Am I the only person that misses 4:3 for TV?
digitalayon
Posted: Sun Jan 19, 2014 5:03 pm    Post subject: Am I the only person that misses 4:3 for TV?
I know they wanted tv to be like a theater and standardize a ratio of 16:9. But I miss having more area vertically. It made it fun. Perhaps I just miss how the signal filled on my old 52 inch CRT TV. I mean my 50 inch plasma does ok. Perhaps the "jump effect" is gone. You know when you went from a 19 inch tube to a 52 inch it was massive. Then added a 16:9 panel and never felt like it took off for me. It actually felt a lot smaller.
ElTopo
Posted: Sun Jan 19, 2014 6:12 pm    Post subject:
21:9 the only one Thumbs Up
Barco Cine 9 the one and only
Posted: Sun Jan 19, 2014 6:19 pm    Post subject:
I still have 4:3 but only a few channels still broadcast that way and not all the time. I'll miss it too.
The other thing that annoys me is the aspect ratio changes. Say you have one show at 4:3, the commercials may be 16:9 in a 4:3 window, you try watching this on a 16:9 set and you get the "postage stamp" look. Little tiny picture in a big window. Then the next commercial fills the screen, Then you are back to the 4:3 program.
416ray4538
Posted: Mon Jan 20, 2014 12:22 am    Post subject:
They have to keep changing things because new/different is always better. Makes all the old stuff just that much more "last week" and therefore just not good enough. I mean what's the point of making new stuff if you can't make the old stuff obsolete. We have to buy things, take them home, then throw then in the trash and buy new crap so that the companies that make the crap can go on making crap and having us buy it, take it home, then throw it in the trash.
When the first clock was invented, how did they know what time to set it to?
No point being pessimistic; it probably would't work anyway.
Posted: Mon Jan 20, 2014 12:44 am    Post subject:
Its much better for CRT life as well.
the big E
Posted: Sun Feb 02, 2014 6:21 am    Post subject:
I also miss the 4:3 due to the same issue ar has
Here I have a 120 inch screen and a 4:3 in a 16:9 program is like 60inches wtf is up with that
Don't get me wrong I like 16:9 but it does have its downfalls
Speaking of which I had a plasma tv get major uneven wear due to this very thing(looked great at the sides but the middle was dull)
crt king of black
larryp
Posted: Sun Feb 02, 2014 6:30 am    Post subject:
my screen is 4:3 I just use the crop - stretch- & letterbox feature on the direct tv remote. works for me
the big E
Posted: Sun Feb 02, 2014 6:33 am    Post subject:
My ps3 looks like crap at 480 with my screen size(tv and movies not so much)
The older game systems use only 4:3 though
crt king of black
winny
Posted: Sun Feb 02, 2014 9:52 am    Post subject: Re: Am I the only person that misses 4:3 for TV?
I read on toms hardware back in the days that one of the reason was because there where only two manufacturers initially for LCD panel production equipment which used a fixed panel size (in the order of 1.2x2 meter). In terms of yeild and geometry, you could only do so much for panelizing 4:3 TVs and several smaller 4:3 screens onto the same larger panel and if you didn't have the same sales figure for the sizes you panelized, your yeild just went down considerably. Solution, make the screens the same ratio as the big panel loaded into the machine. Voilá! 16:9 is born!
Melifluonze wrote:
Posted: Sun Feb 02, 2014 10:31 am    Post subject:
16:9 was born due to it being right in the middle of 4:3 and 2.35:1
I was using a 125" 5:4 screen for a long time, I used active masking for the 1.78:1 and 2.35:1 aspects, but I recently bought a larger screen and it only comes in 1.78:1 or 2.35:1.
I never watch TV, so that isn't an issue. I do play a lot of old video games, and they are almost all in 5:4 ( some arcade games ) or 4:3. Split screen games on older consoles were almost all split horizontally, meaning the 5:4 screen was perfect.
Running a 1.78:1 or 2.35:1 inside a 5:4 wear area is no problem at all. I could game all day and night and never worry about the static wear ever being visible within the wider formats.
Running 4:3 within a 1.78:1 ( or ever worse, running a 1.78 and a 4:3 inside a 2.35:1 ) will use a small to really small tube face area, and will wear within the movie viewing area unevenly every single time.
The issue with 16:9 aspects here in Australia is they NEVER took off at all until they were forced upon the consumer. I did own a 16:9 Panasonic GAOO rear projection CRT, but I never knew anyone else at all that ever had a wide rear pro, and only ever met one other person that had a wide direct view CRT ( Philips Matchline Pixel Plus 2, so they were after high image quality ) Any stores that displayed 16:9 aspect TVs sold very very few of them, because for regular viewing there was a compromise. You either got short fat people, boarders at the sides, or cut the top and bottom off. In the case of the Panasonic, there was a mode that would stretch the image more the further away from the center, which worked very well, however it still cut parts of the image off top and bottom.
When plasma TVs started selling here, there was no option, so you either went 16:9 or you bought another CRT with a better image and at a considerably cheaper price.
