Goto page Previous  1, 2, 3 ... 29, 30, 31 ... 126, 127, 128  Next
dvh99
Posted: Sun Apr 18, 2010 6:14 pm    Post subject:
nashou get a pro over with professional equipment and be done with it damnit....
lol, tell me how much time did you have in this blend already and when will it be good enough.
maybe you can ask the members here to donate.
dennis
Posted: Sun Apr 18, 2010 6:35 pm    Post subject:
dennis
I had Craig over twice, once before I had my first Marquee. he is a Mitsubishi expert and that looked AWESOME!!!!!
So when i got the Marquee i had the red tube go out on the mitsu. The repair shop messed it all up and Craig came back and did both over a two day period. He spent a good 12-14 hours on the marquee.
I talked to him the other day and if I can not dial it in I might have him have a try at it. it be his first blend. but to be honest I have to say once both PJ are measuing each shade of grey with the same Gamma and even RGB values there will be no blend zone visible at all. Right now i have the blend zone invisible 90% of the time up from about 75 %. With each session
I get closer. and this set up I am using no gamma at all from the Lumagens yet. Just one bump up on each Moome card.
The i1 pro worked great when i had one single PJ up and tested it out, that was on the marquee 8500 test bed i had on the floor in the theater. I got great results, for some reason now i just cant get proper readings. I sent it back for the LED calibration tables to be added for an enhancement. I think they should have checked it then, but it came back reading the same way. Spectracal is suppose to get back to me on their forum, no word yet.
Posted: Sun Apr 18, 2010 8:15 pm    Post subject:
Well if you are saying that you measure D6500 or close to it on a 80-100 IRE window and it is obviously not white, then it must be the test equipment. You can be quite a bit off the mark and still "percieve" what you're seeing as white even though it's not.
Is there a forum member close buy with their own equipment that can confirm it for you?
Posted: Sun Apr 18, 2010 8:47 pm    Post subject:
I was thinking of asking Alan Gouger if he has an i1pro I could use. Bob Stephan sent me his Display 2 probe but it is a few years old and they do not keep well after a year.
I'll try his in the mean time but filter type probes loose reliability over time where spectrometers do not, well are not suppose to , I think mine might be the one in a few thousand that do. Wink
And its not only the whites but all IRE's down have a greenish or lean to brownish as I go lower in IRE. So it looks like i push red in the low end and push green in the high end.
dvh99
Posted: Sun Apr 18, 2010 9:53 pm    Post subject:
hi nashou have you tried measuring with just 1 pj turned on, read out the grayscale with the i1 then write down those numbers turn off the pj and turn on the other pj and try to get the same readings.
maybe the i1 isnt good enough for measuring 2 pj`s at the same time, maybe its the sweeping of the scanlines from 2 pj`s that interfere for a good readout.
have you tried different scanrates and then measure the grayscale.
72 hz might be too much the i1 might do a better job at 50hz or so, i am just guessing here but i would definitely try that.
dennis
Posted: Sun Apr 18, 2010 10:02 pm    Post subject:
I only measure one PJ at a time.
I do not think Refresh rate matters for reading of the screen and is only really an issue for direct view CRTs i believe, and this probe is also made to calibrate CRT computer monitors and they can scan high as well. I don't think its that but anyone?
Posted: Thu Apr 29, 2010 3:27 am    Post subject: 12 Feet of Blend Baby!!!
In this one you can see the blend Zone. This was all done by Eye, I know my probe is messed up, it took 10 tries to read the red 75% window when checking the Gamut.
SurprisedSurprisedSurprised
Nashou!!!!!!!
studio
Posted: Mon May 03, 2010 1:10 am    Post subject:
Please go easy on me. Still not home yet but getting there. 1209s & PS3 BD set to 1080p. Unaltered pics.
Posted: Mon May 03, 2010 1:32 am    Post subject:
Those look great Studio!!!!
huggy
Posted: Mon May 03, 2010 6:51 am    Post subject:
Nash
The one of Telly Savalas............Awesome!!!!!!!
12 ft wide blend must be a real sight! I'm envious as hell Very Happy
joatmon
Posted: Mon May 03, 2010 1:35 pm    Post subject:
Be gentle... Smile
 Filesize:  92.98 KB
 Viewed:  7754 Time(s)
 Filesize:  84.96 KB
Posted: Mon May 03, 2010 1:52 pm    Post subject:
My son purchased Avatar last week. I had it on my setup and it's one of the strangest movies I've seen so far. It's an entirely different image type from anything I've seen before..Shocked
However, I'm looking forward to capturing a few shots tonight from my Super 9500..Mr. Green
winduptoy
Posted: Mon May 03, 2010 2:14 pm    Post subject:
Studio; Really nice looking shots. Geometry and color look very good. Is your machine color filtered?
winduptoy
Posted: Mon May 03, 2010 2:17 pm    Post subject:
Joatmon; Color looks pretty good. Highlight look a little roasted - try a stop less exp with the camera and see what happens. What PJ are you using?
joatmon
Posted: Mon May 03, 2010 2:22 pm    Post subject:
Thanks, I'll try that.
PJ is a low hour Cine 7 with a Runco label (late model 70x chassis with P16 tubes and color filtered lenses). 1080i from PS3 via Fury2.
edit: P16, not P14 Smile
studio
Posted: Mon May 03, 2010 2:34 pm    Post subject:
Yes, has the filters.
Posted: Wed May 05, 2010 4:01 am    Post subject:
Been busy, but did get to finish the magnetics today...
Un-touched 1080P 72hz
winduptoy
Posted: Wed May 05, 2010 9:36 am    Post subject:
Wow! decent geomtry, Mike. Now your stuff will be a lot easier to look at.
winduptoy
Posted: Thu May 06, 2010 3:09 am    Post subject:
Finally had a minute to shoot some new screens...
Posted: Thu May 06, 2010 12:58 pm    Post subject:
Un-touched 1080P 72hz!
Page 30 of 128
