BLACK celing paint
Goto page 1, 2, 3  Next
Posted: Tue Feb 13, 2007 11:41 pm    Post subject: BLACK celing paint
It's finaly that time. The Ampro is (mostly) figured out. My living room is a non-living room. It's torn asunder ( ed: what does asunder even mean?)
I'm going from a browney beige with wood and gold accent's to a flat black celing, dark greay painted back wall and upolstered pannels on the side walls and a dark color carpet.
I have found only one brand of flat black paint meant for the celing at Rona it's $18.95 a quart. Kida pricey but I'm only doing this once so I don't mind.
Does any have other recommendations for other brands?
Don Rombach
TV/Projector: Sony G70
Posted: Tue Feb 13, 2007 11:55 pm    Post subject:
Why would it have to made for the ceiling?
Glidden makes a pre-mixed flat black interior paint. About $20 per gallon at Home Depot.
BiG D
Posted: Tue Feb 13, 2007 11:59 pm    Post subject:
It doens't HAVE to be made for the celing. That's just what it said on the can. I'd use automotive paint if I could run a sprayer in here.
Thanks for the recommendation I'll check it out. Wink
zaphod
Posted: Wed Feb 14, 2007 1:16 am    Post subject:
Tremclad comes by the gallon in black. and to boot, you're ceiling won't rust...
but seriously, the best paint i've ever used is BenjaminMoore. the second is Behr, but it is a distant second. I tried Glidden once and it wouldn't cover like others and ended up with more coats.
Posted: Wed Feb 14, 2007 2:03 am    Post subject:
I ~think~ it was Benjamin Moore at Rona but I can't find the piece of paper I had. Ahh so it looks like Glidden is cheaper but actually cost more and takes more time to put on. Good to know. Thanks.
That's 1 vote for Benjamin Moore. Any others?
Posted: Wed Feb 14, 2007 2:56 am    Post subject:
another ben moore, its the only paint i'd use.
But why black? Why not a midnight blue. no reflections, and less creepy Wink
wallace123456
Posted: Wed Feb 14, 2007 3:02 am    Post subject:
I used BEHR paint from Home Depot. The color was INK BLACK. And it is black! My ceiling has a little texture to it, so 1 gallon did it. I think it was about $23.00 a gallon. Forgot what type but I'll get the info this Saturday.
It was not ceiling paint, but the paint was thick enough so it didn't splatter.
wallace
Bruce 09
Posted: Wed Feb 14, 2007 3:12 am    Post subject:
IF you can , use ceiling paint, no reason not to actually .
The reason is you want the flattest paint possible, and that is what ceiling paint is known for . They add more chalks and clays to" flatten" as much as possible this isn't great for wear or smudge resistance, But that is why it is "ceiling paint"
It will help cut down on room reflections , You can really notice flashing on ceilings and will on Black as well .
Bruce
PS
Don't buy a named color paint, Buy a "ceiling" "BASE" that will accept the most LAMP BLACK colorant as possible .
zaphod
Posted: Wed Feb 14, 2007 6:20 am    Post subject:
another tip is to get your primer tinted. i usually do this by having them add 1/2 the amount of pigments that would go into your top coat.
top coat paints are filled so that there is enough room left in the can for the pigment. but there is usually just enough room in primer paint to take the 1/2 measures.
Posted: Wed Feb 14, 2007 4:24 pm    Post subject:
Yep I already have the primer lined up. It'll be a medium grey color. Two coats. I am hopping I'll get started on this on the weekend.
Posted: Wed Feb 14, 2007 4:26 pm    Post subject:
Bruce 09 wrote:
PS
What do you mean? Don't buy a brand name paint? The paint I am looking at doens't have to be tinted. It's black in the can. This is better than them mixing white paint and trying to make it look black no?
Bruce 09
Posted: Wed Feb 14, 2007 6:05 pm    Post subject:
Well, first off you cannot make black paint from mixing in black pigment into a white paint Smile
SO if your number one goal is to make your Ceiling as "flat" , NON REFLECTIVE as possible then you should use Ceiling paint for the reasons I said earlier ...... BUT you cannot get a TRUE DEEP BASE in ceiling paint anymore . The next best step is get the BEHR 1300 series "FLAT" , Deep Base, then get the clerk to add 12ounces of Beluga Colourant .
Then try to get them to add a half ounce more Smile As Mark says you cannot believe manufactures specs, they say 12ounces max, I say squeeeze in a little more, the can will take it.
This paint will do two things it will help you hide poor rolling technique OR POOR COVERAGE and help room reflections .
Paints come in different "bases" the base you need is determined by the colour you want .
