Jeremy112
| Posted: Sun Feb 01, 2015 6:59 pm Post subject: |
| AnalogRocks wrote: | | Jeremy112 wrote: | Never did make a parts list for the set, I just ordered what was bad right away. I normally don't repair TV sets anymore myself, they are just too awkward to haul around and are generally not worth the effort to repair.
You'll have to poke around with a DMM to see whats bad. I only worked on the set as it was for a friend.
I probably did get your PM about scaling, I'll check it out and reply back to ya. |
Do you remember if it was just caps or was it transistors and IC's too? I'll poke aroundwith a DMM later but just wondering which parts you replaced? |
No capacitors, it was diodes and rectifiers (the parts attached to the heatsinks) There should be a couple test points on the board, if you have them and test the test points in diode scale with a DMM, and it tests short, that's your problem board, and likely the bad parts I just mentioned. I had to replace all of them. I was fortunate that none of the other boards were bad, and all the voltages were spot on with the Service manual.
FWIW I had the PN51D550C1FXZA model mac mentioned, the 1080p version, but almost the same thing otherwise.
Also those test points should be on the Y sustain as well and buffer boards.
Also the blink codes mean jack.
| Posted: Sun Feb 01, 2015 7:05 pm Post subject: |
OK I just know on the SONY TV's I've worked on the blink codes pointed us in the right direction.
I'll hit the boards with the DMM when I get the chance. Looking forward to a successful repair.
| Posted: Sun Feb 01, 2015 9:01 pm Post subject: |
No blink code chart for Samsung.
| Posted: Sun Apr 12, 2015 1:38 pm Post subject: |
I pulled this apart and, tested the X-main board last night. Out of 14 transistors 12 appear to be shorted. The Y-main didn't have the same issue.
Also got really weird readings for the 4 electrolytic caps on there. (150 uF, 105deg, 250v ) so I'll change those too. Who knows it may live again.
So where should I place my order for the parts?
Jeremy112
| Posted: Sun Apr 12, 2015 3:38 pm Post subject: |
| AnalogRocks wrote: | I pulled this apart and, tested the X-main board last night. Out of 14 transistors 12 appear to be shorted. The Y-main didn't have the same issue.
So where should I place my order for the parts? |
ebay is the only place you'll find those parts, and 12 out of 14? Exact same count that went bad on mine!
Replace those (and the caps too) and it should work fine, theres not a lot to the board. The only other thing would be to check the PSU voltages after its working to make sure they are where they're supposed to be. Mine were spot on after the repair so it didn't need adjustment.
| Posted: Sun Apr 12, 2015 3:49 pm Post subject: |
| Jeremy112 wrote: | | AnalogRocks wrote: | I pulled this apart and, tested the X-main board last night. Out of 14 transistors 12 appear to be shorted. The Y-main didn't have the same issue.
Replace those (and the caps too) and it should work fine, theres not a lot to the board. The only other thing would be to check the PSU voltages after its working to make sure they are where they're supposed to be. Mine were spot on after the repair so it didn't need adjustment. |
Yeah what a coincidence eh?
I'll scour eBay for these then. Thanks!
| Posted: Mon Apr 13, 2015 1:33 am Post subject: |
Not finding what I need on ebay.
Here's the parts list:
1. AUX 71617 SF10A400H X2
2. RJP30H1 71M 1CH5 X 2
3. AUK 5156 SMK1820 X 2
4. 30G124 X 3
5. RF1501 TF3S X2
6. AUX 61618 SF10A400H
7. AUX 6167 SF10A400H
CAPACITORS:
Electrolitic
150uF, 105 deg C, 250volt x5
| Posted: Mon Apr 13, 2015 1:46 am Post subject: |
I'm guessing only one transistor is shorted. A bunch are in parallel (usually), so if one shorts, they all read that way.
| Posted: Mon Apr 13, 2015 1:48 am Post subject: |
| Curt Palme wrote: | | I'm guessing only one transistor is shorted. A bunch are in parallel (usually), so if one shorts, they all read that way. |
Awww nuts!
| Posted: Mon Apr 13, 2015 2:15 am Post subject: |
and, as you've found out, it's a bitch to figure out which one is bad. Worse, in some NEC chassis, some transistors get shorted out by relay contacts when the set isn't on (and at some resolutions), so you pull ALL of the transistors that read a dead short, and all of them are OK. Took a while to figure that one out.
| Posted: Mon Apr 13, 2015 2:26 am Post subject: |
| Curt Palme wrote: | and, as you've found out, it's a bitch to figure out which one is bad. Worse, in some NEC chassis, some transistors get shorted out by relay contacts when the set isn't on (and at some resolutions), so you pull ALL of the transistors that read a dead short, and all of them are OK. Took a while to figure that one out.  |
For the price I paid for the TV I'll replace all of them. IF I can find them.
| Posted: Mon May 04, 2015 1:46 am Post subject: |
| AnalogRocks wrote: | Not finding what I need on ebay.
4. 30G124 X 3
5. RF1501 TF3S X2
CAPACITORS:
Electrolitic
150uF, 105 deg C, 250volt x5 |
Hey guys! A little help please! I am having trouble finding all of these. Any help's appreciated.
| Posted: Mon May 04, 2015 1:55 am Post subject: |
You probably can't. Why not just look for a used working board on eBay? Will be faster and cheaper.
Jeremy112
| Posted: Mon May 04, 2015 3:04 am Post subject: |
| Curt Palme wrote: | | You probably can't. Why not just look for a used working board on eBay? Will be faster and cheaper. |
That itself is quite a task too since its a commonly failing board. They likely aren't available. I bought all the parts on ebay, so if they aren't on ebay, I don't know where they could be bought from then.
| Posted: Mon May 04, 2015 3:54 am Post subject: |
I've been watching eBay for months now, but as Jeremy says most of these TV's have the same board fail so very hard to find. Lots of Y-sustain boards but no X-Sus boards
Anyone else have any ideas for the parts?
Jeremy112
| Posted: Fri May 15, 2015 2:27 pm Post subject: |
AR, can you give me the part # of each part you need, and quantity of them? I bought more than I needed for my TV like this in the event I came across another one since I figured these parts would become unobtanium.
Give me what ya need and I can see what I got left
| Posted: Sat May 16, 2015 2:54 pm Post subject: |
| Jeremy112 wrote: | AR, can you give me the part # of each part you need, and quantity of them? I bought more than I needed for my TV like this in the event I came across another one since I figured these parts would become unobtanium.
Give me what ya need and I can see what I got left  |
Look 4 posts up ^
http://www.curtpalme.com/forum/viewtopic.php?p=440056#440056
Jeremy112
| Posted: Sat May 16, 2015 4:01 pm Post subject: |
lol DUH huh? I'll look for those and get back to you in a few
| Posted: Tue May 26, 2015 3:58 am Post subject: |
| Jeremy112 wrote: | lol DUH huh? I'll look for those and get back to you in a few |
Any luckj digging these up?
