Obligatory noob post. Please advise.
lyd
Posted: Mon Sep 24, 2007 1:00 am    Post subject: Obligatory noob post. Please advise.
Greetings all.
I've been reading on the subject of CRT projectors both here and at avs for a couple hundred hours now, and, while I have learned a lot, I do not yet feel that I am in a position to make an intelligent purchasing decision. I loathe to make one of these vague and no doubt irritating "which projector should I buy" or "what would you pay for gray cat in the dark" posts, but for all my research I don't feel too much further along than that, and I'm not quite sure where to turn next. I am hoping that you lot can give me a pointer or two. I'll try to be as succinct as possible, though that may be "not very", given the scope of my questions.
I'll just dive in...
I am located in North-East Pennsylvania, between Scranton and Allentown.
I have a large room to use, approx. 20' x 30' with 10' ceilings. The screen will be on the 20' x 10' wall. (Not that I need or expect to fill it.) The room has three large windows that I intend to black out completely, and one open doorway that I intend to curtain. The walls and celling are white and there is nothing I can do about that in the short term. The primary seating is currently located about 15' back from the wall, but can be moved as required.
Ceiling mounting is not likely to ever be an option, but I do have plans to create a sort of gantry/scaffold out of architectural pipe, a la Speed-Rail, to get it overhead. More on that some other time, perhaps. Initially it will be on the floor/table.
I know that want at least 8", I think that I want at least 960p (for SD DVD, upscaled) & 1080i (for HD). One of my questions is whether I might be just as happy with 720p for SD DVD.
I think I want LC.
Currently, I exclusively watch SD material on a 27" Panasonic GAOO that I have had since 1993 and loved unwaveringly the entire time. Unfortunately, the tube is way beyond its duty cycle and I can no longer get it anywhere even remotely close to proper saturation or luminosity.
I have lived with this for a long time primarily because I would rather watch it than any fixed-pixel display I have ever seen. I install cable television for a living these days, so I see a lot of them. The best of them look great for HD content, and if I had an HD-capable device I would no doubt watch more such content, but I still watch enough SD that I can't abide the horrible artifacting I see with even high-end upconversion. Most of them look pretty bad even with HD content. But, sorry, I am getting off track and preaching to the quire.
Source is HTPC, primarily DVDs and the occasional download. I do not have cable, satellite, or a broadcast antenna, and don't intend to get them. I do intend to get a blueray and/or hddvd drive for the PC.
So, it is down to this.
Which projector should I buy? Wink Sorry couldn't resist.
My biggest problem is that I have not been able to see anything first hand. I have emailed a couple of people I found nearby with that request, but not gotten a response.
If I had a greater level of certainty regarding either "what should I be paying," or "what are the minimum features to get me what I need" I would be more comfortable taking a leap, but being uncertain of both of these has left me spinning.
A short while back, before I came to my senses and realized I needed to know more, I almost bought an Ampro 4200 from an individual on one of the forums for $2k. Curt has several items listed on his site that seem like possibles, 2 XG 1351 LC's for $3000 & $3400, a G70 with lower-grade tubes for $1800 that seems interesting, and the tweaked-out 8500's for $3k.
These are all potentially within my budget, but it is still an effing lot of dough! I am finding it a very tough choice to make, particularly when I see people finding units in the next level at similar prices. Make no mistake, however, I understand and fully appreciate the merits of purchasing from Curt or a similarly reputable dealer.
Well, this is has gone on long enough. You see where I am at this point. I'll only add that I would ideally like to spend less than $2k, I could spend as much as $5k if I thought I absolutely would not be satisfied spending less, but that would really hurt a lot and devastate my near-term options for the rest of the set-up. If I can't be happy for less than $8k - $10 I will have to put this off for quite a long while, if not indefinitely, but from what I gather so far this shouldn't be the case.
Wow. This sure lived up to the "noob post" subject line. Can anyone resist the desire to slap me and offer suggestions on where I go from here?
lyd
Posted: Mon Sep 24, 2007 1:12 am    Post subject:
Hopefully someone will chime in that they are close by and will let you take a look at a good 8" setup.
Here's some basics as far as I'm concerned, others will violently disagree..
1) Comparing apples to apples, put 10 different 8" sets in a large room and set them all up well and drive them with identical signals (and assuming all have minty tubes of course), there will be very little difference between models. Some will be louder, some will be easier to set up, some might be a touch sharper than others, but one isn't going to be significantly better or worse than others.
