MPMODS - my latest
Goto page Previous  1, 2, 3 ... 8, 9, 10, 11, 12, 13  Next
Posted: Mon Apr 03, 2017 9:38 am    Post subject:
Nope, the Thomson focus yokes ARE inferior, the only reason they're in a Marquee is because Electrohome determined that they were "good enough" to meet the simulator resolution requirements of their military and commercial simulatior customers, and they did not feel it necessary to invest the money in re-engineering the platform to run K-D focus magnetics.
The difference between focus performance of the Thomson yokes and a G90 yoke in a modified machine is NOT SMALL.
I have done enough of these experiments to prove quite clearly, to my complete satisfaction, that the Thomson yokes are inferior,
and in fact they are the worst ones found in any projector you ever heard of. They'e just barely better than JUNK.
In actual fact a G90 focus yoke is PERFECT for a stock Marquee. But for ONE problem: The stock deflection/convergence yoke assembly is too long and doesn't allow the G90 focus yoke to be placed where it needs to be. It's too long.
But G90 deflection yokes are shorter and allow for proper focus yoke placement, which is obvious as that's how they're installed on a G90.
But there are electrical compatibility issues with the deflection yoke. A problem that I BELIEVE I'm just one more experiment away from solving, as I have already been able to run ONE G90 deflection yoke in a Marquee after changing a single component value on the HDM. With that G90 deflection yoke and focus yoke running on that tube, its performance was fully equal to the focus performance and stability of a G90's focus system. It was RIGHT, possibly the first time ever that a Marquee has focused CORRECTLY.
Posted: Mon Apr 03, 2017 10:40 am    Post subject:
cmjohnson wrote:
As for LUGs having a lack of sharpness, I myself have not experienced this issue except when using OLD versions of Marquee circuits. The newer revision boards made for Ultras seem to handle LUGs just fine, and there are simple ways to optimize the
neck cards even further for use with LUG tubes.
The original marquee neck boards were not designed around the LUG tube, and that is why they would have a focus issue in comparison. And a stock marquee board would need certain changes made to it to properly work with the LUG tube.
It was a complicated process for me to make happen, and when that is accomplished, there are two things you should look for beyond the basic foot Lambert test, which does not take in consideration how well the circuit maintains it's "SPEED" at the higher operating levels. The test is also complex in this regard...
Check out what thewolfman said after getting my last version boards:
thewolfman wrote:
You redeemed yourself Parker! I'm now running contrast at 100 without blooming. It's amazing to ramp contrast that high and watch nothing happen with the grid pattern. No smearing or anything. But settled with 80 which was as high I could go before. There is no audible noise as I ramp up the contrast either but that may be with the help of fresher parts in combination.
Now let me go a little in-depth on the LUG tube design and purpose. It was the Panasonic CRT line best of the high resolution 9" CRT's for projected images. As such, it required a very different design around it's pins, and that is why it also has that HK grid. The LUG tube has very different GUN's, and produce a smaller spot size, and because of that spot size difference it required a different neck board design. And there is really more to in than changing or adding an HK resistor.
When properly done, and higher resolution tube should project and maintain that "smaller spot size" as you drive up the gain to it. So using the Foot Lambert test without also doing a resolution test means nothing when dealing with these type of CRT's. And that is what "thewolfman" has pointed out in the quote. It's not about brightness alone, it's also how well it maintains both spot size and brightness level, when HIGH Resolution is involved.
The LUG tubes were used in both G90 and Barco 909 for this reason...they could be driving HARDER (more light output), and both had neck boards designed around the tubes. And it is the neck boards of the G90 that' really makes for their tighter focus...when test were done years ago by Galen, not sure what the combination was, we all learned that the Tubes used in the G90 were different from what was being used in the Marquee (LCP). And we have since found out, regardless what projector you put either tube in, the neck boards play a very significant role. And that is why the LUG CRT when used in a Marquee, does not have the same focusing ability as the LUG tube when used. The neck boards would need to be designed around the tube, and the process of making that happen is not simple one, thought the component change is not complex.
