Barco Cine 9 background video noise/grain
ElTopo
Posted: Tue Mar 20, 2018 5:51 pm    Post subject: Barco Cine 9 background video noise/grain
Hi all,
my Cine 9 is running fine but i have some kind of extreme background video noise. I'm not talking about film grain.
Same on port 3 or on port 5.
Tried 3 different cards (moome and fury). With all the same behaviour.
Swapped also the complete front tray to test but also the same.
Tubes are brand new.
What do you think ? Video Input board / Driver board issue ? Power Supply ? EHT ?
cheers
ElTopo
Barco Cine 9 the one and only
ElTopo
Posted: Tue Mar 20, 2018 6:24 pm    Post subject:
Found that but what is/was the solution ?
https://www.curtpalme.com/forum_archived/viewtopic.php@t=37698.html
HaydnG90
Posted: Tue Mar 20, 2018 7:12 pm    Post subject:
Are you feeding the pj a signal? Is the noise visible on internal test patterns too? HDMI cable issue?
ElTopo
Posted: Tue Mar 20, 2018 7:23 pm    Post subject:
Signal is coming from an Oppo with HDMI (checked also different cables but the same).
I have to check the internal pattern.
HaydnG90
Posted: Tue Mar 20, 2018 8:14 pm    Post subject:
I would also check the player just to rule that out too. Is the noise visible on the tube faces and on all 3 colors. My Barco 808S would show noise on green with and without video signal.
ElTopo
Posted: Tue Mar 20, 2018 9:14 pm    Post subject:
Checked all three colors and it's on all of them.
Also the internal genlocked pattern shows that noise.
So the player/signal should be out ?
dvh99
Posted: Wed Mar 21, 2018 10:28 am    Post subject:
try connecting the pj to a wall outlet that is not grounded or unplug all other earthed devices.
ElTopo
Posted: Wed Mar 21, 2018 1:15 pm    Post subject:
Thanks. All power outlets are grounded here.
Posted: Wed Mar 21, 2018 1:58 pm    Post subject:
if you have a spare power supply and/or controller card, swap those out to see if the problem goes away.
ElTopo
Posted: Wed Mar 21, 2018 2:54 pm    Post subject:
Thanks Curt.
Tried that but no success.
I'm investigating further....
wanderer
Posted: Wed Mar 21, 2018 6:32 pm    Post subject:
If you set convergence and geometry temporarily to midpoint, does the noise in the image change at all?
dvh99
Posted: Wed Mar 21, 2018 6:51 pm    Post subject:
then unplug all other devices that are grounded and disconnect your video source.
good luck
HaydnG90
Posted: Wed Mar 21, 2018 6:53 pm    Post subject:
Can you take a pic of the noise. Might be easiest to see on the green. Sometimes that can be indicative of the problem.
ElTopo
Posted: Wed Mar 21, 2018 7:13 pm    Post subject:
[quote="wanderer"]If you set convergence and geometry temporarily to midpoint, does the noise in the image change at all?[/quote]
No, i did a reset to midpoint already.
ElTopo
Posted: Fri Mar 23, 2018 3:22 pm    Post subject:
Anyone tried 817p@96 in the Barcos ?
ElTopo
Posted: Sat Mar 24, 2018 6:26 pm    Post subject:
Checked Oppo 203 vs Oppo 93 with the same rez.
The Oppo 93 shows less video noise.
Pzyked
Posted: Sun Apr 08, 2018 4:51 pm    Post subject:
Is this projector a real Cine9 or rebuilt 909 to "Cine9"?
Do you see this all the time? In white and black, in all material?
ElTopo
Posted: Sun Apr 08, 2018 7:15 pm    Post subject:
it is an original Cine 9 (CineMax).
Mostly visible on very bright scenes (like a Sky with CloudKit) and bad UHD/BluRay masters.
cheers
ElTopo
Posted: Mon Apr 09, 2018 6:14 am    Post subject:
Whats the difference? Apart from the coloured C elements and firmware aren't these units the same?
ElTopo
Posted: Mon Apr 09, 2018 8:57 am    Post subject:
Yes, these are the same.
Only difference is the fan control. Otherwise 1:1
