| Posted: Fri Feb 26, 2016 11:56 pm Post subject: |
Mike, your input has caused me to alter my direction. I WILL take your word for it, and am glad to NOT have to spend a lot of money on expensive parts that probably don't represent the best way to improve the circuit anyway.
I'd need to actually know the frequency characteristics of the noise on the DC rails to figure out proper filter circuit parameters for it,
but I figure your values are probably a really sensible place to start.
I have ready access to a rather impressive assortment of dirt cheap inductors ranging from tiny up to toroidals that are the size of a donut. Give me some recommended values and I'll go shopping.
| Posted: Sat Feb 27, 2016 12:35 am Post subject: |
| cmjohnson wrote: | Mike, your input has caused me to alter my direction. I WILL take your word for it, and am glad to NOT have to spend a lot of money on expensive parts that probably don't represent the best way to improve the circuit anyway.
I have ready access to a rather impressive assortment of dirt cheap inductors ranging from tiny up to toroidals that are the size of a donut. Give me some recommended values and I'll go shopping. |
No problem. I'll work with you on this. And remind me in two weeks, and I'll send you some parts to start with. And help you along the way
| Posted: Sat Feb 27, 2016 1:33 am Post subject: |
Chris, use Film caps in the HVPS.
These are 20uf 700 VDC clarity caps from Partsconnexion.
I talked to Chris Stevens and he said they would actually be better in that circuit than Wets. But back then they didn't have them small enough to fit. They were the size of a #10 ketchup can
I have wet tants on my CVA's and VDM's But you have to make sure they are in good working order. many Wets you find cheap are old and can fail. Id make a circuit to run some voltage through them for a few days before using them.
I have had a few leak out.
Chris said for some reason the best results he had with wets was the 6 or is it 8 6.3 volt caps on the HDM. He went with 1500 uf 6.3 volt variants there . I think originals are 3300uf .
And if you do use wet tantalums on the HVPS it is 120uf 100v x 5. That line is the 390 volt line from the LVPS.
The benefit he said was in the transient response from Black to White and white to black plus some noise filtering.
I have a pic of the wet tantalums floating around somewhere. He asked me not to post it but its all well known now.
he also said he wanted to do the LVPS in the same manner but the UL listing/ ratings wouldn't allow it and it had to pass those standards.
| Posted: Sat Feb 27, 2016 6:54 am Post subject: |
The 390 volt supply there is coming from the sub switching supply in the LVPS. It is the same supply that supplies all of the switching supplies in the LVPS (+/-85, +/-24, +/-15, +/-5, filament).
That section in the HVPS is more a decoupling network than a filter for the 390 to the HVPS. Its purpose is more to keep the HVPS isolated from the LVPS and more to prevent flyback noise from getting into the LVPS. No filter is really needed for the HVPS, because the 390 is already well filtered in the LVPS.
But for sure loading down those two caps with what's shown should no doubt help block anything from going either way. But still not sure why anyone would put very large values in a decoupling network, where its purpose seems to be for filtering a particular frequency area of concern.
| Quote: |
He also said he wanted to do the LVPS in the same manner but the UL listing/ ratings wouldn't allow it and it had to pass those standards. |
Now this is a good one, but I like this one even better:
| Quote: |
The benefit he said was in the transient response from Black to White and white to black plus some noise filtering |
This even tops "inject square wave" "fast Fourier" and "spectrum analyzer" to name a few.
I learned about that kind of network when I built my transcoder maybe 15 years ago. The application engineer at Intersil suggested that I attend an FCC Compliance Class, that was actually provided by other operations and was a really good class to learn about noise and interference.
The chassis design of the Marquee is not the best for noise lowering, because there are very few ground points on the chassis for the boards. So if anything to make for a radical noise lowering effort, that area would be the first to address. At least that is my findings to include that the HDM is too close to the neck boards. And figuring out a way to correct that could create a headache. But since the noise is not visible on the screen, it's not worth it.