2) To me anyways (flame suit on), LC isn't that important. As I said though, others will say that they would never go back to a non LC unit after owning an LC. I've got a 9500 LC on my ceiling, but if you forced me to go to a plain 8500, I could certainly live with the unit with no problems at all.
3) Easiest to repair and set up: Barco and Electrohomes
4) Harder to set up, a bit noisier but a bit sharper: NEC XG. Not a set for the 'hands off, I don't want to learn CRT' person. (you don't sound like that guy)
5) A bit easier to set up than the NECs, but larger and heavier and harder to get parts for: Sony G70.
6) 9" set give (subjectively speaking) 20% more resolution, but generally are twice the price of an 8" set. Tube prices dictate this. For your budget, get a tricked out, mint tube 8" set, spend the $ to go DVI/HDMI, and spend some of the left over $$ on an HD DVD player or Blu Ray. I set up a Blu Ray with 1080i and HDFury card on a mint 9500 Ultra this weekend in Edmonton..... stunning! Customer was super happy as well. The 9500 Ultra replaced a power surge blown up Runco/NEC PG+.
Z-Photo
Posted: Mon Sep 24, 2007 1:18 am    Post subject:
Buy an Ampro......
they are the best.....................
Engineer by Day
Photographer by Night
My Portfolio
whats6x7
Posted: Mon Sep 24, 2007 1:31 am    Post subject:
Just couldn't resist, could ya Z?
Posted: Mon Sep 24, 2007 2:10 am    Post subject:
Z-Photo wrote:
Buy an Ampro......
Man all that LA smog is cloudin' your brain isn't it? lol
lyd,
I'd agree with Curt on getting an 8 inch. ( I know that sounds way dirty lol ) Then grab the HD Fury and a high def player and off you go. You already have the HTPC so you can do this well within budget.
As for the air coupled vs, liquid coupled I prefer the darker blacks with the LC but I have an AC, RPTV and an AC FP Sony that look great too. Black is black just not AS black.
rod
Posted: Mon Sep 24, 2007 2:12 am    Post subject:
Well, I'm also a noob (mentally speaking). I've been doing CRT since '99 but I still a two-year old mentally. I'm really happy with by Barco and it is somewhat easy to tweak (once you know a few not so obvoius tricks). It is nice an quite compared to my buddies NEC.
You make it sound like ceiling mount is difficult but unless you have a special ceiling I'd consider mounting it. It will give you lots of freedom configuring the seating arrangement. Also not so prone to bumps and scratches.
Rod
mack1
Posted: Mon Sep 24, 2007 2:14 am    Post subject:
Z-Photo wrote:
Buy an Ampro......
Oh thats a good one Mr. Green Mr. Green
Z-Photo
Posted: Mon Sep 24, 2007 12:15 pm    Post subject:
I am here all week folks -
trying out the Left Coast mindset.
Ampro Good
Bush Bad
Engineer by Day
My Portfolio
aspec2
Posted: Mon Sep 24, 2007 2:42 pm    Post subject:
Pete
Have you got your therapeutic pot licence? I'm surprised that Cliff hasn't moved.
Walt
scottap
Posted: Mon Sep 24, 2007 4:43 pm    Post subject:
I vote for the G70 that Curt is selling with the mint tubes. It sounds like it's in your budget, you've got the room for it, and I think it has the best balance of features/performance that you're looking for. While parts may be harder to come by than Barcos or Marquees, l think that's become less of a problem as it seems like more people are starting to sell/part out their G70s (but I'll defer to Curt on that one). It uses the same tubes as an XG so the sharpness should be similar. It's also (a little bit) quieter. While the XG does gives you more adjustment options than other sets, it also means there are more ways to screw it up. That can be an issue particularly if this is your first CRT projector. If you're paying someone else to set it up and calibrate it for you then it's less of a concern. You can also get great performance out of Barcos and Marquees, but to get the most out of them you'd probably want to mod them (add color filtered lenses, Mike Parker mods, etc.).
So all of your choices are good, but if I had the budget, I'd go for the G70.
Posted: Mon Sep 24, 2007 5:32 pm    Post subject: Re: Obligatory noob post. Please advise.
lyd wrote:
Greetings all.
well here's your first piece of good advice, don't buy anything from DaveLR in Scranton PA. One of his e-bay names is ekojaysabe and if you search DaveLR here and on AVS you will know why.