The last posted image of the "Bee" shows an absolute deep black at 1920X1080P 60hz. What that deep black represents at that bandwidth is a VERY fast video chain. meaning also that it has tremendous headroom (bandwidth capability). Because the deep black really shows first off, how well the LUG tube is working with the video chain (compliment). And it also shows how clean the signal is being maintained from point A to B (source to screen). Because once you get beyond 800X600 resolution, maintaining absolute black because the challenge...because in order to produce absolute black, your video chain HAS to be clean and fast, to include have enough bandwidth headroom. And when properly mated to the RIGHT CRT, you would be able to achieve both controlled spot size (as thewolfman mentioned) and absolute BLACK, which means you have full control of the complete turn on/off of the CRT.
Once more, I was not able to accomplish this until I got my hands on that Test Jig that Scott sent me. Once I got that in hand, it was game over for me. This is my last version, mission properly accomplished!
My neck boards drive the CRT so hard that the Beam Limit circuit starts muting the image and that's even before a contrast of 100...that was the original intent of the circuit, so I have it doing what it's supposed to do..Mr. Green
Absolute BLACK should be the REAL test for bandwidth and video chain performance - that's when you know your video chain has both speed and low noise performance at the suitable viewing gain...
racerxnet
Posted: Mon Apr 03, 2017 11:07 am    Post subject:
But Mike,
Others are getting 65fl on a 110" screen with select neck cards. And your colors are horrid! Gasp, its not calibrated! Hope all is well and thanks for your efforts in moving the CRT community forward.
MAK
racerxnet
Posted: Mon Apr 03, 2017 11:30 am    Post subject:
greg9518lc wrote:
GIJAKY has helped with Kurts question why lugs don't focus and together they have solved it. I have respect for
all develolers on this forum and I am sure Gjaky will be glad to share this . Look forward to mp/gjaky/kurt continued
passion to push the marquee to the next level. It is now obvious that the stock marquee magnetics are not the problem
as we are now able to acheive 10frtl on 110".
What exactly from a technical perspective and engineering point has Kurt provided the community? Has he developed anything from his own making? DO you 2 have something we can purchase for our CRT? So far I see personal vendetta, constant bashing, verbal and abusive language, getting kicked off multiple forums, a grinding attitude, and this is just a start. The reason I bring this up is because anytime someone posts shots, Kurt and you are quick to point out all the flaws. "Theirs vs ours" and Oh how mine are so much better! This forum has provided years of knowledge that everyone has benefited from. We have been respectful of others opinions and perspective. This forum is not a 2 man circle jerk as where you guys reside. Your projectors look very nice and people are happy about it. I am to.
Carry on.
MAK
Posted: Mon Apr 03, 2017 1:51 pm    Post subject:
Carry on.
MAK
You can call him a hard-headed person, but for sure he spends a lot of time with testing things and he is very-very thorough with that (mostly for his personal passion). I think I can cooperate him quite well because he can find time to find out what is needed to be improved, and I can find out how to do it in practice (well, not always...). But for me alone I have no where near as much time to try those things out, therefore I’d have no idea if it should be addressed at all.
And this was exactly the case with this focus board mod. He told me that he found that if he uses LUG tubes then he is either limited on low output, or have to sacrifice sharpness for output – even compared to LCP tubes. He also noted that the problem is in the horizontal plane, so either the center focus is good and the sides are out of focus or the other way. So I came up with a simple idea to increase of the horizontal focus range by decreasing the R131, R231, R331 (330 Ohm) resistors to 150 Ohm. This seems to be working at least he was pleased with the results, but it also worth noting that this will put more strain on the FCM/FGM. To ease this strain one could pamper the board with precisely adjusting the resonant capacitor of the focus coils for the given scanrate, these are C119, C219, C319 for the 60-85kHz range, for 67 kHz (1080P 60Hz) the factory value of 68nF is quite good, but for 82kHz (1080P 72Hz) 47nF capacitors are suggested of the same quality (250V, film cap).
Otherwise anyone can decide if it is worth the $5 (parts) to try this mod...
racerxnet
Posted: Mon Apr 03, 2017 2:18 pm    Post subject:
Carry on.
MAK
Your reasoning and expertise is noted. What I am getting at is when another modder on this forum posts something, the dynamic duo are first in line to bash something done. What the 2 others are doing is riding your coattails. We can all suggest to you what we see as problems with the Marquee. At the end of the day it has been your ingenuity along with others who have truly remedied the problems. Suggestions do not equal success without the technical know-how.
