Barco 1209s - No Picture
Rittberg
Posted: Wed Jun 26, 2024 7:36 am    Post subject: Barco 1209s - No Picture
Yesterday my Barco 1209s started losing the picture after few minutes.
Tried several times to power again, the picture was gone after a minute. No picture from the source and no picture from the internal as ‘Set Up” etc.
So I start replacing the spare modules one after the other (Used parts purchased during many years) after each replaced part I checked to see if the if the problem was resolved:
I start with the QUADRUPLER -> SPLITTER -> SMPS -> and then all the boards from the MAGNETIC FOCUS & HOR. SHIFT -> SM POWER SUPPLY 2 + G2.
But NO GO – no any picture.
After all I ( I had to check it first…..) checked the EHT (R7617427)and I find the 2A fuse was blown.
Replaced the fuse but once again the fuse blown.
I put another EHT (R7627165) I see a very small size picture appear ,So I replaced with another EHT (R7617427-03) , I heard some noises (similar to blown fuses ) I shut down immediately the Barco.
Replaced the EHT to another once but no picture (checked the fuse and they are OK).
Once again checked the SMPS (replaced with a spare one) but no picture.
Can it be that the EHT damaged the replaced QUADRUPLER or the SPLITTER ?
I will appreciate to any Idea how to proceed .
Attached pictures from the Barco:
 Filesize:  497.54 KB
 Viewed:  1333 Time(s)
Rittberg
Posted: Wed Jun 26, 2024 7:50 am    Post subject: Additional picture
Additional picture
 Filesize:  368.21 KB
 Viewed:  1323 Time(s)
Hulio
Posted: Wed Jun 26, 2024 9:42 am    Post subject:
Check first if the red led on the EHT board is lit. If yes, the quad, splitter, EHT could be defect, or you have a shorted tube.
Aso, be aware that not each combination of mainboard/quad/EHT will work.
Rittberg
Posted: Wed Jun 26, 2024 11:20 am    Post subject:
Hello Hulio,
Thank you .
Before you replied I already replaced once again the quad, splitter and the EHT.
I checked the EHT and one red led (in the attached picture) is on, do you mean this one ?.
I diconected the 3 cabels from the splitter and the Red led keep to be on .
Is there any other way to check if there is a shorted tube ?
 Filesize:  227.7 KB
 Viewed:  1312 Time(s)
Rittberg
Posted: Wed Jun 26, 2024 12:39 pm    Post subject: After replacing to another EHT
After replacing to another EHT , now the red led is in another place . is it normal ?
still no picture .
 Filesize:  266.7 KB
 Viewed:  1305 Time(s)
bluemoonhu
Posted: Wed Jun 26, 2024 2:02 pm    Post subject:
Please carefully check the EHT board. The resistance and triode.
Rittberg
Posted: Wed Jun 26, 2024 2:16 pm    Post subject: EHT board
Thanks.
I have 5 EHT and I mount all of them one after the other.
The original one continue to blow the 2A fuse. but with the others No picture and a red led is on(in different places).
bluemoonhu
Posted: Wed Jun 26, 2024 2:26 pm    Post subject:
Please use the multimeter to check, the fault is easy to find
Rittberg
Posted: Wed Jun 26, 2024 2:59 pm    Post subject:
Where in The EHT should Check ?
bluemoonhu
Posted: Thu Jun 27, 2024 1:39 pm    Post subject:
 Filename:  QQ图片20240627213721.jpg
 Filesize:  306.26 KB
 Downloaded:  60 Time(s)
bluemoonhu
Posted: Thu Jun 27, 2024 1:40 pm    Post subject:
 Filename:  QQ图片20240627213810.jpg
 Filesize:  337.86 KB
 Downloaded:  61 Time(s)
Rittberg
Posted: Thu Jun 27, 2024 2:21 pm    Post subject:
In order to check and to reach the points you have mentioned , I should remove the Quad,
I understand that to check the points you indicate I should power on the Barco ?
Thanks.
bluemoonhu
Posted: Thu Jun 27, 2024 2:40 pm    Post subject:
Remove the EHT board from the machine and measure them with the multimeter
Rittberg
Posted: Thu Jun 27, 2024 2:53 pm    Post subject:
So what I can check with the EHT removed is only the resistance ?
bluemoonhu
Posted: Fri Jun 28, 2024 12:10 am    Post subject:
 Filename:  QQ图片20240628080751.jpg
 Filesize:  328.73 KB
 Downloaded:  78 Time(s)
Rittberg
Posted: Fri Jun 28, 2024 3:12 am    Post subject:
Hello,
Thanks for advices,
my original mounted EHT that keept blowing the 2A fuse looks different from the one in your pictures.
The EHT original pictureת is attached.
I have 4 spare EHT , one that looks indentical to the original and another 3 that looks identical as in your picture .
I installed and checked all my 4 spare but no picture, but I can see the a red led is on (in different place) depended in EHT one that is instaled .
Thanks for your support.
 Filesize:  294.41 KB
 Viewed:  1208 Time(s)
bluemoonhu
Posted: Fri Jun 28, 2024 3:27 am    Post subject:
My EHT board is used for Barco CINE9, you need to test similar components
Rittberg
Posted: Fri Jun 28, 2024 2:43 pm    Post subject:
Installed once again an identical EHT, after starting the Barco the red led "EHT Hold Down" is on .
Any Idea ?
 Filesize:  103.71 KB
 Viewed:  1186 Time(s)
bluemoonhu
Posted: Fri Jun 28, 2024 3:17 pm    Post subject:
Hulio said:Check first if the red led on the EHT board is lit. If yes, the quad, splitter, EHT could be defect, or you have a shorted tube.
--------It seems that you need to check three tubes separately for short circuits?
Rittberg
Posted: Fri Jun 28, 2024 3:54 pm    Post subject:
How do you check the tube? do you mean to disconnecting the red cable coming from the splitter or from another place ?
