Easy, cheap, simple adjustable ceiling mount for Marquee's.
Posted: Thu Aug 07, 2008 9:22 pm    Post subject:
You guy's are all out there. When was the last time you actually looked at a good factory mount?????
I just happen to have a base plate right in front of me with 18 slotted holes. It allows for 3 inches side to side movement and 2 inches fore and aft. It allows for twist and tilt. If you can't get the plate up close enough for that, then you shouldn't own tools Laughing I'm not going to argue the point further as I'm convinced that everyone will side with the great Kal, right or wrong. You do it your way and I'll continue to do it the correct way. Razz
Posted: Thu Aug 07, 2008 9:47 pm    Post subject:
If a factory mount has play like that Chip it's a whole other story. Definitely interesting then. That would give you enough flexibility to dial it in 100% perfectly as long as you got the initial install ras bang on as possible.
For those that hushbox (and most should as 95% of CRTs are too noisy), why not save $200 and go with unistrut though? Factory mounts are hard to come by, expensive, and don't offer anything 'more' than a unistrut mount or metal pipe mount as per the original poster.
I dunno, I guess I'm of the opposite viewpoint: Why spend the money when it gives you nothing in return? I have no issues with someone paying big bucks for a few % of improvement but factory mounts don't give you anything more. I'm not a cheap bastard by any stretch of the imagination ($15-20K invested in speakers alone) but I hate spending money when it truly gives you nothing extra in return.
I agree that this thread's gone on long enough though... different viewpoints I suppose. Though I do agree that I wouldn't want to see exposed unistrut or pipe in the HT myself.
the_avguy
Posted: Thu Aug 07, 2008 10:05 pm    Post subject:
the_avguy wrote:
the_avguy wrote:
Does anyone know if this will work for an ECP 4100?
It looks like it should
Are the bolts the same size?
thanks
Okay I think we have confirmed that using this method doesn't make me a cheapskate. Laughing
So can anyone confirm or deny the bolt size on the ECP 4100.
Okay before we give up on this thread completely can someone answer me?
Are the bolts the same as the marquee?
working ECP 4100.
marquee still in pieces, just gathering knowledge.
optoma ep729
Heywood Jablome
Posted: Thu Aug 07, 2008 10:57 pm    Post subject:
You're in a scrappy mood. Anything to do with Crestron-izing a remote with 54 buttons? Mr. Green Mr. Green Mr. Green
Posted: Thu Aug 07, 2008 11:34 pm    Post subject:
I'm still stewing over the "ignorant" remark.
Clarence
Posted: Fri Aug 08, 2008 12:50 am    Post subject:
Factory mounts are for dealers, installers who just want to do the job fast. Or for ignorant users who don't care about the best possible image quality or simply don't know any better.
Chip, why are you stewing over Kal's indirect use of the word "ignorant"?
He didn't personally call you "ignorant", it was in the context of COTS users that may be "unaware" of various viable and affordable DIY mounting solutions.
These forums are invaluable for presenting these types of options. If you prefer OEM mounts, then use an OEM mount. But please don't take offense to others using or recommending DIY mounts.
LOTREE
Posted: Thu Dec 24, 2009 4:26 am    Post subject:
Sorry to revive an old thread but I thought I'd show how this setup for can be adopted for the Electrohome ECP series, at least the 4500. I would assume they're all the same.
Unfortunately the ECP uses a 5/16-18 thread bolt for the legs instead of a 3/8" which will affect the design/material list in a number of ways.
First off the 5/16 thread eye-bolt has a 3/4" eye hole so the 1/2" inner diameter pipe shown cannot be used. Now you're probably thinking I have 1/4" to play with. Well, the 1/2" inner diameter pipe is actually larger mostly from the thickness of the wall plus the fact the eye-bolt holes are not a complete perfect circle where the head end touches the neck. Soooo... I used a 1/2" electrical conduit which is actually 3/4" and slides in with about 1/16-1/8" to spare.
I purchased the 10' x 1-5/8" c-channel 1/2" slotted strut and 10' x 1/2" conduit at Gray Bar which is available in most areas. The strut was $22.67 and the conduit was $3.00 ($4.98 at HomeDepot for the exact same item).
While a 1-1/2" washer is perfect for the outside/bottom for clamping the bolts in position they cannot be used inside the strut which measures 1-7/16" as they are too wide. I managed to find a 1-3/8" washer but it does have slight play in the channel plus it has a 9/16" hole so backing it with a 1-1/4" and 5/16" hole washer doesn't help as it will just slide around. I was originally going to use the 1-1/4" washer but it was sloppy so the quest begins again to find a new washer or I'll just cut/grind the 1-1/2" washers I bought to fit the 1-7/16 strut channel.
To mount the strut to the ceiling I bought 3/8" x 4" lag bolts with a washer that fits but again it is 1-1/2" so they need to be returned.
I'll update the rest tomorrow if I get a chance with pictures and hopefully have a chance to converge the projector also! Thumbs Up
Elaine Benes
Posted: Thu Dec 24, 2009 4:33 am    Post subject:
You can use tin snips to just snip a bit off any washers that are too big, a bonus of doing this is they don't turn in side the channel if they have a flat side...
LOTREE
Posted: Thu Dec 24, 2009 4:40 am    Post subject:
Not sure if I can use snips on 1/16" washers, seems a bit thick but I guess I could try. I think a hack saw may work best.
