| Posted: Wed Feb 10, 2016 1:39 am Post subject: |
Now back to my Panasonic...
| Posted: Wed Feb 10, 2016 11:58 am Post subject: |
After almost two months, I finally got around to touching up the focus. And for the second time since then has done a full convergence. Still need to get into the stig and really tighten the focus up, but still not sure of what neckboards will remain in the projector at this point.
Right now I have my recently upgraded older Electrohome neck boards, that still needs more work. The newer VDC are to my opinion finished. Near perfect everything. Smpte, linearity, tracking, stability, zero shifting, runs cool, etc.
I kept saying I was going to tighten the fucus and dial things in better, but only did another but more detailed quickie. Anyway, I'm gearing up for a project that will keep me tied up somewhat, so thought I'd make this happen this morning.
| Posted: Thu Feb 11, 2016 2:51 am Post subject: |
| Posted: Thu Feb 11, 2016 2:11 pm Post subject: |
| Posted: Sat Feb 13, 2016 1:04 am Post subject: |
Got another BluRay player...
| Posted: Sat Feb 13, 2016 12:33 pm Post subject: |
Trying to capture what's on my screen...
| Posted: Mon Feb 15, 2016 2:12 pm Post subject: |
This is my setup with the recently upgraded 300mhz neck boards (Electrohome)
The higher bandwidth makes them sharper, but they also capture more hash noise
| Posted: Mon Feb 15, 2016 10:56 pm Post subject: |
Back to the 300mhz boards. I'll ned a better camera for these
redfox001
| Posted: Tue Feb 16, 2016 5:12 am Post subject: |
Multipass! made some time ago to see if it still holds. Perhaps I make some new nothing good probable.
Luuk neele
Joined: 04 Mar 2015 Posts: 186 Location: Wijk bij duurstede, the Netherlands.
| Posted: Wed Feb 17, 2016 1:17 pm Post subject: |
how come that the colors on the panasonic seem to be largely on the reddish/orange side?
is that due to the camera? the crt looks much better, awesome job on the tune-up and modifications btw.
GREG1292
gregstv
| Posted: Thu Feb 18, 2016 6:42 am Post subject: |
| redfox001 wrote: | Multipass! made some time ago to see if it still holds. Perhaps I make some new nothing good probable.
Hey Fox, I think the Multipass would be out of date by now.
redfox001
| Posted: Thu Feb 18, 2016 9:59 am Post subject: |
Remarkable in Mike's shots to see the corner bandwidth. I noticed that too with 9518 new neck and lug.
redfox001
| Posted: Thu Feb 18, 2016 10:09 am Post subject: |
image by Radio Head, on Flickr
| Posted: Thu Feb 18, 2016 1:30 pm Post subject: |
| Luuk neele wrote: | how come that the colors on the panasonic seem to be largely on the reddish/orange side?
is that due to the camera? the crt looks much better, awesome job on the tune-up and modifications btw. |
Not sure about the colors, but can say it may be because the colors have not been balanced. But apart from that I've never really liked the colors on the Panasonic. Its plus is sharpness and detail
| Posted: Thu Feb 18, 2016 1:37 pm Post subject: |
| GREG1292 wrote: | Good job Mike been awhile since I looked at this thread and you have alot a punch in those shots. You are only
camera and lens limited for even showing more impact. Enjoy your projector and relax you are entitled. |
I'm thinking about getting another camera for sure, but for right now I'm thinking to bottom her up. I need to work on the focus and then get back to fixing the gamma stage on the VIM for best tracking
| Posted: Sat Feb 20, 2016 6:20 am Post subject: |
Did someone say LUG's were dim in a Marquee?
The following shots from here on have the resistor change on PIN 7 of the neck boards for proper LUG usgae.
And I'm using the Sony Blu Ray (The Panasonic won't play Kong)
GREG1292
| Posted: Sun Feb 21, 2016 2:49 am Post subject: |
I took these earlier today and forgot about them
| Posted: Sun Feb 21, 2016 8:12 am Post subject: |
XG1351 LC @ 1080i-96Hz
Note the bandwidth of the machine barely reach 30MHz (-3dB), no further signal manipulation was involved. A bit too dark exposition i know...
| Description: |
| Filesize: |
162.55 KB |
| Viewed: |
4832 Time(s) |
