| Posted: Mon Dec 01, 2014 1:51 am Post subject: |
The whole neck board
the big E
| Posted: Mon Dec 01, 2014 2:00 am Post subject: |
Ahh ok now I will have to do that
Good thing I already have the top off the set
I am
So glad Black Friday is over with as i was working almost non stop and it's like to drive me crazy:p
the big E
| Posted: Mon Dec 01, 2014 2:03 am Post subject: |
The green tube just blinked off
Arrg I now wonder if it's the hvps(I do have a spare)
| Posted: Mon Dec 01, 2014 3:11 am Post subject: |
Probably not, but try it.
the big E
| Posted: Mon Dec 01, 2014 3:19 am Post subject: |
| Curt Palme wrote: | | Probably not, but try it. |
Ok I know my spare hvps works so first chance I get around to it I will swap it in and see if the issue remains
I think I need to get the power supply for my twin before my marquee needs parts(don't want both sets down)
I have noticed the tubes would get slightly brighter then back to normal then they would get slightly dimmer then back at times before the tubes would randomly blink off
Also every time a storm would be near and lightening strikes somewhere it would make the tubes shut off for said split second (it's been doing that for about six months)
Hence why I am thinking it's the hvps
I also have a spare lvps just in case I need it
the big E
| Posted: Mon Dec 01, 2014 3:20 am Post subject: |
I meant dwin(stupid autocorrect)
the big E
| Posted: Mon Dec 01, 2014 3:33 am Post subject: |
| Nashou66 wrote: | Does it go out of focus at all ?
Nashou |
Nope
You can see a very faint image on the blue tube when it does this(can't read anything on the screen of the tube to tell if it loses focus or not it's that dim)
the big E
| Posted: Mon Dec 01, 2014 4:04 am Post subject: |
Ok I just powered it back on and bam no blue so I got a couple pics and also tried the convergence(doesn't work at all when the tube blacks out)
Screen pic
Blue tube pic(it does look like it loses focus best that I can tell)
the big E
| Posted: Mon Dec 01, 2014 4:05 am Post subject: |
The pic above is the brightest it's been when it decides to go dim any other time it's almost black (this is with the lights off)
the big E
| Posted: Mon Dec 01, 2014 4:27 am Post subject: |
| Nashou66 wrote: | Might be the G2 for the Blue is going bad in the HVPS. Are you sure you tried the Blue VNB on the red Tube and the red VNB on the blue to make sure its not the VNB?
Nashou |
Not yet
Going to swap them around and see if it follows the board or not
Will update
the big E
| Posted: Tue Dec 02, 2014 12:32 am Post subject: |
Well bad news I swapped the neck boards between the green and blue tubes and the green is now dead
So I need a new neck board
Now both projectors are down and I am using my Sony projection tv(it beats nothing)
the big E
| Posted: Tue Dec 02, 2014 3:58 am Post subject: |
| Nashou66 wrote: | I bet it might be a loose resistor , one of the 33 ohm carbon comp ones that sticks straight up and is covered with a clear plastic
shield to protect a short from the Metal plate.
Nashou |
That would explain why it was a intermittent issue and seemed to do it the most at first power up(cold)
Is it possibly fixable??
I did have a electronic service manual for the marquee chassis that I found online but I think it may have got deleted or is buried in my laptop's hard drive somewhere as I hav been able to find it (just when I needed it)
| Posted: Tue Dec 02, 2014 8:16 am Post subject: |
Nashou |
Once I had a simlar fade-out problem, and there the 1uf ceramic cap in the upper section of the VNB had some intermittent conduction. It was odd...
the big E
| Posted: Tue Dec 02, 2014 3:26 pm Post subject: |
I may give the board a once over when I get the time to
I am going to get a back up from curt till I can(may eventually get a set of neck boards to have as spares)
