Finally my Barco CineMax
Goto page Previous  1, 2, 3
Decibel
Posted: Mon Aug 10, 2015 8:12 am    Post subject:
This is the point of the situation: with the help of some friends I repaired the circuit ++ 9v located of sub boards of both SMPS boards that I have available.
This failure caused a lost power of the controller.
So much so that it was not possible to use the diagnostic software.
Repaired circuit ++ 9v now I can see tensions with diagnostic software.
But the projector is still not working.
Should there be a problem in the circuit +/- CON generated from the second SMPS + G2 board.
The corresponding voltages (+/-) should be symmetrical with values ​​around 37 / 39v.
Instead they start for a few seconds correctly then suddenly step to double values as is possible to view in picture below.
This could have caused an overheating of a security resistor of the convergence board that appears burned.
I replaced the resistor but have not solved the problem because the failure, in my opinion, should be before the second SMPS + G2 board.
Perhaps just on the board but having two available that show the same reactions I tend to exclude them.
Domenico (Barco fan!)
Decibel
Posted: Mon Aug 10, 2015 2:15 pm    Post subject:
OOOOOK
Finally the projector start up.
There was some resistor burned, I must to replace some diodes.
Actually the +/-CON circuit of the Convergences board is disconnected by jumpers.
I must to try to reconnect this circuit hoping in a success.
But now I'm stop only test ... I want to rest a little
digitalayon
Posted: Mon Aug 10, 2015 7:30 pm    Post subject:
if mine did what your is doing,.....I'd go digital or call Curt for a CRT sale..
Francisco
Posted: Thu Aug 13, 2015 12:01 pm    Post subject:
Welcome to the Barco 909 919 cine9 Cinemax club.
Decibel
Posted: Thu Aug 13, 2015 2:17 pm    Post subject:
Very Happy Very Happy Very Happy
ElTopo
Posted: Thu Aug 13, 2015 8:48 pm    Post subject:
Yeah welcome Thumbs Up
Barco Cine 9 the one and only
ElTopo
Posted: Thu Aug 13, 2015 8:51 pm    Post subject:
Why buying a Sony 4K when you can repair a 50K Cine9 Mr. Green
Decibel
Posted: Thu Aug 13, 2015 8:57 pm    Post subject:
Mr. Green Thumbs Up
ElTopo
Posted: Fri Aug 14, 2015 3:02 pm    Post subject:
Have you done a setup already on the Cine9 ?
Decibel
Posted: Fri Aug 14, 2015 3:13 pm    Post subject:
No I never had a cine9 / 909. This is the first time.
ElTopo
Posted: Fri Aug 14, 2015 3:23 pm    Post subject:
Is the projector running stable now ?
Decibel
Posted: Fri Aug 14, 2015 3:53 pm    Post subject:
I'm doing the last tests. Notice noise on blue tube.
I have to try to change the source.
ElTopo
Posted: Wed Aug 19, 2015 4:32 pm    Post subject:
Set it up !
It's the best picture available Thumbs Up
Decibel
Posted: Wed Sep 02, 2015 1:31 pm    Post subject:
Ok the projector start up but I noticed that the side and top/bow geometry adjustments no working.
No problem in raster shift.
Posted: Wed Sep 02, 2015 2:14 pm    Post subject:
You've done a lot of work on this projector yourself, and while I respect that, it makes it very difficult to determine if this was a fault that was original to the set, or something that has been created by working on the set. There are a number of boards that can cause this issue within the set. My offer stands to test/repair boards for you if you want to send them in.
Decibel
Posted: Wed Sep 02, 2015 2:56 pm    Post subject:
You're right Curt.
Something I fixed it myself and there's something that I have certainly broken because of my hurry.
The problem for people who do not live overseas are the huge shipping costs for items that are losing more and more market value.
My projector had the sub board of SMPS broken and defective convergences + controller boards.
I successfully repaired the SMPS sub board (and also bought a spare).
I also bought a controller board working and I'm waiting for the deliver of a convergences board.
I have to try if the replacement convergences board solves the issues of geometry's adjustments.
If I will not solve, the send of various boards to test/repair could be a viable option.
ElTopo
Posted: Tue Sep 15, 2015 9:23 pm    Post subject:
Is it running now ?
Decibel
Posted: Wed Sep 16, 2015 7:04 am    Post subject:
ElTopo wrote:
Is it running now ?
the projector is in my workshop and it is almost ready. After the replacement of the convergences board all adjustments work. Remains a issue with the convergence of the red at the corners of the image.
Decibel
Posted: Wed Sep 30, 2015 8:32 pm    Post subject:
Decibel wrote:
ElTopo wrote:
Is it running now ?
Unfortunately the issue of corners it's a simpthom of a bad convergences board. I need another spare part. Curt I wrote a mail to you.
Posted: Wed Sep 30, 2015 8:42 pm    Post subject:
Email answered.
Page 3 of 3
