$40 Stripper - HDCP 2.2 UltraHD. And why it matters to CRT!
frederic1
Posted: Thu Dec 24, 2020 2:23 am    Post subject:
Hello, congratulations to CIR Engineering for this very interesting topic. I would like to know if meanwhile, an HDCP 2.2 stripper has come out that supports 4k@60Hz ? Thank you.
Posted: Thu Dec 24, 2020 3:01 pm    Post subject:
I'm not aware of any new HDCP strippers though there are likely some out there. This stripper can do 4k@60Hz though as long as you set your colorspace to YCbCr 4:2:0. This would keep the bandwidth under 9 GHz. 422 would be better and require an 18 GHz chip, but for most people 420 will suffice.
Please let me know if you find any stripper with an 18 GHz chip and I will test it for you.
frederic1
Posted: Tue Dec 29, 2020 5:29 am    Post subject:
Craigr, thanks for your quick reply and please bear with my limited knowledge.
After doing some research, I found this 18Gbps stripper https://amzn.to/3mY2Wvm and the guy in this video https://youtu.be/kaawM-Kw85U?t=470 (watch from 7min50) says that it bypasses HDCP 2.2 at 4k@60fps.
What do you think about it ? Thank you.
 Filesize:  173.62 KB
 Viewed:  7611 Time(s)
Posted: Tue Dec 29, 2020 3:17 pm    Post subject:
It looks promising. What country are you in? If you have one shipped to me I can test it and then ship it on to you.
Posted: Tue Dec 29, 2020 3:29 pm    Post subject:
Well, never mind on sending me one. I just ordered one and will try and find time to test it next week. I'll post back.
frederic1
Posted: Wed Dec 30, 2020 10:12 am    Post subject:
Thank you very much Thumbs Up
Posted: Wed Dec 30, 2020 3:17 pm    Post subject:
If it strips it'll be good to know about and I will probably order more just to have in my arenol. Many systems work terribly with HDCP especially the Sony 5000. Sometimes I out these inline and all the problems just disappear.
Posted: Thu Jan 07, 2021 5:37 pm    Post subject:
I just tested the unit I received from Amazon and it DOES NOT strip HDCP 2.2.
Last edited by CIR Engineering on Thu Jan 07, 2021 6:03 pm; edited 2 times in total
frederic1
Posted: Thu Jan 07, 2021 5:54 pm    Post subject:
Thanks for letting us know Sad
jask
Posted: Thu Jan 07, 2021 8:57 pm    Post subject:
...and for taking one for the team👍
Posted: Sun Jan 10, 2021 6:09 pm    Post subject:
Yup, it was worth a try Idea
frederic1
Posted: Fri Jan 29, 2021 10:34 pm    Post subject:
I have received my copy of the UHDS-102 18Gbps and all I can say is that it strips HDCP 1.4 (I connected the input to an HDCP-protected 1080p cablebox, and the output to an ElGato HD60 capture card, and it works).
I don't have a 4k device so I wasn't able to test HDCP 2.2 stripping but I trust you, CIR Engineering.
Posted: Sat Jan 30, 2021 3:01 am    Post subject:
That sounds easily plausible, and also quite likely based on your findings.
Unfortunately, I no longer have the unit so I can't clinically test your findings. However, if it's working than it's working right Thumbs Up
Best regards,
Page 4 of 4