MAK
Posted: Mon Apr 03, 2017 4:22 pm    Post subject:
gjaky if you look back through the more than 15 years these mods have been on the table, you will find that I have been replacing those same three resistors, based on Scott at VDC recommendation, to include various other changes also being suggested by the more than 10 engineers who also contributed over the past 15 years or so. One of the reasons not many of the old-heads here are not excited every-time someone claims to have made a discovery, is because of the history involved with these projectors and my mods and others mods.
And if you were involved during that same time period, you would also know some of the history from the original design. to include what was going on when Scott was doing a re-design on the video chain of the projector. First let me inform you that Scott was formally an engineer for another CRT projector manufacturer before joining VDC. He also did a complete re-design of a VIM for the Marquee. I was also privileged to be invited to VDC and got to look at his design and what was in the plans. And has since had on-going contact concerning this and has done well under his advice and others who were very familiar wit the original design.
So, the focus fix you mention, sounds really good until you think about it only being a problem on the LUG tube. And we looked at that years ago, with things then moving to the video chain where the problem really is. It's just more obvious on the LUG because of its unique design. The resistor change helps, but its still minor in comparison to really solving the problem in the video chain.
I would just like to say for you and those who get excited about the changes get to search or inquire first on this forum and AVS as well, and there I'm sure you may find where some of this has already been on the table. An with that in mind, that the constant "our mods is better than yours" would simply stop. It boggles my mind how anyone can look at a screen shot and confidently state that what they are doing is better than the next person.
Oh, I forgot to mention and Tim and confirm that I've also been directly working with and for a former Electrohome engineer for the past 15 years.
Posted: Mon Apr 03, 2017 5:00 pm    Post subject:
Thanks Mike for the flashback, 15 years ago I was just not toddling in my diaper anymore, how would I know anything...
Posted: Mon Apr 03, 2017 7:10 pm    Post subject:
Is it really THAT hard to keep this away from turning into a weenie measuring contest, guys?
I could be wrong but I think that those of us who are following BOTH of you gentlemen's work with interest
would like you both to at least PRETEND to exercise a modicum of mutual
professional respect and basic civility.
racerxnet
Posted: Mon Apr 03, 2017 7:22 pm    Post subject:
Chris,
I think Mike and Giaky have done a good job keeping peace. It's elsewhere where the problem prevails.
MAK
Posted: Mon Apr 03, 2017 11:21 pm    Post subject:
I hope I haven't been a littler over reactive to Gjaky, and forgot that in spite of his affiliation with those who bash my work constantly on other forums (so I'm constantly told). I should be careful as he hasn't really come across as joining the nonsense.
And his willingness to share something that may be helpful and should have been appreciated, if useful to me or not.
I had also made some changes to the FGM board, but mine was mostly stripping noise from the power rails on the board, to tighten the focus by removing the LVPS switching pulses/noise (high frequency) from distorting the final stages (mostly) of the FGM. That required inductors (large) more than capacitors. I'll try and post a picture later on this.
The changes we made was a different resistor than what he suggested, but I understand what the changes he recommend would do.
The same applies really to the neck boards, in that they were not designed for 1920X1080P 60 or 70hz, and required changes to make them work better with the LUG's as well make them better overall. And that made for a cooler operating board while they are also far more capable of light output. So much so, that the Beam Limit let's you know you're driving the tubes too hard (never really worked before this). And still they maintain sharpness without blooming and are very stable. They can get warm, but when they do you're really driving them. I also provide taping to seal the tube housing for better fan flow to the neck boards. And as both who have received this version so far has indicated by one saying the upgrade from even a version I had sent back to me a little over a month or so earlier, that the later version was SUPER Sharp, and this is with LUG's. My other customer also spoke about the sharpness improvement over an earlier version and how much of an improvement the sharpness was over the previous version, and that his camera is not capturing the sharpness. So we're not seeing a sharpness issue at all. And I'm not expecting or seeing my camera to also capture what I see on the screen.
Posted: Tue Apr 04, 2017 11:06 am    Post subject:
I'll start posting a few shots to help in understanding what the real goal should be with mods.
