9500 lc issue
Posted: Tue Mar 10, 2009 12:36 pm    Post subject:
Oh, my XG is a tiny bit off too.
I thought you meant about 5 hz or something!
schmoe
Posted: Tue Mar 10, 2009 4:01 pm    Post subject:
Interesting. I was only looking at the Info screen on the scaler. I'll check the pj when I get home.
1031
Posted: Tue Mar 10, 2009 5:27 pm    Post subject:
I noticed this also recently with the marquee, on my TV-One units i will set up the timings and make sure the frame rate is as mark says but the marquee will show a different timing.... not sure whats going on? Do i trust the Scaler or the Marquee?
My marquee shows framerate allways exactly (same with VP-50)
If i remember correct (that was few years back..) friend has lumagen and least for me that has quite strange logig how it showed those output parameters?
DVDO VP-50
New hobby, Rally
schmoe
Posted: Wed Mar 11, 2009 8:28 am    Post subject:
So that used VP50Pro I picked up, had original v1.00 firmware. So I upgraded to v1.50 and re-setup everything and I noticed two things: 1) the shift/porch values are significantly different than what I mentioned in my previous post. I'm too lazy to go look now but the shift went from 329 to something around 370. 2) It's outputting a proper 60 hz, again through no intervention of my own. Maybe I was hitting a bug in the v1.00 firmware that was causing the 56 hz output ?? Anyway, all seems well now.
Page 4 of 4
