Goto page Previous  1, 2, 3 ... 30, 31, 32 ... 126, 127, 128  Next
Posted: Thu May 06, 2010 2:59 pm    Post subject:
Are you all fixed now Mike?
Does this mean you're ready to go head to head with the beast Wink
Posted: Thu May 06, 2010 6:38 pm    Post subject:
Well, not quite yet. Wait 'til I do the next three rounds of mods....then I'll be ready for the Ampro.
You think it'll still be working by then..Mr. Green
Posted: Thu May 06, 2010 9:43 pm    Post subject:
Whimp Laughing
The only mods to the beast is the neck boards to use the Thomas tubes, R and G c-elements and cooling.
Posted: Tue May 11, 2010 2:05 am    Post subject:
More 1080P 72hz - UnTouched
Posted: Tue May 11, 2010 4:28 pm    Post subject:
Just for starters.....
Nashou Got Blend?
Posted: Tue May 11, 2010 4:40 pm    Post subject:
Here are some more. Sent my i1 pro to be checked out. Not sure what the issue is but i know if i could get it all done with a probe instead of by eye it look much better and the blend zone would totally disappear. its still there in dark pans and in bright scenes. This is why you never see me post a full sky shot etc...
Chronicles of Narnia Movies are my Favorite reference discs. Great Cinematography and colors along with a top notch transfer.
More to follow
Got Blend?
Posted: Wed May 12, 2010 12:58 am    Post subject:
Some 12 feet of Rodan-O-Blend!!!!!
Remember these are 8 inch AC Pj's
Posted: Wed May 12, 2010 11:53 am    Post subject:
A few quickies (not warmed up) @ 1080P 72hz - UNtouched!!!
Posted: Thu May 13, 2010 12:06 am    Post subject:
More RAW 1080P @ 72hz...
Posted: Sat May 29, 2010 12:34 pm    Post subject:
I did this on the Sony about 2 minutes before my arcing issue started, about 20 minutes of operation after installing 9.9 rated 07MS tubes....
Was taken with a pretty average camera, quite average to say the least.... Laughing
winduptoy
Posted: Sat Jun 05, 2010 11:41 am    Post subject:
New Stuff after setup redo andle ns swap...
Posted: Sun Jun 06, 2010 9:58 am    Post subject:
Still raw 1080P @ 72hz - UNtouched!
Posted: Sun Jun 06, 2010 6:14 pm    Post subject:
I'm not going to post any screenshots at this time as my PJ is coming due for a variety of upgrades including a much needed coolant change in the blue LC chamber. It's getting green around the edges.
AFTER it gets its upgrades and is back up to its full capabilities, I'll have some pics to show you. I fully expect those pics to be as good as any that have been seen here so far.
But, I'd like to suggest that you should definitely use Planet 51 as some demo/screenshot material. It's a great flick and absolutely
stuffed full of eye candy as well.
CJ
dvh99
Posted: Fri Sep 03, 2010 3:30 pm    Post subject:
not my focus module, just some quick static focus no dynamic changes were made.
dont mind the blue haze it is clouded glycol.
edit: horizontal lines are from the camera (5volt adapter, it needs 3 1/2)
lots of ambient light and all white walls.
contrast is at 65
res: 1920*1080 72hz
Posted: Fri Sep 03, 2010 5:20 pm    Post subject:
Nice detail Dennis, get that fungus sorted out soon!
Some blend pics to follow.
Posted: Fri Sep 03, 2010 5:22 pm    Post subject:
Posted: Fri Sep 03, 2010 5:23 pm    Post subject:
Hi Guys, I finally got the Radiance XS's hooked up and figured out some bugs in Calman v4. I still have an issue where my i1 pro does not like to read the 75% IRE red to well. So i will attempt another calibration with all 100% gamut windows. i had to turn the probe to face the screen with no filter to get a decent consistent reading and adjustment. And then i checked again facing the screen and it actually read a bit better but still not each time.
I did a couple runs on the left PJ and only one on the right. there is a slight luminance difference and that makes a huge difference in getting a perfect blend zone. But this is by far the best i have had it. And with no Zone contrast modulation done. I still have to decide how i want to tackle that one. To bad Calman v4 did not interact with the marquee and two probes to do the zone contrast. I think I need andre to write the code for that Wink
So for now this is the best I got, and the usual suspects screen shots of my favorite reference disc The Chronicles of Narnia: Prince caspian.
My Personal favorite screen frame to use.
More to come, didn't want to fill up one post.
dvh99
Posted: Fri Sep 03, 2010 6:18 pm    Post subject:
your pics are much darker then mine.
they are breathtaking btw.
Posted: Fri Sep 03, 2010 7:15 pm    Post subject:
Hi Dennis, looks like you have brightness to high and your washing out the colors. But fungus laden blue Glycol chamber is not helping at all. You will not be able to get white balance done correct with it.
winduptoy
Posted: Fri Sep 03, 2010 11:27 pm    Post subject:
Nash; those screenshots are da bomb! Haven't seen Prince Caspian yet...have to check it out. Your shots with the radience are really sharp! Congrats; you've been working on this a long time.
Page 31 of 128
