| Posted: Fri Feb 13, 2015 10:26 am Post subject: |
I spent a lot of time working on my astig and both mechanical and electronic focus, there was never any trick photography used. It was basically digital sharp at 1920x1080p
redfox001
| Posted: Fri Feb 13, 2015 10:54 am Post subject: |
I did the main astig zones on red and green. The zones that are really over the edge I left alone might work on those later. Also I did not do much on blue but it might bring more colour uniformity over the screen when I do blue to. Oh and I did not do anything yet with the 6-poles. Did you work on the 6-pole does it pay off? My dots seemed pretty round but perhaps in some edges the 6 pole could improve. I love how very stable this focussing mechanism works on the barco to get everything 100% in control if your taking the time to.
redfox001
| Posted: Fri Feb 13, 2015 11:01 am Post subject: |
Next thing I will go back to the Marquee and see how she works. I have no idea yet. On the mechanical part I noticed that the barco astig magnets turned easy and steady while the Marquee magnets slipped a lot. Also the centering of the focus yoke is difficult to work with for a beginner but it might be of some benefit. To be honest I think I will have to replace the yokes with the barco yokes if I want to ever get anywhere. But that is not so difficult.
| Posted: Fri Feb 13, 2015 11:59 am Post subject: |
I did the lot yes.
| Posted: Fri Feb 13, 2015 12:00 pm Post subject: |
I did the lot yes.
redfox001
| Posted: Fri Feb 13, 2015 2:36 pm Post subject: |
I looked at the barco service manual and they say:
Dynamic Astigmatism
Use Menu>Service>Common Settings>Dynamic Astigmatism>Genlocked Pattern
Play around with the SHARPNESS-keys (over-focus) and CONTRAST for best visibility
Adjust all areas for most circular dots (use 6-poles if they seem to be triangular)
Aim is to get best focus around value 57 (Sharpness/Focus-buttons)
I did not see triangles so I left the 6-pole but I guess close inspection might disclose some triangles
Francisco
Joined: 05 Apr 2007 Posts: 305 Location: The Netherlands
| Posted: Tue Feb 17, 2015 12:08 pm Post subject: |
| redfox001 wrote: | | gjaky wrote: | | stridsvognen wrote: |
Ill claim that LUG tubes and sharp image is not super important when evaluating PQ.
Nor the bandwidth While my opinion could be ignored as I don't own a high-end 9" machine, but switching from the PG xtra to the XG LC got me a huge step forward in picture quality. Both machine had about the same spot size, in my case the PG xtra had significantly higher bandwidth, still the XG with its current 30MHz bandwidth throws a lot better picture. You can say all 9" machine are LC, but the room you use also has an impact on contrast.
Also bandwith only affects the sharpness in the horizontal plane while spot size affects in both planes. if I'd only have one choice between an ES (spot size-wise) machine with 100MHz clean bandwith, and an EM machine with low bandwidth, I'd choose the EM machine... |
He I realise you say something true. Spotsize has a huge impact on sharpness. It clearly makes my desktop characters more readable yet it does only a little on MTF. I clearly see the lines in the 1:1 now but the contrast of the lines has not much changed. To judge sharpness do we have to look at both in the 1:1, the brightness and the separateness of the lines? I think spotsize brings out the details sharper and bandwidth makes them brighter. |
Wow, this is the reason I like Barco 909 series with modified boards. It improves bandwidth MTF and also sharpness. For me it's the ideal combination between (in my eyes) good bandwidth and superior sharpness. Must say that I spend many hours to do 2-4 pole mechanic astig until center dot's are perfectly round and don't move when under and over focussing. Then I did whole 4-6 pole electronic adjustments which made the picture very sharp and detailed even in all corners. When I'm very close to the screen I can determine scan lines everywhere, even in outer corners. The HFQ900 do help here a lot I must say.
_________________ Philips vacuum cleaner | Trystar double toaster | Car radio with orange plastic memory arrows | Class A Fridge
redfox001
| Posted: Fri May 15, 2015 11:40 am Post subject: |
Here is the 1:1 of my modified Marquee. I know Strid has posted much better 1:1 but he told me he never watches a movie with those as the slightly lower bandwidth looks better so says Mike. Think to much bandwidth is to noisy.
When I compare with the 1:1 Francisco posted of his 909 they seem very similar.
I know the 1:1 is not everything and I had to do hard work to get the focus comparable to the Barco Cinemax but I now have the feeling I am as sharp but I do not get clear scanlines however hard I try. That must be because I do not have lug tubes. It does not show in the picture to me. I do see clearly the 1:1 pixel lines. Perhaps a bit clearer on the Cinemax.
I do have to add that compared to my unmodified Cinemax I very much prefer the modified Marquee. Details are much sharper and I see amazing blacklevels.
Still I feel like modifying the Cinemax in the near future
jbmeyer13
| Posted: Fri May 15, 2015 3:00 pm Post subject: |
| redfox001 wrote: | Here is the 1:1 of my modified Marquee. I know Strid has posted much better 1:1 but he told me he never watches a movie with those as the slightly lower bandwidth looks better so says Mike. Think to much bandwidth is to noisy.
Still I feel like modifying the Cinemax in the near future  |
Is that 1080p/60? Do you have a stock board screen shot to compare to?
redfox001
| Posted: Fri May 15, 2015 3:31 pm Post subject: |
Depends on what stock board you compare with. Some look almost the same but than there is a lot of peaking on them. When replacing the parts with high bandwidth parts they look better but when the peaking is changed they look the same again. But some look very worse. I think it is possible to make the 1:1 look better but I think that will not make the picture look better.
Have to add I have a vim02 with mini board and modified Moome in the chain. I think it will never get perfect 1:1 even with perfect neckboards but I do not see that as a problem as was explained to me.