To include, the noise only affects the video chain. I used very similar to what's in the HVPS on the video chain, by better decoupling and more specific frequency isolation. So far it has been working fine. You can't even see any noise now when looking directly into the tubes. And I'm sure I was able to make that happen for somewhere near $20 bucks..
redfox001
| Posted: Sat Feb 27, 2016 8:53 am Post subject: |
What you guys have not discussed yet is the image quality that comes with simplicity. Like simplicity in the video chain and I have to praise Mike for that. Take away all the processing all the scalers etc. But if you can not get it simple you have to do something else.
tschaeikaei
Joined: 08 Apr 2013 Posts: 490 Location: Germany/Saarland
| Posted: Sat Feb 27, 2016 1:17 pm Post subject: |
Hi, sorry for not reading your -very interesting- text before, i was in a hurry and had to do just the same you said you do: save my thoughts somewhere
I've read the whole thing now and there are still some questions. And some statements (i hope they're not offensive).
And yes, i've written some, about 50 lines about caps and stuff and since it was work, i'm not going to delete it.
But i'm glad you changed your mind about it and save the money
Resolution:
| Quote: | | Screw VGA. If it's not 4K capable it's not even worth considering. |
VGA is capable of everything your cable is capable. If your videocard doesn't allow more that 2048*1536 use powerstrip or something similar
and tell the card exactly what you want it to put out.
If you are going to use the projector with an htpc you will input RGBHV. There is no 4k capable moomecard, you said it yourself.
What instead of VGA (dsub 15) will you use? VGA ports put out RGBHV signals, nothing to worry about adapters, conversion and so on.
I doubt that any other signal will do. You can surely use DVI analogue (same signal, different connector).
HDMI and display port are out of debate. And those would not be of any benefit (if there were adaptors).
Get a few meters of professional video cable and solder some connectors to it.
Don't let the industry fool you by some jokes like HDMI was better than analogue (VGA or what you'll call it).
The only advantage is a smaller connector (breaks often) and HDCP, the stupid copy protection.
I must say it: What could be better if the source delivers just exactly the signal the projector wants and you send it
through a good quality cable directly to the projector? No boxes, no converters, no adaptors could ever improve anything on a (video-)signal.
And using a HTPC as a source enables you to play around with all parameters of the signal.
Best part is for sure that software is always cheaper than hardware.
Capacitors: Could you link the Chris Stevens document, please?
As far as i am informed there is no need in tantalums at the places you want them.
They were the best choice about 20 years ago, but aluminium electrolytics have gotten much better since that time.
The only reason tants are still used today is that they are super super reliable and have a wider temperature operating range than aluminium electrolytics. So they are used in some military automotive applications.
See Nashous Marquee modification thread (on the first pages, improvement in HVPS, electrolytics parallel to the 1uF 400V
film caps). I thinks that is what you meant when you told me you'll use tantalums on the HVPS.
I don't know what you want to improve on the neckboards. There are only two caps (C1 and C26) they de-ripple the +-85V input rails.
If you want to improve ESR, i'd propose to use high quality low ESR film caps or os cons (found some Panasonic 100V 15uF 40mOhm).
Two of them in parallel and the ESR is divides by two again. Just as Barclay proposed. There ma be others that fit even better (voltagewise),
i didn't read all the datasheets. But 100V should be enough.
I found nothing on ESR about wet tantalums, except that it's "very good".
20 mOhm at 85V can deliver 4,2kA (for a very short time), the other caps in parallel will further increase that current.
I'd seriously think about the series resistance of the other parts and the copper layer of the VNBs.
Slew rate is connected the the impedance of the current source (which is the input caps in this case)
but not only to that. If it's high frequency stuff everything comes down to parasitic capacity and inductivity.
That's were stuff get's nasty and becomes vodoo
Tubes:
I was always wondering if anyone tried the following: Overfocus (electronically for sure) a LUG slightly and see if it get's brighter.
If this is the case, you'd better increase the resolution to fill the dark lines between the bright lines.
