redfox001
| Posted: Wed Oct 08, 2014 9:51 am Post subject: |
| CasetheCorvetteman wrote: | | Press zero on the remote. |
No I mean by removing some resistors. What resistors or what connections?
| Posted: Wed Oct 08, 2014 11:40 am Post subject: |
Never heard of that.
stridsvognen Guest
| Posted: Wed Oct 08, 2014 2:43 pm Post subject: |
| redfox001 wrote: | | stridsvognen wrote: | | CasetheCorvetteman wrote: | | I wound it all the way anti clockwise , nothing changed |
Im quite sure it do, but you need to meassure it, dobt you will be able to detect by eye.
I always deactivate the gama section of the card.
Do you have a pic of your card, from the inside, so i can see the print layout.? |
How do you deactivate the gamma? I would like to try that too. |
No idea where those resistors are on the EXT V3.
| Posted: Mon Oct 20, 2014 8:35 pm Post subject: |
Case, to get your contrast correct again set the EXT to 16-235 and run a white window into the HDMI at 100 IRE. Make sure the source is also outputting luma in range 16-235. You can use a test Bluray or a pattern generator.
Connect your oscilloscope to the GREEN RGB output and measure the p-p voltage. Adjust contrast such that the p-p is 0.7 volts.
If you send me a photo of the front and back of the EXT I can tell you what to pull off to disable gamma.
redfox001
| Posted: Fri Oct 31, 2014 1:36 pm Post subject: |
This is the external Moome v3. Can you tel how to disable the gamma on this one? The top yellow wires go to blue gamma and contrast pots.