That's an awesome room, if I had 10 foot tall ceilings I would be running a pair of stacked over/under 8500's right now. 15 feet is too far back though, that should be the back row. If you HAVE to floor mount then the front row should be a pair of chairs to either side of PJ about 10 feet back from 92" wide screen.
You will be thrilled with an 8" set showing 960P from HTPC and 1080i from HD-DVD, there's just nothing that can touch this combo for less than $3K. My fave is the Marquee 8500 with optional color filtered lenses and moome DVI or HDMI input card. It's an excellent perfromer right out of the box, moddable to hell and back, and can even be made into a 9500LC. Thumbs Up
lyd
You asked some good questions and the answer is YES. I think $5K will cover a VERY nice HT including PJ, screen and 7.1 Dolby digital surround with very nice speakers.i'm assuming you have "some" equipment right now like a HT reiever at least but you might need some nice speakers to match your new PJ ? One way to save money is to buy a complete HT package. No not a Bose garbage one but a nice system from Energy or Mirage. Something like this with full size tower speakers and sub-woofer for $1200.
http://www.audioadvisor.com/prodinfo.asp?number=ENKC500&variation=CHE
then if you like you will have enought left over for a second pair of surrounds, a nice screen, or whatever?
Posted: Mon Sep 24, 2007 10:29 pm    Post subject:
Ampro Good
Bush Bad
Are we ever going to agree on anything AmPro related? As much as I like my AmPro's, I'll take bush over them any day, especially if they have been custom trimmed Laughing
lyd
Posted: Mon Sep 24, 2007 11:36 pm    Post subject:
Thank you all very much for your responses.
I would sure appreciate that!
I am definitely not that guy. I am afraid I am the "will probably spend more time tweaking it than watching it" guy.
That frightens me just a little bit. The overwhelmingly largest factor in deciding to buy the GAOO, way back when, was its absolute black blackity blackness. Of course, these days it tends to clip any detail below ~30 IRE, so I dunno. I do like black to be black, though. With any luck, killing every last stray photon in the room will be enough to make me happy. I can't paint it (at least I don't think I can, have to check with Mr. Landlord), so I guess I will be looking into curtaining the whole space, down the road somewhere.
These comments confuse me a bit. Are you referring to stand-alone HD-DVD/Blu-Ray players? Why would I want that rather than an internal drive(s) for the PC? Also, why would I prefer DVI or HDMI over RGBHV? The runs will be short.
I can appreciate the advantages, but it would be troublesome as I am an apartment dweller. Not impossible, and I will do it if it makes the most sense, but as I mentioned above I am going to look into placing it on an overhead structure fashioned from this sort of stuff first.
Oh man, I am really, really, trying to pretend I never heard of stacking, for the time being. That way lies madness. ;-) Talk to me when I get the audio sorted.
The seating is totally flexible, as I mentioned. I'll arrange it as need be.
Actually, no, I don't. I'm not concerned about rushing for the audio, initially I can just hack something together for surrounds that will tide me over. I have had my eye on a pair of KRK RP-8's for my DAW, anyway, and since that is against the back wall of the same room I might just use those for rears temporarily. I do want to upgrade my mains, and I have been coveting a pair of RBH TK-5CT's. I'll figure something out for a short-term center, or just kludge it in processing and run quad. For now I will feed signal to this stuff through the analog outs of my soundcard, as I am doing now for stereo. I can live with it. Eventually, my plan is a whole set of the TK series, driven from multiple Behringer A500's off a pre-only processor fed coax s/pdif from the pc. Not yet made a decision about sub(s), although that will probably be what I do next after the mains.
Meh. I think I would only do this if it got me a receiver with really nice preamps for no more than I would spend for a really nice preamp. ;-) Of course, it may do just that. I haven't really gotten around to shopping for a receiver/processor/pre yet, so I can't really judge what I am looking at in your link. (EDIT: Ooops, I didn't look closely enough at your link, there's no receiver there at all! See above, then, about speaker plans.)
All that last was wildly OT, sorry about that. I'll start a new thread to talk about audio when I am closer to doing something about it.
Thanks again to all! I will continue to read eagerly your comments and suggestions.
lyd
Posted: Mon Sep 24, 2007 11:39 pm    Post subject:
Lyd, sorry I speed read, and skipped over the part that you have a computer. Get a HD DVD or BR drive then, no need for a standalone unit. Go DVI/HDMI if you already have short runs.
