Need lens suggestions for Marquee 8500LC
Posted: Tue Jul 22, 2014 9:15 pm    Post subject:
Be sure to make up your mind (stock or upgrade to 9") before you hang it. The throw distance between the two is waaaaay different. That said, I would leave it stock and look for a red and green c-element and just use it.
modelaratrod
Posted: Tue Jul 22, 2014 9:34 pm    Post subject:
I had asked Curt which throw chart to use for the 8500LC and he said the 9".
With that being the case the throw would be dependent on the lenses correct?
Posted: Tue Jul 22, 2014 11:31 pm    Post subject:
the throw is a formula based on your lens choice and screen size but you need to use the 8500 chart unless you swap to 9" tubes.
The marquee 8500Lc with HD lenses has some of the longest throw distances of any CRT, and if you put it where a 9500 would normally sit you will not be able to get a large enough image for your screen.
Posted: Wed Jul 23, 2014 6:19 am    Post subject:
gjaky wrote:
digitalayon wrote:
Yep.....selling the 8 inchers to pay for cost of 9's might be worth it. Would he need plates for this? I participated in one of these upgrades last year on a 8110 but not a 8500LC
No way I would toss a NOS 8" set for a DIY 9", remember it is NOS, the magnets are still factory aligned, and probably is spot on. If it is true that the 8500LC uses P16 tubes this is especially true, even if he would push the tubes hard they will last years!
Arent they 180DMB22 tubes?
Posted: Wed Jul 23, 2014 6:29 am    Post subject:
There is a set of GT17s in the buy sell section.
digitalayon
Posted: Wed Jul 23, 2014 5:39 pm    Post subject:
Yeah I'm not buying the P16 tubes....that was a major mod if true. I just do not see that mode being on a 8 set.
Posted: Wed Jul 23, 2014 5:50 pm    Post subject:
