Sony 09MX 9" Tubes Work In a 1292-Yes or No
Phil Smith
Posted: Wed Mar 28, 2007 1:26 pm    Post subject:
Well I guess Graham is off on a bender again. And we thought we had finally got him cleaned up. Mr. Green
As disappointing as the lack of a response from Graham is, nothing can ruin my day today. After being down for 2 days, my G70 is back up and running. Life is good! Thumbs Up
Graham Johnson
Posted: Wed Mar 28, 2007 9:00 pm    Post subject:
I havent been home for a few days. (work) I will look tonoight for you Phil.
GJ
Graham
Phil Smith
Posted: Wed Mar 28, 2007 9:25 pm    Post subject:
Thanks Graham! I was just kidding around. I assumed you were busy.
Ile
Posted: Wed Aug 15, 2007 11:39 pm    Post subject:
So we still don't know answer to this question?
My red tube just died from my BG1200. Sad
It had few pops, flickering and had nice blue arc inside neck. Shocked
First I though that I dropped something inside pj, since I was just adjusting back end cards.
But when I looked to red tube I realized that tube was sucked glycol inside tube between bell/faceplate seam.
It seems that white goo doesn't tolerate glycol, good thinking Sony. Thumbs Up
It's not bad idea to remove c elements and add good layer of silicone between front glass and lc chamber to these tubes.
Posted: Thu Aug 16, 2007 4:56 am    Post subject:
Ile. Sad to hear about that tube failure.
Hurry up :
http://cgi.ebay.de/Sony-VPH-1292-09MFX3-Roehre-ROT-CRT-Rating-9_W0QQitemZ290148510811QQihZ019QQcategoryZ75403QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I think that even small mechanical stress to tube can make that white "goo" to leak and suck air in... Then you got expensive fireworks. Crying or Very sad
DVDO VP-50
New hobby, Rally
Ile
Posted: Sun Aug 19, 2007 4:03 pm    Post subject:
Removed Barco sticker and Sony sticker says 09MI (R).
Projector and red neck card seem to be ok.
Ile
Posted: Mon Sep 17, 2007 8:11 pm    Post subject:
Just got new red 09MFX3 out of customs. It have 14 mm longer neck what 09MX and 09MI have. Other dimensions and pin out is same. Don't know yet if there is enough room in my BG1200...
Ile
Posted: Mon Oct 01, 2007 6:04 pm    Post subject:
It seems that BG1200 have enough room for 14 mm longer neck, I can even remove neck card without removing whole tube. Laughing
oliverg
Posted: Mon Oct 01, 2007 10:18 pm    Post subject:
Great news mate, good one!
If anyone can make those nice ol' Barcos work its you Ile Smile
speedyandre
Posted: Tue May 27, 2008 7:34 pm    Post subject:
Ok this topic is OLD Laughing
Has Graham ever compared the tubes and pics in this topic Question
I've emailed him about 09MX tubes being ok for a Sony 1292 but I didn't get a reply Embarassed
I guess that 2 cut pins are a problem, but the pinout of the 09MX and 09MFX3 seem to be the same.
That the 09MX is a bit shorter then a 09MFX3 is good news, but I doubt if the cut pins could be repaired and I don't know for sure if they are needed in a Sony 1292 ....
I'm still looking for a blue 09MFX3 tube.
André
I'll be broke
Graham Johnson
Posted: Fri May 30, 2008 4:27 pm    Post subject:
I havent ever used the MX version. But I expect that if it is smaller it wont be able to be used as the deflection/astig coils wont be in the same position in both tubes.
I I have only ever substituted the MFX2 for the MFX3 with the LC chamber swapped
Graham
