the_avguy
Joined: 16 Mar 2007 Posts: 91 Location: Edmonton, Alberta
| Posted: Sat Oct 27, 2007 6:37 pm Post subject: |
| macgyver655 wrote: | Hurray Yes you can delete all cookies, temp files, temporary internet files and history. Glad you got it running. |
It's okay to delete your cookies but probably not required.
You will then have to resign in to all your bulletin boards etc.
_________________ working ECP 4100.
marquee still in pieces, just gathering knowledge.
optoma ep729
JustGreg
| Posted: Sat Oct 27, 2007 7:48 pm Post subject: |
Don't forget to delete all the files in the %system%\Prefetch folder too. Also do a search for *.tmp and *.temp files and trash them too. Running programs won't let allow you to delete an in use temp file so just deselect it by holding down the Shift key and left clicking on it. Do that every time the delete process stops on a file that's in use.
Glad to hear it's up and running.
Greg
_________________ Greg
the_avguy
| Posted: Sun Oct 28, 2007 3:16 am Post subject: |
I am curious, why are you so interested in deleting all the temp files?
In the normal course of operations they shouldn't be a problem.
Unless you are running out of space on your hard drive maybe?
optoma ep729
Naw it's to hide the pron from the wife/GF.
| Posted: Sun Oct 28, 2007 11:53 am Post subject: |
| AnalogRocks wrote: | Naw it's to hide the pron from the wife/GF.  |
"pron"??? Oh, you mean porn. Other peoples sex. Kind of like other peoples money. All you get to do is look at it
_________________ Chip
| Posted: Sun Nov 11, 2007 12:07 pm Post subject: |
Well, my main PC's gremlins have retuned. Last night I was on fleabay looking at more Crestron equipment. My eyes were bothering me so I took a 1/2 hour rest. when I returned, I found it had shut down on it's own. Now it's totally unresponsive. There is some power as a green led on the mother board is lit as normal, just no respose from the power button. When my problems started before, a trouble shooting flow chart for my mother board kept mentioning the power supply. Is there a way to test the supply to confirm it is the problem? In just about every scenario on that flow chart, the power supply was mentioned as a possibility. Thanks,
| Posted: Sun Nov 11, 2007 1:05 pm Post subject: |
Do you have another power supply, or another PC that can play surrogate?
incova
| Posted: Sun Nov 11, 2007 4:30 pm Post subject: just shut down? |
Hi Chip, if it has just shut down and is not responding put it of with the power button at the back of the power supply, leave it off for a few seconds so there are no lights on the pc motherboard. Now put the power supp button back on and press your power for the pc. What does it do then?
the less I know.
oliverg
Joined: 15 May 2007 Posts: 800 Location: Melbourne, Australia
| Posted: Sun Nov 11, 2007 6:50 pm Post subject: |
Also, check your power management settings - for the sake of this exercise, turn all PM off.
_________________ ( R ) G ( G ) 9 ( B ) 0 ( R ) G ( G ) 9 ( B ) 0
| Posted: Sun Nov 11, 2007 8:26 pm Post subject: |
I tried another PS and it went instantly into protection. After some trial and error I narrowed it down to my powered graphics card. If I un plug it it fires up. I tried another powered card from this PC and it's fine. Time for a new card. This one is a Geforce 6600GT 128MB AGP 8x/4x. I need a quick suggestion for a replacement so I can pick one up today.
| Posted: Mon Nov 12, 2007 3:03 am Post subject: |
I know a little late
7300GS, 7600 or 7900/7950 $erie$ will get you back up and running. Make sure to get the AGP card. Will your mother board run 8x AGP or was it an older model that will only do 4x?
