WTS
| Posted: Sat Jan 27, 2007 2:02 am Post subject: |
If I remember right I didn't tie it anywhere. I think it is just a tach sensor.
_________________ Thanks
Walter
kal Forum Administrator
WTS
| Posted: Sat Jan 27, 2007 3:23 am Post subject: |
Hmm, I'll have to have a look at that and let you know.
Walter
v_erich
Joined: 12 Sep 2006 Posts: 76 Location: Austria/Europe
| Posted: Sat Jan 27, 2007 4:45 pm Post subject: |
Hi Kal,
can you say something to the noise level of the Silent-X?
A friend has them in his G90, this is a good replacement in that CRT.
What is in the BArco? Is the little better noise level of the fans hearable?
Rgrd,
Erich
WTS
| Posted: Sat Jan 27, 2007 4:55 pm Post subject: |
Well I would say it was an improvement over the stock fans which had a constant droning sound to them, These just have the air turbulence noise.
Walter
| Posted: Sat Jan 27, 2007 8:19 pm Post subject: |
| v_erich wrote: | Hi Kal,
Depends which Barco you're talking about, but in my Cine8 Onyx clone (Zenith 1200), it's got the following fans:
3 in the back: NMB model 4710NL-04W-B30: 119mm x 25mm, 2050RPM, 35dBA noise, 79.4 CFM
The one in the front: NMB model 3110NL-04W-B50: 80mm x 25mm, 3250RPM, 34dBA noise, 38 CFM
Pretty much all Barco's are quiet to begin with as compared to a lot of other CRT projectors, but if you want get ever quieter, nothing wrong with using SilenX fans.
I'm not sure however that they'd last as LONG as the NMB stock fans. I have my doubts as the NMB's are probably good for 50K+ hours. So if you end up replacing fans, be careful and check them and/or use a temp sensor of some sort. I use one of those little stove temp sensors with an alarm to make sure the temp stays under a certain range. In other words, it warns me if ever my hushbox air evacuation or the built-in fans fail.
ChrisWiggles Opinionated SOB
| Posted: Mon Jan 29, 2007 4:29 am Post subject: |
Hey guys, sorry I'm being lazy and I am unclear as to what the right fans are. I have what I am sure are original fans in a high-hour G808 chassis that I'd like to switch out. Which fans do I purchase?
v_erich
| Posted: Mon Jan 29, 2007 10:14 am Post subject: |
Ok, thanks for the Informations.
Then I will try first the series resistor (0E, 5E, 10E) and then the replacement with the Silent-X.
Greetings,
Erich
| Posted: Mon Jan 29, 2007 1:31 pm Post subject: |
Well, I've finished installing 4 new SilenX fans replacing the existing ones.
Barco varies the voltage supplied to the fans based on how hot the chassis gets (the sensor's in the SMPS). My hushbox is well cooled such that the fans never get more than the min +7.5V fed to them. If you run the SilentX fans out in the open vs. the stock fans, the SilentX fans are basically completely silent. The stock NMB fans have some mechanical noise to them.
Does this mean that that projector is now completely silent with new fans? Of course not. A large percentage of the noise that was generated before is still being generated: Noise generated due to air turbulence.
The difference is that now the noise is lower and is more of a 'whoosh' than a 'whoosh' with a mechanical clicking. Sorry, can't take any noise level measurements as my radio shack meter doesn't go low enough. It is quieter for sure. Not as quiet as no hushbox of course. Given the choice I'd take stock fans with a hushbox any day over no hushbox with SilenX fans. The hushbox makes a much bigger difference.
In the back I used:
(2) SilenX IXP-76-18 (120mm x 38mm/90CFM/18dBa)
(1) SilenX IXP-74-14 (120mm x 25mm/72CFM/14dBa) (the angled fan)
In the front I used:
(1) SilenX IXP-74-14 (120mm x 25mm/72CFM/14dBa) (placed on an angle with a shroud).
I took a bunch of pics so I'll put together some instructions with more thoughts/opinions.
picree
Joined: 31 Mar 2006 Posts: 351 Location: Johnson City, TN
| Posted: Mon Jan 29, 2007 5:31 pm Post subject: |
So-kal, eventhough the SilenX spec says minimum operating voltage of 8V you found no problems at 7.5V? Did you test to see what the actual starting voltage of the fans might really be?
Curt
| Posted: Mon Jan 29, 2007 5:50 pm Post subject: |
Nope! I never tested to see what the minimum was... that would have been a good idea (though I don't have a variable voltage supply here, though I could make something simple temporarily I suppose).
You say the min is 8V? Where'd you see this? I didn't find anything on their site before I made the purchase (I was specifically looking for it). Bought anyway since other Barco owners had already do so before me and not had any problems.
My exact voltage is +7.54VDC last I measured immediately at startup.
Person99
| Posted: Mon Jan 29, 2007 5:57 pm Post subject: |
| kal wrote: |
Kal |
Looking forward to this!
I may have to do this in the coming month.
| Posted: Mon Jan 29, 2007 6:13 pm Post subject: |
What someone needs to do is redesign the 808 chassis from the ground up for more efficient air-flow to avoid all this turbulence. (not going to happen).
When you pull the 3 back fans off and take a look at what they're doing, it doesn't make much sense. Some of the fans back into areas that are almost 50% just flat aluminium which probably causes most of the air turbulence.
I suppose if you could remove the back of the PJ (and leave it off), you could probably build some sort of nice baffles or something to avoid such abrupt changes in air flow. Something with nice curves in it that would allow you to offset the fans from the chassis a few inches to give you room to build curved baffles of some sort.
Though in the end, still easier to do a vented hushbox. It's amazing how much it helps keep it cool too. As I was putting the back of the PJ back on I had the hushbox venting system off temporarily since the feeder wire was disconnected and I was amazed at the amount of heat build-up around the ceiling area from only 20-30 mins of working around there.
Person99
| Posted: Mon Jan 29, 2007 7:37 pm Post subject: |
| kal wrote: |
Though in the end, still easier to do a vented hushbox. |
Speak for yourself. The ceiling in my HT is 10'. The PJ hangs down so far that I'd have to drop the ceiling to practically do a hushbox (assuming I didn't want to have a 4' tall hushbox!).
Person99
| Posted: Mon Jan 29, 2007 8:27 pm Post subject: |
| kal wrote: | Dave: How's the PJ hang down? On what?
Kal |
I'll take a pic. I have the Peerless mount that was sold by Zenith (they sold the peerless as an option, not the barco one). So, I have a >2 foot 1.5" diameter pipe the comes from the ceiling plate to the peerless mount. The lowest part of the PJ is 6' 4" off the floor.
We don't have basements in TX, so most of our theaters are in dedicated rooms most often on the second floor. 9 and 10 foot ceilings in them are not uncommon.
picree
v_erich
| Posted: Wed Jan 31, 2007 10:21 am Post subject: |
Kal,
a question to your suggestet fans:
You wrote:
| Quote: |
(1) SilenX IXP-76-18 (120mm x 25mm/72CFM/14dBa)
(1) SilenX IXP-76-18 (120mm x 25mm/72CFM/14dBa) (placed on an angle with a shroud).
I think, the 120x25/72/14 are the IXP-74-14.
Is this right?
Do you have pics from your front fan mounting?
Which Back-Fan is the slower one?
Thanks and Regards,
Erich
