My new theater build
jbmeyer13
Posted: Thu May 11, 2017 1:33 am    Post subject:
greg9518lc wrote:
jbmeyer13 wrote:
greg9518lc wrote:
What brand of chairs are those? Nice job on your theater looks amazing
Thanks. Bought them from midwest seating. Going to put some recilners in front. Should have 7.1 in by monday😀
Nice and thanks for the info trying to decide between these and recliners. I am sure it will be nice to finally have the sound match your picture quality
Check out seatcraft for recliners; aspen model not much more than rocker style seating;-)
jbmeyer13
Posted: Thu May 11, 2017 5:26 pm    Post subject:
Generally, you'll want to treat the entire front wall (behind the speakers) with absorption - Linacoustic. The side walls, you want to treat at least the first reflections, with absorption for multi-channel rooms (use mirror method or CAD).
Hey Steve,
Which version/model# for this stuff are guys using and what nominal thickness?
Regards,
Justin
Posted: Fri May 12, 2017 1:58 am    Post subject:
Your theater is looking very, very nice indeed.
I have fantasies of having a home theater as nice as yours.
jbmeyer13
Posted: Fri May 12, 2017 1:29 pm    Post subject:
Well first you need to clear out at least 10 of the projectors you own Laughing
Thanks. It's been a lot of work and there's still a bit more to get it exactly where I want but it is coming along. It's very rewarding when a project comes to fruition in the manner in which you envisioned. That's not a given as there's usually stumbling blocks which can alter the intended outcome.
I have a 3-channel Carver amp (a-753x) showing up today and hope to have my M&K S-5000's installed by middle of next week. So I'll have a functioning 7.1 set up which should make for some interesting testing. It's a bit more fun to test audio than video Thumbs Up When Kurt set up the PJ back in the fall we spent 40-hours of hard core tweaking/testing and while it's fun to see the end result we (especially him) were pretty shot by the end of it.
Posted: Fri May 12, 2017 5:55 pm    Post subject:
Blasphemy!! Wink
Posted: Fri May 12, 2017 8:50 pm    Post subject:
It's been proven that the more projectors you have, the less time you have to set up an HT. Look how long it took Curt to get anything that resembled an actual home theater! Wink
Posted: Fri May 12, 2017 9:54 pm    Post subject:
Then is it bad that I lost count on the number of projectors that I own? Smile
Posted: Fri May 12, 2017 11:13 pm    Post subject:
I am sure I've lost count as well.
For every one I have now, (that's sixteen including the JVC RS45 digital and a lower resoltution, high brightness InFocus unit that'd be good for gaming or business presentations) I am sure I've had at least one more that I scrapped, sold, or gave away in the past.
Just to try to run down the list:
Not less than eight more Marquees
Sony VPH-722Q1
Sony VPH-1072
Sony VPH-1092
Two AmPro 4600s
One AmPro 3600
Two Barco SLM R5 large venue DLP machines
Four workable AmPro light valve chassis plus spares
AmPro LCD-300 which was a new engineering sample, which I made a tidy profit off of.
I'm sure there were more.
Posted: Sat May 13, 2017 12:42 am    Post subject:
Someone should start a 12-step program for crt addicts. Wink
Posted: Sat May 13, 2017 12:45 am    Post subject:
Step 1, don't be number 1 poster on this form Wink
Posted: Sat May 13, 2017 1:14 am    Post subject:
You won't be laughing when I have twelve CRT projectors all tiled together on a single huge wall, color matched, blended, and projecting 8K.
Posted: Sat May 13, 2017 1:16 am    Post subject:
I wouldn't want to see your electricity bill! (Both for running the projectors and for keeping the room at something less that 110F). Wink
Posted: Sat May 13, 2017 2:19 am    Post subject:
FYI, three running G90s will trip the 15A thermal circuit breaker in a typical 6-outlet power strip, after a few minutes.
So assume they draw 5 amps each. Marquees draw a bit less power than a G90.
Posted: Sat May 13, 2017 12:51 pm    Post subject:
The manufacturers spec them as follows:
G90U: 1050W max
G90E/G90M: 1000W max
Marquee 9500LC Ultra: 650W max
You might get slightly more inrush current on power up. Not sure.
I've always liked to run my projectors on their own 15A circuit (1440W max nominal, 1800W peak). My digital draws 360W.
jbmeyer13
Posted: Mon May 15, 2017 3:48 pm    Post subject:
Hey CJ- you better make sure you have good medical insurance. Those Light valve projectors are radiation beacons!!
Never knew Ampro made any; thought it was just JVC.
Posted: Mon May 15, 2017 4:16 pm    Post subject:
I haven't had a light valve unit since 2000 or 2001.
Neat machines, though. It was fun to learn how they work.
I had one of every model Ampro made except for the two chassis AE-12 model.
The lower chassis was the lamphouse and lamp power supply.
It used a 5KW Xenon arc lamp and put 12K lumens on the screen.
jbmeyer13
Posted: Tue May 16, 2017 6:10 pm    Post subject:
Hey Steve,
Regards,
Justin
Anyone know which Linacoustic material is the correct type?
jbmeyer13
Posted: Sun Jun 18, 2017 3:45 pm    Post subject:
Installed my sconces and should hopefully have my PJ ceiling cover up today
Posted: Sun Jun 18, 2017 4:14 pm    Post subject:
I like it. 'Reminds me of the interiors from HAMMER HORORS films in the 1970's.
Say you don't have Christopher Lee hiding in there do you? Wink
jbmeyer13
Posted: Sun Jun 18, 2017 5:10 pm    Post subject:
Count Dookoo is stuffed in the left middle column Laughing
The black ceiling really does give it thst emglish horror feel. With the low ceiling I had to go black. If I had a 9-10' ceiling I would have installed a coffer. Final step is acoustic treatments.
Page 3 of 4
