I miss the Evil Twin. I lost the tse gamma design
Goto page Previous  1, 2, 3
Posted: Sat Jan 26, 2008 3:22 pm    Post subject:
beun wrote:
As I understand the MP 1.4 circuit is more of a replacement for the cheap video card antialiasing filter, but I have to defer to MP as the actual authority on it.
Kim
It's replaces the 75 ohm termination and provides an output driver stage to drive long cables.
beun
Posted: Sat Jan 26, 2008 3:58 pm    Post subject:
OK, the RTC2x00 output uses an exact 75Ohm termination and has the currrent capability to drive long cables.
ESL-0.5 Full Range Electrostatic Loudspeakers | RTC2200 Component to VGA Converter with Gamma Boost
beachbunnyfl
Posted: Fri Feb 08, 2008 3:01 am    Post subject:
I am interested in this gamma dongle idea as well.
I was thinking of adding Kim's RTC2200 to my setup,
an HDMI switching receiver to HDFURY to Nec XG110.
This gamma booster would be perfect!
I do not need component inputs and I already
have a 35 foot HDMI run , w/ Monoprice HDMI booster,
working fine to the HDFURY.
The RTC2200 would mean pulling out the VGA-BNC cables again!
Please put me in the waiting line to buy one of these!
Robin
NEC XG110
HD FURY
Key Digital HD1080P-Leeza
Monoprice HDX-402
beun
Posted: Fri Feb 08, 2008 3:26 am    Post subject:
I already have a preliminary board layout ready and am waiting on a few sample dongles to see if I can make everything fit.
Posted: Fri Feb 08, 2008 6:33 am    Post subject:
I have both tse's and beun's gamma cards. Both are very good ! Beun has adjustable gamma on his. Both seem to be a great upgrade for a CRT projector. Only beun has a model in production...
e_patsellis
Posted: Sun Feb 10, 2008 5:08 am    Post subject:
buen,
I'd be interested in a pcb or completed product, preference being to the pcb...
erie
Posted: Wed Feb 13, 2008 3:27 am    Post subject:
Probably a stupid question, but I'm good at that. Re the tse card, why do you even have to deal with sync. Why can't it just be passed? One more stupid question. Why does a doctor call what he does a practice? I don't want some dumb MF practicing on me Laughing
beun
Posted: Wed Feb 13, 2008 4:51 am    Post subject:
Well, I can only answer the first question. Since you need a known black reference when you want to do gamma you need the H-sync to clamp the signal to that known black reference. When you don't your gamma will depend on the average level of the video and that will look really weird.
Posted: Wed Feb 13, 2008 6:31 am    Post subject:
Chip in answer to your second question it's for insurance reasons... Wink
Posted: Wed Feb 13, 2008 7:17 am    Post subject:
Would that be like calling a doctor a perfect practitioner?
Posted: Wed Feb 13, 2008 10:58 am    Post subject:
Tom, you're on my ignore list until I see in the forum somthing to the effect "It works, I've done it".
You know what I'm talking about. Wink
Posted: Wed Feb 13, 2008 1:16 pm    Post subject:
Was out of town for a three day holiday and now working on another major project with a deadline of friday but in the next couple days....
gcom007
Posted: Fri Sep 05, 2008 5:28 am    Post subject:
Is there any sort of updated schematic from those that have been posted? It sounded as if those posted were tentative while more definitive versions would be published later.
-Elliot
Barco 1208s/e
tse
Posted: Fri Sep 05, 2008 11:49 pm    Post subject:
Elliot,
AVSGAMDCR_REVB.DSN
was the latest schematic. It was fully functional at that point. All the little bugs were worked out.
Scott
Thomas Jefferson
gcom007
Posted: Sat Sep 06, 2008 1:16 am    Post subject:
The reason I ask is this somewhat random thought of the possibility of somehow hard-wiring this into the projector signal path? I could likely only do it in the most rudimentary of ways, but I have electrical engineer friends who might have other ideas. But do you have any thoughts on this?
-Elliot
Barco 1208s/e
tse
Posted: Sat Sep 06, 2008 3:06 am    Post subject:
That is the whole idea. Connect your analog video signal into the device and connect its output to the input of your projector. The shadow details are then brought up from the mud and are displayed without setting the projector bright control too high. Something that benefits a CRT projector.
Scott
Thomas Jefferson
gcom007
Posted: Sat Sep 06, 2008 5:50 am    Post subject:
Scott
When I mean in the signal path, I mean, well, inside the projector. So all inputs would work the same outside but then be processed before hitting boards most likely? I think I'm talking crazy...you know, with music and guitar and all that, as a serious player, I'm constantly a bit annoyed with "weekend warrior" types who get a little too ambitious and end up just being annoying. I feel like a CRT/Engineer weekend warrior in the worst way...
No, but again, I was more wondering like I said if there was a way or any benefit to somehow making it a hard-wired actual part of the projector per se as opposed to an external box. I wasn't sure if skipping some soldering points could help as well as more cable connection break points. I guess in some ways it all would balance out, but eh, I'm just pondering...
-Elliot
Barco 1208s/e
Posted: Sat Sep 06, 2008 10:45 am    Post subject:
I'm not saying it can't be done but it's a lot of work just for the sake of not seeing something outside the projector. You could use Scott's design, shrunk down to daughter board size and attach it to the RGB input card of your projector. Divert the signal from the input BNC's to the gama circuit then out and back to the input of the RGB input card. It would require a much smaller board with SMT construction.
Page 3 of 3
