what can i do to boost picture quality on a barco 701?
barcodude
Posted: Tue Nov 17, 2015 10:30 am    Post subject:
redfox001 wrote:
Lol that is funny. Usual there is a little written text on the board that says hé I am the bad connection! Not.
You can find it by inspecting a board but takes someone with experience in electronics.
duh get it. So if i'm lucky it's the 708 CRT socket/video amp?
Epson EMP TW700 - Projecta HomeScreen Deluxe- Denon a/v receiver - Mission highrisers -klipsch subwoofer - Samsung Bluray player
redfox001
Posted: Tue Nov 17, 2015 11:35 am    Post subject:
Yes good chance you would have to buy one from Curt but that is cheap.
On the other hand you could take my offer for the 809 and do a huge step forward Very Happy
barcodude
Posted: Tue Nov 17, 2015 12:45 pm    Post subject:
i hear you Smile it would be grate to own your split pack!
https://www.barco.com/en/Products/Projectors/Simulation-projectors/9-CRT-projector-designed-to-meet-limited-space-requirements-for-immersive-Simulation-and-Vamp;AR-dis.aspx
alleen waar zijn je lenzen?
but a bicycle repair-man in training doesn't make me rich Embarassed
redfox001
Posted: Tue Nov 17, 2015 2:20 pm    Post subject:
Well it is the smaller brother the 809 Wink
You get lenses with a small problem for free. Curt has usable 9 inch CRT's for almost nothing. The tubes you see on the picture have logo burn and are not usable. I am afraid going 9 inch will still cost something.
barcodude
Posted: Tue Nov 17, 2015 2:38 pm    Post subject:
so the set is comtible with 9incher's and yours have logo burn áh now i know Surprised
dus als jij de set zou verkopen aan mij moet ik zorgen voor 9 incher's okiedo
Posted: Tue Nov 17, 2015 2:40 pm    Post subject:
barcodude wrote:
if it's not a bad connection, then the 708 CRT socket/video amp is probably bad.
and were do you find the bad connection if it's that case?
regards, barcodude
About all it can be here is the white connector that goes to the input board may have pulled out a bit, but I doubt it. As redfox says, you can't see a bad part/connection without doing some signal tracing.
barcodude
Posted: Tue Nov 17, 2015 2:44 pm    Post subject:
so i have to do some signal tracing, check for loose connections and maybe replace the amp that you sell ok
Posted: Tue Nov 17, 2015 2:55 pm    Post subject:
Try this:
Interchange the white connectors between the red and green tube on the board. Be very careful not to bend a pin on the input board, that's very easy to do. It won't damage anything if you do, you can bend it back, but that can cause another problem in the set.
if it is the neck board, then the problem will stay with the same tube. If it's on the input board, then the dead tube will switch to the other one.
That's really about all the testing you can do, and almost guaranteed it's the neck board (CRT socket)
barcodude
Posted: Tue Nov 17, 2015 3:04 pm    Post subject:
thank's i'll keep ya'll updated Thumbs Up
redfox001
Posted: Tue Nov 17, 2015 3:48 pm    Post subject:
Yes at this point I do not know what tubes I can sell here. I have some but they are pretty good so not free. You could get a green for free with fast phosphor.
barcodude
Posted: Tue Nov 17, 2015 3:57 pm    Post subject:
so send me a e-mail with detail where and what i could get for it @ what price Cool
because if you talk about fast phosphor you lost me...
barcodude
Posted: Wed Nov 18, 2015 8:16 am    Post subject:
dus wat is kapoet wat doet het, en wat heb je als reserve onderdelen? Wink
redfox001
Posted: Wed Nov 18, 2015 1:22 pm    Post subject:
Ja ja rustig Very Happy Je hebt een email!
barcodude
Posted: Wed Nov 18, 2015 7:22 pm    Post subject:
thanks,
nu is het helder Thumbs Up
regards barco dude
barcodude
Posted: Tue Nov 24, 2015 1:19 pm    Post subject:
solved
i have a chance to buy a hd fury, will it work on a 3bnc rgb output (sync on green)?
will i have a better picture over hdmi than component? Confused or is it a waste of time and money?
barcodude
Posted: Sun Nov 29, 2015 11:59 am    Post subject:
stupid now i got my bluray hooked up and trying to watch a standard dvd and now i see some stripes in de image like i'm feeding a to high resolution yeh right Neutral
blurays no problem, clean image. Standard dvd's some stupid picture noise?
somebody?
Posted: Sun Nov 29, 2015 6:08 pm    Post subject:
somebody?
component output on a blue ray player is limited to 480P on regular DVD, component video is capable of 1080P but the firmware will not scale up DVD thru the analog out jacks.
Thank the industry lawyers for this brainless feature
Posted: Sun Nov 29, 2015 11:18 pm    Post subject:
somebody?
Over there that would be 576P at 50Hz, but yes a completely stupid 'feature' on Bluray players.
barcodude
Posted: Mon Nov 30, 2015 9:18 am    Post subject:
so it's about conflicting output's why i have that stupid noise in the picture?
Posted: Mon Nov 30, 2015 10:21 pm    Post subject:
are you referring to the stripes, AKA "Scan lines" , as noise or is there a different noise your talking about?
If it's just scan lines, that's normal. When resolution is lower the retrace lines get bigger and more visible.
Page 3 of 5