Most are aware of and use the SMPTE pattern as a reference for proper resolution, or the Rule for when proper resolution is achieved. True that it can be used as a determiner, but it's far from being the absolute rule. It could be if all video info was at the same 100IRE level that the one pixel lines are, but since in an actual video image or scene, there is many other 'smaller' and less than 100IRE data that would require a very different video standard to properly reproduce. And this is when you see where i use the word "Speed" and it's its not really all about Speed and bandwidth only. There are several other elements that help make up the true High Definition image.
I'll start out using a shot that I posted on the previous page here (below). In that shot you'll see an image that nearly has almost perfect Clarity, from the foreground to the backgrounds. That means that even things in the background are as easy to discern and those things up front in the image. In order to make that happen, you'll need High Bandwidth and Fast video chain... OK, let me go a little deeper here...High Bandwidth or the required bandwidth would make for a perfect SMPTE pattern. But where "Speed" come in to play here, is when you'll need a video chain that's fast enough that the rise/fall rate is best performance. And that allows for an nearly to perfect pixel performance in an Analog Video chain. In short, it also means that the faster the square wave or Fine objects in the image have less rise/fall tracing/lag, which by-the-way is also a distortion, the Clearer things will be in the backgrounds. Or let me try another way of saying this... With a fast video chain, and that is what Gjaky sometimes also post when he post his supporting shots when he test a circuit. He shows the square or object of testing and also shows the get-there and recovery-timing (rise/fall) of the signal being used for testing. That allows you to see how well the signal will maintain it's original structure while going through that video chain or device.
And depending on how well the rise/fall performance, the better you'll be able to get those things in the background to have the same clarity as the stuff in the foreground. And that is when you really get into the best in HD. Unlike Standard Definition an High Definition Image literally means it's capable of also bringing out the detail in the backgrounds, whereas SD (Standard Definition) really only brings out the foreground as being detailed, because it lacks the ability to show the backgrounds being Properly Resolved.
Now before I forget, I've also mentioned the Absolute Black thing. This is also very important with an analog video chain, especially one that claims its HD (High Definition) ready or capable. In the video chain itself, Black is the equivalent of zero, or the lowest point in the video sweep. And the reason why Black is so important because Black (zero) is also the reference for everything of quality in the image. You'll also need a good zero or black reference point to get good colors. Ok, I'll leave that one alone for now and get back to Black being a reference for quality only for now.
So when you fire up your analog video chain, and if it's a True HD video chain, it has the awesome responsibility of maintaining that same 'black reference' that's on the source all the way through that video chain..and here is when it gets complicated. If the video chain is missing doing three things well, that black/zero reference will get lost in the video chain, and not only will you loose black reference, your colors and best background detail will also get lost, or will be diminished.
When that happens, you may see a sharp image (foreground), but if you're not able to see Clarity in the 'backgrounds' it's not really an HD image. And when an HD image is really good is when you'll able to see Equal or good Foreground Detail/Clarity over the entire image, and you would also be able to achieve "Absolute Black" - remember three things are required for this and that's two things beyond the SMPTE. Also when the three things are properly in place and when absolute black is really there, you'll also notice more and better pastel or subtle colors. Because without aa good black reference the finer or pastel, more complex colors will most likely appear muted.
Btw, this is all solved in my latest mods. And once I get the Green LUG installed, I'll crank things up here a bit in The Mod Factory and you'll be more able to see things on the screen here..Wink
The below shot should do well in showing the clarity I spoke of here. But note that it could be so much better and a careful eye would show that the green is blooming and that limits things, yet it's still a good representation of an HD image.
Wink
Posted: Wed Apr 05, 2017 2:01 am    Post subject:
Chris Stephens had a great way of explaining the role of the entire video chain, all the way from the power supply forward to the CRT phosphor layer, which makes you really understand how dynamic, precise, and stable it has to be.
If you are displaying a 1080p- signal with a 72 Hz refresh rate, it works out that you need 180 MHz of clean video bandwidth.
Or, to put it another way, the system has to be able to respond to changes in video signal level and it only has about 5.55 NANOseconds (billionths of a second) to do it for a single pixel. It not only has to illuminate that pixel (spot) but it has to do it accurately, whether it's 0.00001 IRE or 100 IRE at whatever your target ft-l level is. It can't overshoot, ring, or clip. It has to hit the right output level every single time and it has 5.5 billionths of a second to do it, for every single pixel. And it has to also be able to hit a specific level and maintain it for some period of time without the voltage sagging or surging. Trace a full white scan line, go into the sync/retrace time, do it again, repeatedly, and never let that white scan line have any variance in it.
