Convering 1209 to 1209SE (continous scheimpflug)
Goto page 1, 2, 3  Next
winny
Posted: Fri Jan 10, 2014 10:32 pm    Post subject: Convering 1209 to 1209SE (continous scheimpflug)
I got a pile of stuff in the mail today in order to convert my BG1209/2 to continous scheimpflug. First off, the chassis seem to differ. I was under the impression that I might have to make new holes and use nuts since there would be no press-nuts in the correct spots. If I line up the top piece which the housings are attached to to match the outer cover, the hinges will go several centimeter further to the front than they should. I can cut out a piece of sheet metal to extend it but there are other differences too like ventilation holes differ and the side plates are too short on mine for the top piece to be attached with both screws on each side.
This must have been done before. What is the correct procedure?
1209s-top plate on the left side.
 Filesize:  86.82 KB
 Viewed:  8724 Time(s)
Melifluonze wrote:
Posted: Sat Jan 11, 2014 12:27 am    Post subject:
Hey if all fails, you can strap those to your boots and walk across the ice. Laughing
winny
Posted: Sat Jan 11, 2014 1:36 pm    Post subject:
No, if it fails, I'll stop using CRTs and sell both projectors in parts. Besides, I have these for getting across the ice. Great stuff.
 Filesize:  201.29 KB
 Viewed:  8691 Time(s)
Melifluonze wrote:
Decibel
Posted: Sun Jan 12, 2014 9:08 am    Post subject:
You must to use the 1209s top cover and the tube's supports that you see below.
 Filesize:  85.97 KB
 Viewed:  8670 Time(s)
Domenico (Barco fan!)
winny
Posted: Sun Jan 12, 2014 1:31 pm    Post subject:
This L-bracket seems to differ. Do someone happen to have a photo of it at a different camera angle where the screw holes close to the front is visible?
Also, can someone measure the length of this part and/or close-up of the holes at the front?
What's the length of this part?
 Filesize:  90.54 KB
 Viewed:  8662 Time(s)
L-bracket differ.
 Filesize:  197.09 KB
Melifluonze wrote:
Decibel
Posted: Sun Jan 12, 2014 4:57 pm    Post subject:
I hope that this image can help you.
 Filesize:  143.69 KB
 Viewed:  8643 Time(s)
winny
Posted: Sun Jan 12, 2014 5:14 pm    Post subject:
Sorry, not really since I already have this chassis. I need to find out the difference between 1209/se and the chassis in your picture. Can you take a photo of your equivalents to R805628 and
R805033 in your 1209s? Preferably with a ruler or tape measure for scale.
Melifluonze wrote:
Decibel
Posted: Sun Jan 12, 2014 5:51 pm    Post subject:
R805033 there isn't in 1209s!
Look my previous picture!
Next post I'll show the part that you asked.
Decibel
Posted: Sun Jan 12, 2014 5:53 pm    Post subject:
R365005 is different because in 1209s there are three pieces with holes for tube's fix, scheimpflug and others.
Look very well my previous picture.
Decibel
Posted: Sun Jan 12, 2014 6:03 pm    Post subject:
The picture that you asked
 Filesize:  75.04 KB
 Viewed:  8629 Time(s)
Decibel
Posted: Sun Jan 12, 2014 6:15 pm    Post subject:
Other picture
 Filesize:  71.58 KB
 Viewed:  8625 Time(s)
winny
Posted: Mon Jan 13, 2014 12:09 pm    Post subject:
I know. I mean the equivalent panel in your 1209s to the R805033 in 1209.
I used your picture and extended it to show what I mean.
To change the parts in question, how much do I need to strip down? Flip the projector over, take off the outer casing, then what?
Also, someone suggested me to change out some capacitors on the motherboard while I'm at it because they fail over time and are difficult to change unless the projector is in parts. Which capacitors would this be?
What is the length of this panel?
 Filesize:  67.66 KB
 Viewed:  8615 Time(s)
Melifluonze wrote:
Decibel
Posted: Mon Jan 13, 2014 1:36 pm    Post subject:
Here
 Filesize:  90.81 KB
 Viewed:  8590 Time(s)
 Filesize:  77.31 KB
Decibel
Posted: Mon Jan 13, 2014 4:42 pm    Post subject:
The panel is different?
winny
Posted: Mon Jan 13, 2014 6:15 pm    Post subject:
I measured the length to be 565 mm, which should be within margin to match your measurement. The holes does however differ. Thank you very much for your picture!
Since I need the bottom plate and top cover and pay for shipping for them, I might just as well get the side plates as well instead of drilling.
Melifluonze wrote:
winny
Posted: Tue Jan 14, 2014 7:50 pm    Post subject:
Does anyone have the exploded view of the 1209s chassis for reference? I have the service manual but no chassis in it.
Melifluonze wrote:
nombz
Posted: Thu Jan 16, 2014 9:32 pm    Post subject:
Where in Sweden are you located? I have a 1209s/E hanging over my head. If you are close you can come measure Smile
I am in the northeast part of 08-area.
And walking on the ice is not that fun, I am waiting for a few more cm of ice and then I will be living up to my avatar this year again! Smile
BarcoGraphics 1208s/2 and BarcoGraphics 1209s/E
Decibel
Posted: Thu Jan 16, 2014 9:44 pm    Post subject:
In the service manual of 1209s there is the exploded view of the older chassis Rolling Eyes
winny
Posted: Thu Jan 16, 2014 9:55 pm    Post subject:
Lucky bastard! I have ordered all the metal parts needed now, unless the bottom plate is different too. Perhaps some assistance will be needed when it's time to mount everything in terms of photos.
About 180 km I think.
Perhaps I should change mine to a picture of me doing four wheel powerslide as a season special. My Smithers injecting himself with the experimental drug to stay straight didn't end up either animated or very good.
Also, turns out I need to modify the mounting points of my skates to accommodate any normal type of ski boot. *rant*
Melifluonze wrote:
nombz
Posted: Fri Jan 17, 2014 12:00 pm    Post subject:
I have a 1208s/2 chassis "lying" around but I guess that dont have the continuous scheimpflug? Otherwise it might be possible to use it as a donor?
Page 1 of 3
