newbie here need help diagnosing pioneer svx-821
Goto page Previous  1, 2, 3 ... 7, 8, 9 ... 13, 14, 15  Next
Posted: Sat Jan 10, 2015 4:14 am    Post subject:
Well that is great to hear. Now you can enjoy it. Smile
jgrice53
Posted: Sat Jan 10, 2015 7:06 pm    Post subject:
Hi mac, yes it is working but there is a problem with the right front channel. The volume output is very low and the sound is distorted. Do you have any ideas?
Posted: Sat Jan 10, 2015 9:07 pm    Post subject:
Must be 1 or more bad parts still in there. Set your DMM to DC voltage and test all the speaker terminals and see if the RF has any DC. Not likely but check there first.
jgrice53
Posted: Sun Jan 11, 2015 10:25 pm    Post subject:
volume min. or does it matter? speaker connected or not? i have never done this test before.
Posted: Sun Jan 11, 2015 10:43 pm    Post subject:
Speakers disconnected, volume doesn't matter. The only thing that needs to be sure is that the speaker relays are latching on but since you have sound coming out then they are latching. That is why this test does not always work. If the relay is not closing then you cannot test for DC at the speaker connectors.
jgrice53
Posted: Mon Jan 12, 2015 1:50 am    Post subject:
So even if the sound is good at the left front channel, I still should test it? As well as the center and rear channels?
Posted: Mon Jan 12, 2015 2:33 am    Post subject:
Sure. It only takes a few seconds. I always check for DC on all channels after a repair. And idle current should also be checked and adjusted if needed. But it needs to be running properly first for that.
jgrice53
Posted: Mon Jan 12, 2015 2:20 pm    Post subject:
R channel .033v
L channel .028v
C channel .038v
R surround .035v
L surround .033v
B L channel .000v
B R channel .000v
Sub .000v
Posted: Mon Jan 12, 2015 6:08 pm    Post subject:
I hope you already tried a different speaker on the problem output? Very Happy
Those numbers look ok for now. The FR amp appears to be balanced but unknown if running. So problem could still be in amp section or could be in preamp section. The best approach is to verify which section the problem is in instead of hunting blindly. So in looking at the schematics I believe this to be the best approach.
On the amp board, locate the harness connected to CP401. This harness goes to the audio board. You need to swap 2 wires and see if the problem stays or moves. If you can get the wires out of the connector with the releases that would be good but if not you will have to cut.
On CP401 you need to swap pins 1 and 9. This is for FR and FL. I have attached a pic for guidance. After the swap, connect speakers to FR and FL and see if the low volume and noise is still where it was or moved.
jgrice53
Posted: Mon Jan 19, 2015 7:29 pm    Post subject:
hi mac, is there another way to troubleshoot the r.channel besides switching pins 1 and 9 on CP401? i really do not want to cut the wires and i really don't think i could ever get them out of the connector. I have checked with headphones and the output and sound is good on channels A & B, so I would say the pre-amp is okay right? Maybe i missed one of the output transistors on the amp board? if you say that swapping pins 1 & 9 is the best way, i will go ahead and do it.
Posted: Mon Jan 19, 2015 8:42 pm    Post subject:
Are you good at looking at schematics or even ok at it?
jgrice53
Posted: Mon Jan 19, 2015 8:45 pm    Post subject:
ok i would say
jgrice53
Posted: Mon Jan 19, 2015 8:47 pm    Post subject:
i can read as far as symbols go and tracing out the parts, but what does what i have problems with.
jgrice53
Posted: Mon Jan 19, 2015 8:48 pm    Post subject:
for instance i can find a diode or transistor and test them but i don't how one will will affect the other
jgrice53
Posted: Mon Jan 19, 2015 8:58 pm    Post subject:
in the above schematic of the channels coming off of CP401, I can see the right and left are the same circuit so with out your help i would just try to compare the voltages and values of each component in the left and right channels and knowing that there is a problem in the right channel, i would look for any test point and then value that is different than the left channel.
Posted: Mon Jan 19, 2015 9:05 pm    Post subject:
Ok, then you should be fine with this. In the image below you will see CN1 which is all 5 channels coming into this board. Now these lines are final lines which means they have gone through preamp and final amp stages and now are just being directed to where they need to go. So if you look at your problem speaker line (FR) where it comes into CN1 you can then follow it to relay 2. But you will see where it also splits off to speaker B terminal and relay 1.
So if relay 2 is activated then your A channel speakers will play. If relay 1 is activated the head phones will play. And if B channel is selected then speakers B will play.
But regardless what is selected, it still comes from the same, final speaker line.
SO........ if your headphone RF plays fine but the speaker RF does not, then it would be either the speaker, or relay 2, or a problem on the line from the relay 2 to the speaker A terminal.
If your unit has B channel speaker you could test that output and see if it is distorted. BUT, it will have to also turn off the A channel relay. Because if the is a problem on the line from the relay to the terminal and the A relay is on then the same problem will exist on the B channel also.
Hopefully you got all that, lol.
jgrice53
Posted: Mon Jan 19, 2015 9:34 pm    Post subject:
RIGHT speaker channel A & B have the same problem. i know it is not the speaker because i am using 1 speaker and changing it from one channel to the other channel
jgrice53
Posted: Mon Jan 19, 2015 9:41 pm    Post subject:
Only 1 speaker connected to the speaker A r.channel and selector on channel A only there is low volume. turn off receiver and move connection to speaker B
r. channel and selector on speaker B only there is still low volume.
Posted: Mon Jan 19, 2015 9:57 pm    Post subject:
And on headphone the RF sound fine and the same as the LF?
jgrice53
Posted: Mon Jan 19, 2015 10:03 pm    Post subject:
yes headphone and LF good sound.
Page 8 of 15