The power supply system, which is very much part and parcel of the video chain and NO less important than the neck card performance, has to be able to drive a steady full white screen with stability just as much as it has to be able to deliver the explosive instantaneous power required to light up a single pixel to full output in the middle of a dark field, without failing in any way to track the signal exactly and provide all the power it needs whether it's a full white field or just one pixel or anywhere in between.
Anyone who is smart enough to successfully modify the video chain and improve its factory spec performance is surely worthy of my respect.
Posted: Thu Apr 06, 2017 9:26 am    Post subject:
Good points here CJ.
When I asked the various engineers over the years why wasn't the video chain improved beyond what was manufactured, and out of them all, Scott from VDC and Cliff from Electrohome both gave the best answers. In short, it would take a lot of time to finely tune or work-out the kinks for best image quality, to include, it really wasn't necessary or required. And that explains why they all had such high noise floor and was really lacking in living up to the stated bandwidth. No one ever made an issue out of it, nor was there any real testing to verify the specs. So that made for easier sales and alloyed for them to move onto the next design better. Because time was cost, and the businesses stayed afloat because they were able to move on. If you could post the earlier digital projectors that both Barco and Electrohome/Christie manufactured, you would be shocked at how many they had made within the same period that they were also manufacturing their top CRT projectors. It was a bunch and almost all of them had short lives, and that explained why there were so many in comparison to the longed lived Barco 1209/8 808 series and the Marquee chassis that had the longest lifespan of them all. The manufacturers needed to not only stay on top of and ahead of the digital game. They had to also make sure they wee in a transitioning posture from CRT to Digital technology. And as I was told, the accounting people in the organization was the governing agency. Things like parts and time spent on anything was always what drove the operation.
And that is how a lot of the fixes for various items they sold was discovered by someone outside of the operations. They only had a handful of people dealing with upgrading and dealing with bugs. And that's how the Warranty Repairs helped them. You fix it on your end and they would reimburse for the repair. That would allow them to find out what fixes they needed to supply for their product, and at the same time not be so involved in having a bunch of hands on board dealing with bugs and fixes.
This also allowed them certain techs that supported their product, but was not on their payroll. They were only concerned with repairs and fixes, and they really didn't want to get too much into that, and that was the failure of one of the earlier CRT commercial projectors that failed a lot and why they went out of business. Fact is, all of the CRT manufactures that did not get on top their service, died a quick death. Maintaining and keep them in operation was costly, so any real improvements was never on the table, with the exception of Electrohome, who at one point was also looking into making the video chain better. And that is why the 03 VIM was designed, to soon after be taking off the assembly line. Aside form the time put into designing it and the extra cost (AD834) to manufacture it, to include, there was no real request or need for its extra performance. The very first Marquee (9000/8000) was a major flop, because it had both VIM and neck board failures, but they figured out the problems and quickly manufactured both neck boards and VIM's to replace they first.
These replacements are basically what we have now, with some changes that were part additions, but the board design is basically the same, because I was told cost was the driving factor and that's why a lot of time was never put into improving the image. No one complained and no one challenged the specs, so that allowed them all to just keep things wee it kelp the dollar the most important governor.
With my real point being that in order to improve the image, it would take a lot of time and dedication that was not needed nor would it make sense from a manufacturing perspective, because there was always the next new project. So being able to really do image improvement, it would require a lot of time involved in having a basic understanding of what is going on in the circuits, to also having a tremendous experience in also being a Troubleshooter, because fixing an already operational stage or circuit looking for problems below the work or not work repair model, one would need to really understand what they are looking for. And the really difficult and challenging part is being able to get so intimate with the stage or circuit that you'll have to develop your own means and methods of getting it to next level. This would explain the Industrial Pattern generators have so many patterns in them. Most are there to be developed around.
