9500 lc issue
Goto page 1, 2, 3, 4  Next
bomrat
Posted: Sun Nov 18, 2007 3:59 am    Post subject: 9500 lc issue
what would cause this.. banding on the right. is it from the coils? its happening on all three tubes. can't turn up the contrast above 50
Posted: Sun Nov 18, 2007 4:01 am    Post subject:
Do you mean the banding on the other right? Wink
bomrat
Posted: Sun Nov 18, 2007 4:02 am    Post subject:
uh, on the left
Posted: Sun Nov 18, 2007 4:17 am    Post subject:
Unrelated to your 9500 but I had that on a CRT monitor. Replacing the VGA cable fixed the problem. Not sure if that's what you are seeing though.
jask
Posted: Sun Nov 18, 2007 8:12 am    Post subject:
what is your source? did this just start?
nuttall_chris
Posted: Sun Nov 18, 2007 2:17 pm    Post subject:
Every Marquee I have see does this when the retrace option is set to short. Change retrace to long and that "banding" will go away.
This has nothing to do with cables as it occures on the internal test patterns as well. It is on all colours.
One problem is that many source devices use very short porches and with retrace set a long the picture will be clipped off on both sides, setting retrace to short can help the clipping of the picture but the side effect is this "banding" on the one side of the picture.
Chris.
bomrat
Posted: Sun Nov 18, 2007 4:18 pm    Post subject:
mike parker, please call ken w...
schmoe
Posted: Sun Feb 22, 2009 12:03 pm    Post subject:
I have this exact same issue with a 9500 I'm trying to set up and it's really annoying. Is there anything that can be done? I'm using short retrace. If long retrace is the cure, how do I change my signal to work with long retrace? My setup: DVDO Edge -> HDMI -> HDFury2 -> RGBHV -> 9500.
Posted: Sun Feb 22, 2009 12:28 pm    Post subject:
Confused? Not banding but raster ringing.
Posted: Sun Feb 22, 2009 3:08 pm    Post subject:
there is a tech bulletin on this i think. But it might be for the right side not left. And Chip is right its ringing VDC calls it jail bar
ringing i think.
If its on the internal test patterns only, this Bulletin might help
http://www.curtpalme.com/docs/ElectrohomeMarqueeTechnicalBulletin_VDCDS_TFB_003.pdf
It might help even with external images also i believe, not sure.
secstate
Posted: Sun Feb 22, 2009 3:49 pm    Post subject:
Yeah Barcos do this too, especially when they go into hi scan mode.
tse
Posted: Sun Feb 22, 2009 5:25 pm    Post subject:
It sure looks like ringing caused by short retrace. If you have to use short retrace phase the external image as far to the right as necessary to avoid the bars. You might have to use the convergence shift (center adjustment) to put the picture back in the middle.
Scott
Thomas Jefferson
Posted: Sun Feb 22, 2009 6:47 pm    Post subject:
Just so ya know, this condition is not specific to Marquee's. The condition can be duplicated with just about every crt projector. One more reason not to sway to far from factory recommended mounting instructions. It's one of the trade-offs
from insisting on using as much of the tube face as you can eeek out of it.
schmoe
Posted: Sun Feb 22, 2009 7:33 pm    Post subject:
The ringing is there all the time, not just for test patterns. Otherwise I wouldn't be bothered. I don't have much experience soldering and such, so not sure I want to attempt a bulletin fix that may only apply to the internal test patterns.
hmm, why don't more people complain about this then? Are people not running 1080p60?
Can you elaborate on what the mounting instructions have to do with this issue? Thanks.
nuttall_chris
Posted: Sun Feb 22, 2009 9:34 pm    Post subject:
This has nothing to do with mounting position. You can squeeze the raster in far from the edges of the tube face and it's still there. This appears to be a stabilization of the velocity of the horizontal scan after retrace when using short retrace.
Chris.
Posted: Sun Feb 22, 2009 10:29 pm    Post subject:
My XG will do it too.
Chris is bang on with the cause.
To fix it you need more porch pixels (I can't help with the Marquee specific retrace settings), and reduce the width/size setting.
More porch pixels/reduced width will mean that you may have to more the projector back...closer to the factory settings...to fill the screen.
If I want to eliminate the ringing on my XG at 1080i 96hz I really need to move the projector back.
Posted: Sun Feb 22, 2009 11:31 pm    Post subject:
"This has nothing to do with mounting position."
If you say so. I guess I've been told Laughing
nuttall_chris
Posted: Mon Feb 23, 2009 12:01 am    Post subject:
You can also add more porch pixels and then widen the raster. This will give you the same size image on the tube face eliminating the need to move the projector back.
Chris.
secstate
Posted: Mon Feb 23, 2009 12:15 am    Post subject:
They do complain I have seem quite a few compliants over the years. It is more noticible on high scan on Barcos and 1080p will not cause Barco's to cut over unless the owner has adjusted them to lower the cut over. I have seen it to a degree on every Barco I have run. My current Barco does it to some extent on 1080i.
Posted: Mon Feb 23, 2009 2:08 am    Post subject:
This is most likely the worst with 1080p right?
It's raster ringing, and all projectors that I have seen do it to some degree or another. The best fix to improve the situation is to position the image as far to the left (when looking into the tube) on the raster as you possibly can (away from the leading edge). The farther the edge of the image is from the start of the raster the more time the beam will have to settle down.
This happens with high scan rates because the beam has to go from -40 IRE all the way up to the image IRE level (and you are probably showing a 100 IRE field in the photo so 140 IRE jump?). When the beam does this, it shoots past the IRE level desired and then oscillates for a spell. That's what makes those waves in the picture.
If you are using a VP or HTPC you can do as others suggest and increase your porch sizes, to make the raster bigger, to allow for even further positioning of the image away from the edge. However, keep in mind that when you increase the pixel count you also draw more bandwidth and your image may become softer.
The G90 is the best projector in terms of being able to make this distortion almost invisible, but you can still see it if you know what to look for.
Page 1 of 4
