Random no blue on marquee
the big E
Posted: Sat Nov 29, 2014 3:02 am    Post subject: Random no blue on marquee
Guys I have noticed over the past few months that my marquee has been having a random no blue tube(tube face would be really dim and seem blurred and is barely visible when looking into the lens)
I removed the top to see if the tube heaters was the culprit but they aren't
The amount of time it does this will vary but the longest lasted long enough that I was able to load a game(gran tursimo on ps3) and the blue tube was dark from the time I powered up everything to the time the start screen showed on the game
I haven't had time to check anything other then making sure it was the tube heaters bad(been crazy busy due to the holiday sales)
Any ideas as to what is the issue??
It also does it with the test grids
crt king of black
Posted: Sat Nov 29, 2014 9:01 am    Post subject:
Swap the blue neckboard with an other, and see if the problem follows the neckboard.
dvh99
Posted: Sat Nov 29, 2014 1:22 pm    Post subject:
if that doesn`t help swap the little video cables on the vim.
Posted: Sat Nov 29, 2014 1:32 pm    Post subject:
I bet its a weak connection for the Blue G2. see how tight it fits on the G2 pin. If it is loose carefully and gently use some pliers to crimp the G2 connector a bit so it fits tightly on the tubes G2 pin. Also clean the contact with de oxit while your in there.
Posted: Sat Nov 29, 2014 2:38 pm    Post subject:
Isn't the missing G2 causes super bright screen? Confused
Posted: Sat Nov 29, 2014 4:25 pm    Post subject:
No, an open pin on the G2 causes excessive brightness and spot burn. Losing the G2 voltage without an open circuit or the video signal causes a black screen.
the big E
Posted: Sat Nov 29, 2014 6:47 pm    Post subject:
Ok thanks guys I will try everything suggest out later today and it's if the issue returns or not
What's so weird is the fact it's so random as to when it does it
One time it done it and I cycled the power and it worked fine
I made sure when I installed the nine inch tubes that everything was snug and tight and it was working fine for months(almost a year) before it started this
I am glad it hasn't spot burned the tube though
crt king of black
the big E
Posted: Sat Nov 29, 2014 10:13 pm    Post subject:
Here is a pic of the tube when it acts up
Let me know if the pic doesn't work
crt king of black
the big E
Posted: Sat Nov 29, 2014 10:15 pm    Post subject:
Its weird as it will be working normal one second and like in the pic I uploaded above the next
crt king of black
Posted: Sat Nov 29, 2014 10:37 pm    Post subject:
Ok on the VIM swap the green and blue mini rca's to see if the issue goes to the Green.
nashou
Posted: Sat Nov 29, 2014 10:42 pm    Post subject:
Ok on the VIM swap the green and blue mini orcas to see if the issue goes to the Green.
nashou
WTF is an "orca"?
Posted: Sat Nov 29, 2014 10:45 pm    Post subject:
sorry typo
rca's
the big E
Posted: Sat Nov 29, 2014 11:18 pm    Post subject:
nashou
Ok I will in a bit
I checked the connections on the neck board and everything was snug
I will update later
crt king of black
the big E
Posted: Sun Nov 30, 2014 2:00 am    Post subject:
Update I swap the connections and am waiting for it to act up again to see if it acts up on the green tube
Not sure when it will as it would do it then it would vary as to when it did it again
crt king of black
dvh99
Posted: Sun Nov 30, 2014 1:31 pm    Post subject:
nashou
WTF is an "orca"?
beautiful creature actually
https://sites.google.com/site/biologybfinalproject/animalia/orcinus-orca
Laughing
the big E
Posted: Sun Nov 30, 2014 9:20 pm    Post subject:
Well I had to going for almost four hours with no problem
Any ideas as to why it was acting up in the first place?
Going to use some more later tonight and see if it acts up again
crt king of black
the big E
Posted: Sun Nov 30, 2014 9:21 pm    Post subject:
nashou
WTF is an "orca"?
Laughing
Agreed
crt king of black
the big E
Posted: Mon Dec 01, 2014 1:17 am    Post subject:
Well the blue tube blinked off one time so far
I don't know why but I have feeling it's the neck board Sad
crt king of black
Posted: Mon Dec 01, 2014 1:41 am    Post subject:
Swap it to the red and see if the red does it too.
the big E
Posted: Mon Dec 01, 2014 1:45 am    Post subject:
The neck board or the cable connection on the vim?
Ps sorry of I am sounding clueless but I have been so busy with holiday sales it's crazy
crt king of black