Elaine Benes
Posted: Thu Dec 24, 2009 7:55 am    Post subject:
Well, a hack saw will work best if you want to spend a lot of time just to cut a small sliver off the edge of the washer, but if you want to do it quick and easy, tin snips, the kind with the red, green, or yellow handles(to denote right/left/straight cut) will work best. Try it before you doubt it will work, I didn't believe it either till I tried it. Its funny, I've got a pair of tin snips that were my Dad's, old beat up things I don't care if I wreck them or not, so if I have something I need to cut quickly, I give them a try first. I've yet to encounter something they wouldn't cut, and haven't wrecked them yet...and so much quicker than a hack saw...wear safety glasses when you're doing this...and you'll likely need to use two hands on the snips...
JustGreg
Posted: Thu Dec 24, 2009 9:13 am    Post subject:
Or just use flat stock to begin with and drill your own hole. I made some for my pj mount to replace the horrid Unitstrut 'nut' that scared the crap out of me. The problem with those things for my application is they're made to spin out of the slot one way and that way was the wrong way. They don't make any with a radius going the other way from what I could find. To use them I would have had to add another cross layer of Unistrut to the design. 'Cause I have limited ceiling height low profile was everything. I used 1"x1/8" stainless bar and cut, drilled, and tapped (not required for what you want) to suit. No way for it to turn in the channel.
Lacking a bench grinder, a handheld electric grinder/cutoff works great. A PorterCable model is only like $40 at Lowes. It takes a steady hand to hold the grinder and turn the washer (or a vise to gently clamp the grinder in) but it can be done and the grinder has a zillion more uses than a bench grinder most people only occassionally use. With a cutoff wheel you can make quick work of cutting any metal such as your channel stock. Handheld shears would work I suppose for 16th inch but owie on the wrists. Then there's the hand filing to debur..........
This post would have been great when I was building mine. It would have saved alot of time but I'm happy with my mount and electric winch combo.
Greg
Elaine Benes
Posted: Thu Dec 24, 2009 1:54 pm    Post subject:
This mounting method works great with a Barco 808S too.
I now have a Barco, and the mount channel pieces bolted to the bottom of the projector which are made to fit into the factory mount just happen to have four holes in them which are perfect places to bolt the eye bolts needed to push the black pipe through. I was able to mount my Barco using the same method, and the same pieces of unistrut I'd already fastened to the ceiling joists for my Marquee.
Because the unistrut gave me forward/back adjustment, I was able to get the mount position of the longer Barco to the correct place without having to move anything that was already lag bolted to the joists...
benareeno
Posted: Thu Dec 24, 2009 6:32 pm    Post subject:
Well...according to chip, you're both foolish for attempting such mounting techniques...best to order in the factory mount and hope you get it right. What a ridiculous argument! Factory mounts as good as a custom uni-strut mount? Give me a break. Maybe with your mult-holed factory mount...but not with the factory mounts I've seen.
Who would come into such a thread and try to pooh-pooh it? And then cry when put in his place...just ridiculous.
Posted: Thu Dec 24, 2009 8:21 pm    Post subject:
I feel Kal is right on with his comments. I have never been able to line up a projector nearly as well with a factory mount as compared to uni-strut... it's just not possible.
Furthermore, with my uni-strut mount the projector is only 2.25" from the ceiling and with a G90 mount it would be about 4" down from the ceiling. 1.75" may not seem like much, but my ceilings are only 7'8" tall and I need to keep all the head room I can possibly maintain.
And furthermore again, my house is 105 years old and the joists are not spaced as they are in new houses, they are further apart. If I wanted to use a Sony mount I would need a large, heavy, metal base plate, or two pieces of uni-strut to mount the mount to in order to span the joists... and that would have cost me tons more ceiling height. I have G90 mounts here, but I prefer uni-strut in most installations (though not all). One thing the factory mounts tend to allow for is easier adjustments to the pitch, but you can do that with uni-strut as well.
benareeno
Posted: Thu Dec 24, 2009 8:28 pm    Post subject:
craigr,
how often do you spin up a laser disc?
Posted: Thu Dec 24, 2009 8:45 pm    Post subject:
Uhh hmmm, Craig remember what you said a few years ago when you came to Calibrate my Marquee 8000?
"Wow , you really set this up good, you left me no room on the raster for tweaking" (if you ran into ringing, which you didn't) Wink
The Marquee factory pulley mount allows for lots of adjustment . For thew longbows i also used the unitstrut so when i go to 9 inch tubes i can move it forward or back. but once i had the mounts connected to the unistrut and did careful measuring i did not touch the unistrutt again and only used the Marquee mounts adjustment bolts.
benareeno
Posted: Thu Dec 24, 2009 9:00 pm    Post subject:
are you suggesting he's lying?? Or do you think he genuinely believes a uni-strut mount is a good solution? I mean really....what is the point that is being argued here?
Posted: Thu Dec 24, 2009 9:24 pm    Post subject:
No argument, i am using it also ben, but to say its impossible to get a good set up with a factory mount is not 100% true. With either you just need to take your time, and great results will be the reward.
benareeno
Posted: Thu Dec 24, 2009 9:32 pm    Post subject:
nothing is impossible...uni-strut is the better solution, simple as that.
Posted: Thu Dec 24, 2009 9:40 pm    Post subject:
Pulley mounts are the best simpler and simple as that Wink lol
Page 2 of 3