Just like everyone does it with the blue tubes.
If the tube does not get brighter, it doesn't have anything to do with the smaller beamspot.
Then it could be electronically, e.g. the part with the KH grid (anyone knows what KH actually means?) or they could use different
phosphor. I doubt the phosphor is different because they labeled them HKA/BMB/RJA just like the LCPs (and most, if not all other tubes).
P43 phosphor is on all my tubes labeled with a green round sticker under the focus coil saying "P43" and the tube itself is labeled PT22-19 (LCP pinout)
or PT22-30 if it has the LUG/ LPB pinout.
Barclay, did you try the LPB-HKA yet? I was wondering if it is finer focus than LCP.
Regards, Julian
_________________ Marquee 9500U edgeblend P43 | NEC 9PG
| Posted: Sat Feb 27, 2016 2:27 pm Post subject: |
Just a few things in general: I'm going to follow Mike's lead (and very generous offers of assistance) and pursue a more calculated program of filtering noise rather than just throwing expensive capacitors at a problem that I haven't even characterized.
Suddenly I find that I regret selling my excellent 400 MHz Tektronix 2465B oscilloscope. It would be useful for scoping out noise.
No problem, I have another that I can refurbish after recapping the power supply, and put it into service.
When redfox001 first said "vga" then I was really thinking of VGA resolution, which is just 640x480. But the general idea of extracting high resolution signals from a VGA connector via a pigtail or adapter is of course completely valid.
The catch to that is that I am not aware of any VGA source that goes beyond 2K x 2K. Nor any VGA equipped video card that goes beyond QXGA. (2048x1536). If such a beast exists, and you know about it, PLEASE give me the make and model number.
The rule I'm seeing is that all HD cards use DVI or HDMI, and if they have a VGA connector, it's limited to non-HD specific resolutions. Then UHD cards typically ONLY have HDMI.
Now as for Mike's point about limited good ground points on the Marquee chassis...
I expect to more or less totally disassemble the chassis in the course of the work.
There's no reason at all why I couldn't add some copper sheeting in strategic areas, thus greatly improving the quality of
the chassis as a ground point. At the very least, run copper tape or straps (screwed down) to all the factory ground points
in a star ground pattern.
I have some conductive shielding paint as well. That might be quite useful.
I wish there was an easy way to build an LVPS output filter system that could fit in the space between the HVPS and the LVPS,
but that'd be a substantial bit of engineering.
redfox001
| Posted: Sat Feb 27, 2016 4:21 pm Post subject: |
He I have mods on the vertical, convergence and astig board (all boards on the back) and also on the focusboard, vim and neckboards. Together they lower the noise to not visible on the screen for me. Perhaps the noise originates from those boards and is travelling between them? I did nothing on lvps and hv. I think they deliver filtered power allready. Barco 909 also has thse inductor filters on astig, focus and convergence.
| Posted: Sat Feb 27, 2016 11:50 pm Post subject: |
Here is one of Chris's Email's
Interesting guy I must say. His Engineering back ground is evident. But He is an eccentric chap.
| Chris Stevens wrote: | The electrolytics on all the boards on the back heat sick drift like CRAZY effecting conv, size, astig and so recapping all that with wet tant makes it so stable for conv its amazing. But yea, that leaves H deflection.
H Def is a REALLY analog board. Its been forever since i looked at the schematic. Driving those yokes with all those different scan rates must produce crazy impedance variations as the scan rate on those yokes changes. There is a LOT of analog going on there in deflection. I knew that was a circuit that required a lot of hand tuning during R&D. Playing with anything on there with the power involved and the freq, that would end badly. I did not want to effect anything important in the circuit path. I dont remember what all i changed out. I do remember putting much bigger higher voltage caps on there. I remember lots of tant on the rails. I remember one big thing i did not expect much change but ended up "wow"...
