lyd
Joined: 15 Sep 2007 Posts: 390 Location: Lake Mills, Wi
| Posted: Mon Jan 07, 2008 11:05 pm Post subject: |
| CRTuser wrote: | | nuttall_chris wrote: | There is a registry tweak that needs to be done with PowerDVD that will solve this problem.
Search your registry for COLORSPACE_OPTION and set the value to 1. You will need to re-setup your brightness level but this should help.
Chris. |
Could you please elaborate on this topic a little bit more?
Is the registry file in the PowerDVD folder? What's its name?
Thanks. |
The windows registry. It's a database that stores variables for system and program settings. You use regedit.exe to manipulate and view it. If you make a mistake and change something you shouldn't, you can render your machine inoperable. Please take care.
I posted the full path to the key in the thread on this topic that AR started in the HTPC forum.
lyd
