New batch of Marquee HDMI v3 cards. Pre-order and save!
Goto page Previous  1, 2, 3, 4, 5
Posted: Fri Feb 19, 2016 5:26 am    Post subject:
CIR Engineering wrote:
To me the color benefit of UHD is far more important than the resolution. IMHO the best part of UHD is the benefit of the color resolution. This is a difference between individual people that I have noticed over many years of calibration and video engineering; some are more attune to sharpness and focus, others to color fidelity and gamma. While I appreciate all aspects of quality video, I am certainly a color fidelity and gamma guy, and having colors not technically correct will absolutely bother me in real world video video.
Just asking, but are you color blind or color deficient (partially color blind). I have many clients who are. Most have trouble with red, but some are totally color blind. To them, obviously color does not mean a great deal or is at least less importaint. Just curious.
This!! I much prefer an expanded color gamut and greater bit depth. Unfortunately it is easier for manufacturers and salesman to sell 4k. At least the rest will hopefully come along for the ride with discs. Streaming will probably compress the image down to worse than SD.
You are correct about UHD discs and 4k. I watch a lot of OTA and the new ATSC 3 standard should be 3840x2160. There are bits and pieces of it talked about, but my guess is that it should be ready to roll out in '18. Hopefully by the start of the next decade, all broadcasts will be running the new standard. I find PBS to have the best quality at the moment with Nova and Frontline really looking great. I must confess though that my kryptonite is banding and the intro in Frontline has it. Banding drives me nuts and the reason I am so selfish on wanting greater bit depth.
Posted: Fri Feb 19, 2016 2:18 pm    Post subject:
Actually the rabbit is inside the cat. The cat ate it already.
There are at least two things that look like they MIGHT be well camouflaged rabbits hiding in the grass in that picture, but no confirmed actual rabbits. I'm just funning you.
Posted: Fri Feb 19, 2016 2:48 pm    Post subject:
Now I am sure there is a rabbit Wink
Posted: Fri Feb 19, 2016 2:49 pm    Post subject:
I wonder if we will ever actually get UHD over the air in the USA... I hope so.
Posted: Sat Feb 20, 2016 3:56 am    Post subject:
I suspect that if we do, it'll be so compressed that it would drive any videophile insane.
Posted: Sat Feb 20, 2016 5:37 pm    Post subject:
There have been tests going on for the new ATSC 3 standard. They even did a broadcast at CES this year.
https://en.wikipedia.org/wiki/ATSC_standards#ATSC_3.0
http://www.tvtechnology.com/news/0002/khmptv-delivers-live-hdr-4ktv-in-atsc-30-at-ces/277694
http://atsc.org/newsletter/atsc-3-0-what-will-the-standard-look-like/
I understand your typical hyperbole. Discs will always be the gold standard, because it is easier for them to hold a larger amount of data and distribute that data. With new codecs, it should be possible to send a UHD signal OTA with very good quality. HEVC/H.265 is supposed to be able to compress a file to a quarter of the size of a mpeg at the same video quality.
Personally, I would rather have everything be 1080p/60 with expanded color gamut and 4:4:4. Most people would see a bigger difference with that than just running a weak UHD.
Posted: Sat Feb 20, 2016 6:15 pm    Post subject:
Yeah I know it's supposed to happen, but remember when HD rolled out... It took some stations many years past the FCC deadline to finally get some sort of digital broadcast up. And that was after the deadline was pushed back a number of times. Now we expect the stations to shell out big bucks again to upgrade to UHD hardly a decade later. Big markets will no doubt see it first if and when it happens.
Japan has such a huge advantage for UHD broadcast. Half the population of the USA packed into such a small country. It was relatively easy for them to upgrade because there are far fewer towers to worry about.
Posted: Sun Feb 21, 2016 5:30 pm    Post subject:
Well to be fair they were making the switch between analog to digital. The stations were having to outlay a lot of money when the shift over the previous twenty years had been to cable/sat. Now, it seems that people are seeing that they can dump cable/sat and go with OTA/internet. The latter option is usually cheaper and at least in the case of OTA superior pic quality.
Don't quote me, but I thought I read somewhere that for the stations they would need a lot less new equipment therefore the outlay would be minimal. Lets be blunt. The cable/sat companies can roll this out quicker, but the more people find out that they can get OTA UHD for free the more people will consider it.
Everytime I consider going back to cable/sat, I hear the horror stories. The latest was my mother at xmas. I was looking at her bill and nearly went into orbit when I found she was paying $140 a month for Comcast's midtier package. I yelled at my sister and told her she needed to take care of this ASAP.
One other thing that hasn't been mentioned is the sub-channels. This has given the stations an alternate source of income, as well as expanding the amount of programming on TV. I just saw that there is a new scifi channel called Comet. Unfortunately for me they are only in WPB as of now.
Posted: Sun Feb 21, 2016 5:46 pm    Post subject:
My "hyperbole" in my previous comment was based on my own (cynical) observations concerning what my local cable provider has done to its customers.
While I am not privy to the ultimate bandwidth capacity that their system has, it is apparent by looking at any given sports broadcast that they have chosen to carry more content at a high compression rate than carry less content (channels) at higher quality. Watch a sports program (football showing the problems most clearly) you see artifacting every single time the camera is panned. Since I don't drink I'm never drunk enough not to notice.
Granted, the way the current system works is not even remotely like legacy analog cable, with many channels actually carried down the coax, but instead it is a pure digital client-server system. I understand that. But they're offering so many interactive services and have such a high system bandwidth loading that they compromise image quality in favor of all these bells and whistles.
Their attitude seems to be to turn down the picture quality until they get too many complaints about the sucking picture quality, then they turn it up just enough to make the phone stop ringing.
it's my fear that OTA and cable providers will always choose against providing purest image quality when they can compromise image quality and derive another revenue generating source from it.
Posted: Mon Feb 22, 2016 4:49 am    Post subject:
So, you are conflating OTA and cable/sat. The latter has a fixed pipe in which to shove as many channels as they can down their customer's throat. OTA is a single channel. They have other constraints, but hopefully the quality will be maximized.
Ironically I think it will be the distribution which will be the hold up for UHD, as the content providers should be able to produce everything in UHD for not to much more expenditure.
Posted: Mon Feb 22, 2016 5:47 am    Post subject:
I think OTA for UHD will be problematic in any event. The broader the signal bandwidth, the harder it is to maintain signal integrity over a long distance. Even allowing for improvements in compression algorithms and modulation schemes, I'd expect a UHD carrier to be broader than an HD carrier (two for one channel slots?) and even harder to get good range out of it.
There's a reason why broadband internet isn't already everywhere. Broadband signals don't carry unless you put a lot of power behind them. Speed and distance costs money, how far and how fast can you afford to go?
Page 5 of 5