There were like 4 big uF low voltage caps on that board. I remember they had to do with the CRT beam centering signals. Replacing these I remember had a surprisingly good effect. I was surprized that big wet tants in that spot improved pic. I remember looking at the circuit and thinking that yep, the ultra wideband hyper low ESR resulted in a VERY quiet node in that circuit and made a interesting difference in the picture I did not understand. How did that cap change even effect the pic ? Decreased H deflection jitter noise ?
I am VERY confident that I can do wonders in that last stage that drives the yokes.
Yokes are like speaker drivers. Woofers. Vert. Tweeters. Horiz. Lots of watts and pretty complex impedance. All that filter network stuff is really just like speaker crossover components. In fact, maybe it would be good to use better wire for the yoke runs.
Yea, shielding is good. I was taking that copper foil off old tubes and putting it on in more places on the tube. I learned a secret long ago. If you look at the neck board you will see 2 tabs on the ground ring that are unused. Wellll... Turns out that the copper foil and wires from it were doubled in the orginal design and the additional foil and wires plugged into the tabs you see today. So I have always pulled the foil off the old tubes VERY CAREFULLY as you want to put it back in perfect condition on your new tube. Keep the wires attached. You will see where it goes on the tube. Where it should go. Now just exactly what signal is on that copper is a very interesting thing.
All of those things I was playing with and lots and lots more. AND I could just go on and on still. I can still sit down and find new things to do in 30 mins.
I think the thing that MIGHT redefine a CRT picture might be to supply a highly regulated HV supply to each tube independently with real caps on the 2nd anode. This is TRULY going where no man has gone before and could result in a picture beyond anything anyone has seen, however, it might also result in smoke or arcs or who knows what. So its dangerous. But I love that sort of thing. One of the dangers of using a highly regulated HV supply MIGHT be xray emission changes. Should actually lower xray output by not have a higher unregulated swing on that supply.
The 2nd anode noise ends up in the electron stream which ends up as brightness modulation. Also bloom is 2nd anode voltage drift. So the tighter your HV regulation the more stable your pic size is when switching from black to white scenes that use lots of beam current.
Im not opposed to doing new engineering. I could suggest lots of lines of mods no one has thought of yet.
Ive always wanted to do a DAC change out EVERYWHERE. WAY better DACs today. So all the analog deflection and level signals all over the projector could be WAY cleaner from the start with better DACs.
Someone could jump into the code. The firmware. It would be killer if someone copied, decoded and then "jailbreak" the projector and we can rewrite some code, alter fundamental functions.
There are INSANELY crazy ways to super align the CRT yokes and align them to the tube. Not factory methods.
If I have not mentioned I used a DAC for SDI and later HDMI. P put them on 2nd input cards. So no interconnection wire. Just right from the DAC pin into the proj via board trace. VERY clean pic. Digital input projector. No loss.
Im not sure if you have wrapped you head around the PLL concenpt this projector works on. I did not get it at first. The whole digital side of the projector clocks at a variable rate. So the DACs, the i2c bus, the cpu clock, memory. All sorts of stuff is tied to a variable master clock. The digital clock is variable. Its based on the incoming sync. Its brilliant really. Simplifies everything. Its what makes this projector special. So this PLL master super clock is on page 4 here. You can follow and read up on what this does in the marquee from the service manual. http://www.xymox1.com/Projector/Marquee/Control/00-250306-08-5.pdf The control board is a huge analog orgasm of signals and DACs. The daughter board the PLL is on is killer important to everything. Cap this and this whole circuit deserves attention. ANY jitter here will jitter EVERYTHING indluing the digital bus. So my guess is this circuit needs some TLC beyond just capping.
But yea. I could go on and on. And on.. And on and on... and on some more... hahah...
I didn't exactly paraphrase his one comment about black to white. Its highlighted here.
Here is another interesting Email.
It's about the Bandwidth of the Marquee.
| Chris Stevens wrote: | The whole path from BNC to CRT grid can exceed 300Mhz, power bandwidth measured at the tube. That claim is very accurate. Ive swept that path and its got response to 600Mhz. You do gotta replace that crappy coax tho, bandwidth limiting. The VNB is a wonder of engineering. The use of RF power transistors was awesome.