Or let say it this way; when I say the SMPTE is not the all-in-all, it's because I had to go beyond the SMPTE pattern, because where and what I was looking for, that pattern could not be used. so my research lead me to a different model and approach. And that is why I now include Black and Colors when I speak on bandwidth, because good bandwidth results produce far more than sharpness. fact is, sharpness is the lesser of the qualities that best bandwidth really produces. That is when I'll be talking about the range of colors, and pastel colors, image detail, image clarity, absolute black and noise floor...
But you are right, that signal MUST not loose its integrity on it's mission from source to the phosphor of the tube. And it is mind blowing how noise can cripple a video chain, but what's even worse, what it would take to track down that noise, because it's not something you can so easily scope out. And this is where the learned or acquired methods come into place. And I got just add here the importance of a good test jig, because it can allow you to fully look at things.
I'm finally getting excited about watching movies from my own projector and that should be within the next two months, mainly because I got a video chain I can't wait to watch all of its glory..Wink
Posted: Thu Apr 06, 2017 10:52 am    Post subject:
All very true words, Mike. Image quality has not been the driving force in projection, other than meeting the usability goals of the end users. Which, for CRT projectors, were always military and commercial flight simulation systems.
Sony put SOME effort into the G90 in terms of getting a better picture. And I would say they succeeded, as the image out of a stock G90 IS better in some ways than the image out of a stock 9500LC. But it's not perfect, it still has some video noise to work out and of course you know this better than I do.
The G90, at a retali price of 38,000 dollars a unit, was produced in numbers only a bit above 1000 units. I am sure that Marquee production was something beyond 10,000, don't ask me how much more.
And then Barco actually built a specialty version 909, actually two of them, the Cine 9 and the CineMAX, which were actually
marketed to the home theater crowd and supposedly have fewer noise issues than any other CRT projector or so I have been given to believe. Price: I've heard something around 60K for a CineMAX. Not sure if that's true.
I'd be surprised if even 500 CineMax units were made. And I'd like to know what circuitry improvements they had over a standard 909.
Cost always drives the product's design. This holds true in all markets.
So it's fair to say that all products are compromised in their design and execution by cost constraints, to some level.
I
jbmeyer13
Posted: Thu Apr 06, 2017 1:30 pm    Post subject:
Watching screen shots doesn't count Laughing That will never happen because you can't help tinkering
Posted: Thu Apr 06, 2017 2:24 pm    Post subject:
That's true, but age is slowing me down somewhat, where it has become easier to watch the screen than to look at those tiny parts on PC boards. I really want to get more into a relaxed and enjoy mode and even do some things in nature like the parks and fishing.
Plus, I'm really pleased this time with where i have things with the mods and that is a real first....but know that soldering iron will still be calling me out of my sleep.. Very Happy
Posted: Sun Apr 23, 2017 10:20 am    Post subject:
I had to get back into the Mod Factory for the past week or so, because I've been upgrading some boards I've sold going back over a year. This was a Free Upgrade that I had offered, because I wasn't pleased with a series of boards that I sold. So the upgrade was mention during the sale, and so far I'm finishing up the last of those boards. They meet my expectations well. Oh what a difference the proper Test Jig has made..Wink
Now, this same set will need the LVPS also done to better compliment the video chain. If you notice in the shots below, even with the camera in the process. The low end and black is showing very well. You'll definitely need the LVPS also done to get this and much more.
And to add, I'm now also doing the Control Module. These both are substantial upgrades that easily show the difference after being done. But this may not be necessary for everyone. Only the very picky, because I don't include the LVPS and Control module in the cost for the video chain.
This shot was a quick-and-dirty, and that can be seen in the convergence and focus not being the best. But that will be getting better next month when I fire this baby up fully calibrated..Very Happy
I can crank my contrast to 100 and things will remain tight with near to zero blooming...That's when you know you got the chain right.. Mr. Green
Oh, from now on keep your eyes on RED in my shots and know that I I'm not using a RED C Element..
Posted: Mon Apr 24, 2017 10:46 am    Post subject:
Gotta get that Green LUG installed. The Green LCP presently in there is blurry again.
Posted: Tue Apr 25, 2017 10:10 am    Post subject:
The green LCP is getting worse. I took a shot to show what the convergence grids look like comparing the green LCP to the red LUG and the difference is very easy to see, however it did not turn out well.
Anyway, a few more showing the green out of control, but the good news is, I should it it out of there hopefully first part of next month.. Smile
Page 9 of 13