The reason this should be better than the colour swatch you are matching is the guy who made this colour swatch up didn't necessarily have a home theater ceiling in mind, never mind one that was driven by a CRT projector that has poor ansi contrast..... Smile Smile
Bruce
GEBrown
Posted: Wed Feb 14, 2007 6:34 pm    Post subject:
When I went to Home Depot and told them I was painting the ceiling and screen wall of my HT and I wanted FLAT BLACK, they said, "Oh, then you want Behr, because Glidden claims their's is washable and so they put a little enamel in it".
My 2 cents
Gary
wendortb
Posted: Thu Mar 01, 2007 11:10 am    Post subject:
A little while back I picked up pittsburgh paints interior flat latex paint, purple in color. It seems pretty reflective even though it says it is flat paint. Is it kind of shinny because it is a latex base? I want to repaint to get rid of this reflective and want to make sure this doesn't happen again. If I pick up Behr ceiling paint, some dark color, will this work a lot better?
Travis
Person99
Posted: Thu Mar 01, 2007 3:08 pm    Post subject:
I used Behr for the flat black. I got it at home depot and they used the Disney color "Mouse Ears" which is pure black.
ronholm
Posted: Thu Mar 01, 2007 3:55 pm    Post subject:
Ya'll should really look into Sherwin Williams.. I only use their 200 series stuff these days.. I use an airless sprayer most of the time... But with SW 200 roller marks and paint surface texture are always perfect. It is always safer to touch up than other brands.. Less likely to flash (show a difference in sheen)
But then again I just really consider Home Depot like Walmart.. I don't buy my groceries from the store that changes tires, sells drugs, and has bicycle parts, and TV's
And I don't buy paint from the Depot.... Besides with the volume of painting I do every year Sherwin is Much less $$$
I guess Behr paints would work fine.... But besides the quality of the SW paint I can't stand dealing with the crack pot kids that they hire to work at the H Depot around here....
Person99
Posted: Thu Mar 01, 2007 4:04 pm    Post subject:
Yeah, you are right. It is pretty stupid for a store that specializes in home improvement to sell paint. Rolling Eyes
Posted: Thu Mar 01, 2007 4:05 pm    Post subject:
I found out flat paints' sheen (or lack thereof) really varies from paint company to paint company. We made the mistake of spec'ing Sherwin Williams' flat colors for the interior of our whole house when we built it a couple years ago. While I loved the look when it was new, it's like a damn chalkboard. You literally can barely TOUCH the wall without leaving a scuff mark. You can imagine what some of the higher-traffic areas look like now two years later. It is REALLY flat. Big mistake. I'll be doing some major repainting over the next couple of years.
On the other hand, our neighbors painted a bunch of their interior with Valspar's American Traditions' "flat" paint from Lowes, and it wasn't flat at all! It was probably more like Sherwin Williams' Satin - even a tad towards semi-gloss!
If you can, I'd have them dab some on a card and use a hair dryer on it to really see a particular paint's sheen before you spend $20 or $25 to buy a gallon.
Bruce 09
Posted: Thu Mar 01, 2007 4:12 pm    Post subject:
Sherwin Williams is a hardware store paint as well, it is not a high end paint , They are both in the same league of paints.
In this instance though , the cheaper the paint the better.
The cheaper paints use MORE clays and chalks in their paint for weight and volume so their paint will usually have a flatter sheen than a better paint which is trying to make a more durable paint .
If you were able to tint a ceiling paint as Black as the 1300 series it would even be better for a flat black ceiling .
BUT if you are not going for an absolute BLACK ceiling I would use the ceiling paints for the least sheen possible.
Dave how much beluga colourant did they use on your mickey mouse paint formula ?
Bruce
Posted: Thu Mar 01, 2007 4:13 pm    Post subject:
Dave, I think you missed Ron's point. He wasn't saying Home Depot shouldn't sell paint, he's saying he doesn't buy it there - for a reason. It's the same reason you probably wouldn't buy a projector or other high-end theater equipment from Best Buy - especially if it was part of your business! Instead, you're going to go where you get the expertise, knowledge and attention. From my experience, the guys at Sherwin-Williams stores know what the hell they're doing. They seem to be "career" guys - it's their "thing".
You have to admit that a fair chunk of the rank/file people working at Home Depot (or any other big box store for that matter) aren't doing it as their career. It's a part-time job for extra income, a full-time job while they go to school, a second job when they're not on-duty, etc.
Dave was just saying he gets a better product and service at a paint store as opposed to the paint department at Home Depot. Having worked a lot with the Sherwin-Williams folks, I tend to agree.
Page 1 of 3