But a higher resolution is not tied like you think to bandwidth. LOTS of things effect the ability to resolve that resolution that is fed to the grid. That tube is a messy analog place. Messy RF analog place. With HIGH voltages present.
The bandwidth of the channel is not as important in this case as say a clean supply on those RF output transistors. ANY noise on those rails ends up in the signal. That effects resolution by adding noise ( fuzz ) to the beam spot. Anything that adds noise to the beam decreases resolution. If there is noise in deflection then the pixel does not land in exactly the same spot frame after frame but moves around very slightly at like 60hz. This has the effect of reducing resolution by making the dot look fuzzy again.
So a 1Ghz bandwidth is great, but if your dot is fuzzy in the range of a 200Mhz equiv, then any change you made elsewhere does not matter.
So EVERYTHING effects percieved resolution in this case. Vert deflection is a big one. That flutters and moves up/down by more then 1 line frame by frame. With a still picture. On dynamic contrast changes scene to scene BIG changes of pic size can occur because of "bloom" which is a lack of HV regulation when the tubes are pulling more power. This "jitter" vertically by one or more lines decreases percieved resolution by 1/2. So having the HV stable, the deflection stable and all sorts of things like focus and alignment effect resolution and so bandwidth alone does very little above 300mhz. |
| Posted: Sun Feb 28, 2016 1:25 am Post subject: |
Yeah, Chris is a bit out there, but unquestionably he's brilliant and was thinking of things a decade ago that most of us haven't considered even today.
He looks at a Marquee the way a race car builder would look at any given brand new car off the lot that has some performance potential. "I think I can keep the radiator cap stock. The rest has to be replaced or modified if you want to win on race day."
I find myself wondering what we might have ended up with if the old quantum phosphor project had come to fruition. Theoretically, it could have resulted in flat panel CRTs suitable for projection use, with huge brightness ability and very high resolution capacity, with phosphor life that's orders of magnitude better than regular phosphors.
Today, we're starting to see the beginning of the usage of quantum dots. I wonder if there is any relationship between quantum dot principles and the quantum phosphor principles?
There was a time when I was thinking about how phosphors brown (burn) in a tube and it's oxidation between the binder chemicals and the chemicals in the phosphor, which occur as a function of time and temperature. It had occured to me that if there was a way to create a phosphor and binder system that had no oxidizers in it (Oxygen, chlorine, bromine, fluorine) then you would have a phosphor that can't burn as there'd be no way to complete the burning chemical reaction. That would have been a nice innovation. Permanent phosphor, never burning or browning.
I have found an HDCP removal device on amazon for just 25 bucks, and it's the HDMI 2.0, 4K capable version. So with THAT out of the way, all I would need would be a really kick-ass software engineer to contribute (for free, of course ) some programming time, to program up an FPGA to derive RGB or component signals from the datastream.
It may be a dead end road, but I'm enjoying the drive.
| Posted: Sun Feb 28, 2016 3:05 am Post subject: |
Part of my plan (as it sits now) is to retrofit Barco magnetics into the Marquee chassis. This will be the full magnetics stack out of a Cine 9/909. Reason: Room on the tube neck. The Marquee deflection yoke and convergence coil take up more room on the tube neck than the Barco units do, and since I'll be running the same focus yoke you find on a Cine 9 (after any required mods, of course), and these are longer focus yokes, they're far more compatible with the Barco deflection and convergence yokes from a physical standpoint
I'll be able to put the focus yokes in their optimal position this way. This is going to be important so it's worth the trouble to try to adapt different deflection and convergence yokes to the Marquee chassis.
What I don't yet know is whether or not the deflection and convergence yokes will work properly with Marquee circuitry with only connector replacement and rewiring as needed.