NOw it's up to you whether to go with LC or not..Smile
lyd
Posted: Mon Sep 24, 2007 11:50 pm    Post subject:
Cool on the 'puter, but what I was asking about the digital output is why I should prefer it at all. With short patches and a decent quality breakout, will it really make a difference? Seems like I'd have more control over the D/A if I do it on my graphics card. (Not sure if there is any reason I need more control, but there you go. ;-)
Thanks.
lyd
Posted: Tue Sep 25, 2007 7:50 pm    Post subject:
full fade to black (FFTB) on any CRT is a function of electronics, NOT optics. When the G2 gate is electrically closed there are no electrons hitting the CRT Phosphor, period. Having an LC or AC has abosulutely no effect on how Black your room can go. LC only comes into play on mixed scenes where you have a bright object on a mostly black background.In this situation the background an on LC will be blacker. On an AC set this will also produce some degree of Halo'ing around the bright object which bothers some people and others not at all.
The real problem with CRT, as you've already noticed, is when you set it to FFTB, you crush all detail below 20 or 30 IRE. The reason Everyone loves the new Moome HDMI card is it has a custom Gamma curve that's ramped up at the bottom to give you excellent Black's without crush. It's explained here
https://www.curtpalme.com/forum_archived/viewtopic.php@t=5416.html
Now your thinking "well why can't I just boost Gamma in my PC". Well you can but it's not the same thing. Boosting gamma in my HTPC raised the entire black pedestal and washed out the FFTB at the same time. It wasn't even close to what the moome card delivered.
I have no experience with the speakers you posted, never even heard of them really. However one thing I would suggest is don't even buy a receiver. They're really a waste of money and the amps in even the best receivers are always really a joke when asked to drive 5 or more speakers. For your first system, a seperate pre-amp/amp combo like this one from Emotiva Ultra theatre Series for $900. will just stomp all over the best receivers.
http://www.emotiva.com/products.html
lyd
Posted: Tue Sep 25, 2007 10:17 pm    Post subject:
Sorry, I guess I wasn't clear. I am familiar with what you're describing. When I said I wanted to eliminate all stray light I was thinking of reflected light from just the sort of high-contrast scenes you are describing, bouncing back off the walls and ceiling and washing out whatever black level I do have.
I have heard of this, and it is one of the biggest reasons I am really hoping I can take a look at a something before I buy. I am really sensitive to, and distracted by, DLP rainbows, and this sounds unpleasantly similar.
This set did not always have that problem, it appeared with age. When it was new it just had great shadow detail and deep black.
That's very interesting! Thanks, I'll look into it further.
I couldn't agree more. Like I said above, the only reason I might get a receiver is if it was a steal and had good quality pre outs, because that is all I would ever use on it.
I think I know where I am going with amps, but the preamps there are certainly interesting for the price. Never heard of Emotiva before, but I'll definitely see what I can learn about them. Thanks a second time.
lyd
lyd
Posted: Wed Sep 26, 2007 1:11 am    Post subject:
Sorry to double dip here, but after looking at what the Moome is doing, it seems to be exactly what I have been doing with my PC.
When you say you changed the gamma and blew out your deepest blacks, were you tweaking the curve in the driver or wherever else in the chain, or just raising some global gamma setting?
lyd
Posted: Wed Sep 26, 2007 6:17 am    Post subject:
lyd wrote:
circumcized.....
Oh the fade to black is great on the Sony. It's just a matter of more contrast with the LC projector and less halo'ing. The haloing isn't too bad on the Sony 1252, my RPTV has quite a bit more. The Ampro 4000 doesn't do it. Mainly because it's not working (lol) but when I had it running it didn't halo. I do remember the first time my buddy Drew and I compared the Sony to the Ampro using the DVD 'Cars' we both went 'WOW!' The LC just adds that extra contrast when you have a bright area on a dark background. ( We used the scene where the 4 tunners were playing catch with the sleeping rig for our comparisons )
I just went ahead and painted it. All they can say is they don't like it. Then you tell them you'll paint it white when you leave.
lyd[/quote]
I was actually refereing to a stand alone for the high def stuff and use your PC for DVD, but that was before I found out about the new LG combo BluRay/HD-DVD rom drive for $299. If your PC has the horsepower then certainly add the drive. I use an X-box HD-DVD drive for high def now. My PC is a 4600 AMD dual core with 4GB ram. Others have used lesser machines though.
What speed/cores is your HTPC?
lyd
Posted: Wed Sep 26, 2007 9:45 am    Post subject:
C2D E6600, 2GB, 7900GTO
I don't foresee any problems in that regard.
lyd
