k
Posted: Sat Jan 19, 2008 2:03 pm    Post subject:
So you think NEC would have the same pwc, 721, and 3a5 number but it be a different board between the 751 and 1352?
Posted: Sat Jan 19, 2008 2:08 pm    Post subject:
No. Same number, same board.
I don't understand the confusion? It's a 751, and most of the boards should swap, the ones with the same numbers/inkstamp.
dbaisey
Which part are you refereing to? Im missing something I guess. Doug
kevin_k
Posted: Sat Jan 19, 2008 2:11 pm    Post subject:
I think I got it Doug, that last PM helped. If the 933A5xxx numbers match between the machines I can assume then I'm good to go to swap them?
Cool, thanks Mark
dbaisey
Posted: Sat Jan 19, 2008 2:18 pm    Post subject:
Should be. I'm mainly factory NEC specific. Runco did a few things different and no docs on it were given out on specific changes but on the most part you will be ok. You got lucky it was a 751. Doug
kevin_k
Posted: Sat Jan 19, 2008 2:24 pm    Post subject:
I'm finding out I'm lucky. I have a 750 in the basement that I was originally going to try to use. I would have been SOL with that idea. Maybe it's time to get rid of the750.
dbaisey
Posted: Sat Jan 19, 2008 2:34 pm    Post subject:
Kevin,
Does the Runco have HD-8 lenses and if not which ones. Doug
kevin_k
Posted: Sat Jan 19, 2008 2:38 pm    Post subject:
It had 144's, I had the seller keep them so I could ship UPS. Needed to reduce the weight and lenses got it undert UPS's limit