Hopefully, they will.
| Posted: Sun Feb 28, 2016 12:57 pm Post subject: |
Measure the indictance of both coils to see how close they are. Also the resistance. Remember what Chris said about the yolks:
Good luck
redfox001
| Posted: Sun Feb 28, 2016 2:17 pm Post subject: |
I know that those yokes have to be put further forward but I also had the 1292 yokes and did not try any more. If you can show how to do this I will put them on my Marquee too. I also foudn out that Mike modifies a resistor vallue on the focus board to get more adjustment range. Never tried it though. See if i can find it.
| mp20748 wrote: | For anyone using the Barco 909 focus coils in a Marquee, change the following resistors for better Static focus range and best overall focus
R138, R238, R338 from 4.7 ohm to 4.0 ohm 1 %
Also remove R145, R245, R345 |
http://www.curtpalme.com/forum/posting.php?mode=quote&p=433753
| Posted: Sun Feb 28, 2016 3:18 pm Post subject: |
I've started making notes and adding them to a file just to plan all this out! I can't rely on MY memory to retain everything, that's for sure.
I guess I should start by going on the hunt for a low cost MTF measurement rig. I will need hard data to determine the effect of any mods made, and as they'll be focused on reducing noise, as Chris Stephens pointed out, noise in the beam control circuits (deflection and focus, and convergence, too) will manifest in a larger spot size, affecting MTF readings. Noise in the video path is more obvious but noise in the deflection systems WILL have an effect on spot size, resolution, and MTF.
Ultimately, the CRT displays intensity and time. We want to quiet it down in BOTH domains.
I'm going to be looking at EVERYTHING. I seem to remember reading "the stig amps are noisy" somewhere, so yes, even
astig and convergence amps will be looked at for unwanted noise and quieted down if I can figure out how to do it.
| Posted: Sun Feb 28, 2016 8:09 pm Post subject: |
| cmjohnson wrote: | I've started making notes and adding them to a file just to plan all this out! I can't rely on MY memory to retain everything, that's for sure.
astig and convergence amps will be looked at for unwanted noise and quieted down if I can figure out how to do it. |
That would have been me. it was the new longbow Astig Amp boards that are noisy as @#ck !!!
Here is how I fixed the problem as I didnt want to do it the fun way on a board level search at that time
https://www.youtube.com/watch?v=P7Eu4RHnle8&list=PL27EFC9D12963126D
Oh, and for measuring MTF TSE told us to just use photoshop to get a fair estimate of the value. I dont remember the entire process. He would throw up the 1:1 pattern and take a pic of the lines. then he would blow up the image and measure the color in photo shop of the center of the light line compared to the black. I also guess if you blew it up enough you could count how many pixels of the lighter color increase with each mod you do to see if the white area increases in pixel size in the picture you took of the picture. It was in a MTF thread here somewhere.
EDIT: found it
https://www.curtpalme.com/forum_archived/viewtopic.php@t=23159.html
| Posted: Mon Feb 29, 2016 11:20 pm Post subject: |
Thanks for finding that topic. I've bookmarked it for future reference.
For setup and adjustment of flare, astig, and triangularity, plus ultimate focus adjustments, I'm going to be using a
camera on a tripod, with its HDMI output feeding to a monitor, so I get a close-up view of the screen while I'm back at the projector. This method should be very good. For a camera I use my Nikon D800 or my D810, both are 36 megapixels with HDMI outputs.
I am looking forward to kicking off this project just as soon as the magnetics I bought from Redfox001 (Thanks, Red!) arrive.
I'll be picking up Projector no. 2 at the home of its former owner (a friend of mine) in the next day or two. Ironically, I helped him to buy it a few years ago. Loaned him the cash to get it and we took a road trip to pick it up.
| Posted: Thu Mar 10, 2016 1:45 am Post subject: |
Parts are starting to come in. Projector 2 is here, finally, and I'd forgotten that it already has both red and green C elements so I have those to swap over to the HR tubes when the time comes for me to do that.