The issue with computers and especially internet browsing is that width is never the issue. Its the height you always want more of, hence the 5:4 format, allowing more height to fit the Windows task bar at the bottom of the screen and not imposing on the 4:3 viewing area. Same goes for 16:10 over 16:9. Trying to get a computer monitor in 4:3 or 5:4 these days is possible, if you want to put up with 1280x1024 resolution and 19" screen size... Cause that's about all you can get. And they are dear as f***. Id happily go back to the 1920x1440 or my CRT monitor any day.
Having all that height of the 4:3 made the TV look HUGE.
Posted: Sun Feb 02, 2014 10:34 am    Post subject:
I wouldn't run a single CRT projector on a 2.35:1 screen ever... At least the 16:9 window within it will have perfect astig and great corner focus I guess... Laughing
HogPilot
Posted: Sun Feb 02, 2014 2:57 pm    Post subject:
Not only is it "right in the middle" of 4:3 and 2.35:1 (technically it would be 2.37:1, although the actual "scope" AR is 2.39:1), but it allows all ARs between 4:3 and 'scope to be displayed at equal area:
http://en.wikipedia.org/wiki/File:Dr._Kerns_Powers,_SMPTE_derivation_of_16-9_aspect_ratio.svg
There's at least one guy on AVS who has a dual motorized masking setup and displays his material in this manner (equal area).
Of course this is purely a matter of personal preference, but I've always found myself wanting more width rather than height. Scrolling up and down is normal because we read from the top to the bottom of a page, but scrolling left and right to read due to a lack of screen width drives me absolutely nuts. I think 4K monitors will fix a lot of that...you'll be able to display a LOT of info with all that resolution and size, as long as your viewing distance is close enough so as not to strain your eyes while reading text Smile
the big E
Posted: Sun Feb 02, 2014 3:52 pm    Post subject:
I have a samsung rear projection crt tv and when I replaced the red tube the wear pattern was close to the edge but that was widthwise the top and bottom had virgin phosphor
Its a 16:9 HDTV
Here in my area people wasn't in a hurry to go to HDTV due to the same issues case listed
I may set me up a extra screen for 4:3 only so I can play the older games in all they're splendor
I knew it had to be the manufacturing side of things somewhere that forced this on us
crt king of black
digitalayon
Posted: Sun Feb 02, 2014 4:30 pm    Post subject:
Good to know I am not the only one that feels we now have less area on the screen.
the big E
Posted: Sun Feb 02, 2014 5:08 pm    Post subject:
I rather have a 120 inch screen without the black bars then have one with them
Downside is my hdtv tuner doesn't do the crop or pan and scan stuff whereas my other equipment does
crt king of black
larryp
Posted: Sun Feb 02, 2014 5:20 pm    Post subject:
I have a old 3DO game system which I still use a lot. Looks great on my set up. Regular & HD tv look great to. No complaints at all.
Posted: Sun Feb 02, 2014 7:27 pm    Post subject:
Personally, I couldn't care less about no more 4:3. Don't miss it at all. I always hated the shape (almost square), because I always watched movies, watch are almost exclusively a wider aspect unless you like to watch a lot of black and white. For projection, a decent-sized 4:3 screen won't work in rooms with normal floor-ceiling heights because it gets too tall. It leaves no room for a center-channel speaker, and I watch almost zero 4:3 content.
Posted: Sun Feb 02, 2014 8:46 pm    Post subject:
Absolutely correct Hog, it comes down to personal preference regardless, whats practical for me is not for Crabb Laughing
MrBlonde83
Posted: Tue Feb 04, 2014 6:30 pm    Post subject:
I have to agree that 4:3 looks a lot larger... You do have that height that makes it seem much larger. Especially with these projection screens. I remember watching all the president's men (4:3 side DVD) and how awesome Washington DC looked at night like you were looking out of a nice picture window on a tall skyscraper. I guess the only way you'd get that size is by making your screen larger.
Posted: Tue Feb 04, 2014 7:08 pm    Post subject:
The problem is that in most rooms, you don't have that height. In my room, and in most rooms in North America, 4:3 will be smaller than 16:9, which will be smaller than scope.
To illustrate, take a typical US basement with an 8-foot ceiling. Mine is slightly shorter than that, so it's even worse. Assuming you don't want your center channel sitting on the floor, or your screen jammed against the ceiling, you're left with less than 6 feet for screen height. Mine is 54 inches, so I have a 96x54 16:9 screen; 110-inch diagonal. If the screen was 4:3, it would only be 72x54 - 3/4 of the size of my 16:9 screen. So, in my room, and in reality, 16:9 not only looks larger, it actually is much larger.
All that ignores the one major problem a lot of height gives you too, which is sight lines if you have multiple seating rows.
If I had the room, I'd go audio-transparent scope. I'd shorten the height of the screen a bit to 48 inches tall, which would give me a 115-inch wide scope screen. Site lines would be better, big, epic scope films would be bigger than 16:9, 16:9 HDTV, dramas, comedies, and animation would be bigger than 4:3, and 4:3 would be smallest - just like at the movie theater.
With a few notable exceptions, CIH makes a lot of sense in most rooms, and for most content. 16:9 is a reasonable trade-off, and is where I'm pretty much stuck with my current room.
Other than classic gaming, classic TV (which are all low-res), or the occasional black-and-white film, who's actually watching 4:3 content? If you are, what percentage of it is your watching?