Once the Barco magnetics arrive, I'll start with a baseline evaluation of Projector 2 in its stock form. Then, rip it open, yank out the tube assemblies, put the HR assemblies in place with the stock Thomson magnetics, set it up, and get some basic performance data on it.
Then, swap to the Barco magnetics, performing all needed wiring adaptations to make it all work, and then set them up and see if things look any sharper.
Then begins what I expect to be a long process of iterative tweaking and adjusting. And circuit mods for noise reduction, one board at a time.
This won't be a weekend project. I expect it to divert some of my time on a regular basis for months to come.
The plan is also to fully upgrade Projector 2 to full Ultra standards from top to bottom. But an Ultra HR with additional performance mods.
| Posted: Mon Mar 14, 2016 9:02 pm Post subject: |
Magnetics are here, and I just scored a quantumdata test generator for 99 cents on ebay. Even after shipping it's quite a score!
This evening I want to start metering out the Barco magnetics and comparing their values to Marquee magnetics, and document them, of course, so as to have a good baseline for comparison.
If they're within 20 percent then I should be able to just swap the connectors and run them.
| Posted: Tue Mar 15, 2016 1:35 am Post subject: |
I'm searching out as much data as possible on the Barco KF-3212 focus yokes so hopefully I won't have to open one up and disturb its internal alignment. Plus I don't want to break one.
Its extra connections are for an extra pair of 6 pole dynamic astig windings.
I believe i will be able to connect the Marquee astig circuit to EITHER the 4 pole windings or the 6 pole windings, but obviously, I won't be able to use both at once like a Cine 9 or 909 can.
That should be OK. I don't anticipate that making a large difference in what I can get from these tubes.
The idea of using the Barco deflection and convergence coils to allow for proper location on the tube neck for the Barco focus yoke seems to be workable, but I will have to modify the Barco yoke beyond simply changing the connectors.
The Marquee deflection yokes have a scan fail detection coil added to them, but it's glued in around the rim of the yoke and it appears to be a stand-alone coil system that can be lifted off the deflection yoke as an assembly and then glued down on the Barco deflection yoke. I'll just have to heat up the glue to extract it, then glue it back down on the new coil in a suitable location.
| Posted: Tue Mar 15, 2016 6:37 pm Post subject: |
I may not be right about the scan fail coil, I need to revisit the manual and read about the scan fail detection again.
The Barco deflection coils are more different than I expected. Their coil inductance values are roughly half that of the Thomson deflection yokes (regular Marquee variety) and the Thomson yokes are actually configured with two separate H coils which are connected either in series OR in parallel by relay switching on the HDM, depending on scan rate.
The Barco coils don't have this feature. While there are two H coils they are connected together in series, and that's hard wired. I will have to unsolder that connection and add wires to make the two coils indepenent and make them compatible with the HDM's system. But I am not sure yet if I'm going to need to modify the HDM to make it work right.
Fortunately I do have a "sacrificial lamb", an 8" LC tube assembly that can be used to test and validate all experimental changes made to any magnetics and circuits. If it gets a spot burn, nobody cares.
I came up with an idea just for testing the idea of what would happen if you were to actually have a way to run both the 4 pole and the 6 pole astig windings in these Cine 9 yokes.
Since my basic tests will be performed on a SINGLE CRT assembly on a test chassis, I'll test using the green channel. And I will be free to utilize the astig control off of either the red or blue circuits to drive the second astig winding on the Cine 9 yoke on the tube under evaluation.
Of course, that's not going to work with all three tubes installed, but I will be able to at least simulate what might happen if the Marquee could drive two astig systems.
I've looked at the Marquee's control architecture and I am rather disappointed that it wasnt engineered to control the individual boards via serial data over an I2S bus. If it did have control architecture like that, then actually adding a new secondary astig control system would be electrically and mechanically simple, and require modified firmware on the CLM. But since the CLM doesn't work like that, to add a secondary astig system to it would be a much more involved process that would still require new firmware and the addition of new hardware, AND require a significant physical mod to the CLM.
